Block Deck Smoothness - Page 2 - Chevelle Tech
 16Likes
post #16 of 25 (permalink) Old Aug 31st, 19, 8:16 PM
Mr Bill
Re: Block Deck Smoothness
Originally Posted by Bill70 View Post
I would like to see pictures of various Ra finishes. Thank you. BTW this is a higher hp N/A 434.
Sorry for the delay, had to root around and find the surface comparator
ID:	602036   Click image for larger version
ID:	602038   Click image for larger version
ID:	602040   Click image for larger version
ID:	602044   Click image for larger version
ID:	602046   Click image for larger version
ID:	602048   Click image for larger version
davewho1 likes this.
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Team Chevelle #100
BillK is offline
post #17 of 25 (permalink) Old Aug 31st, 19, 11:35 PM
Will it seal if flat, sure, is it right, well that delves into youtube mentaility
Torque em down and run it .
Telling this guy to use a stone and wd40 wtf lol no wonder most have problems.
cuisinartvette is offline
post #18 of 25 (permalink) Old Aug 31st, 19, 11:42 PM
If Mike Lewis says it's not good enough I'm fixing it.
/discussion
I'd absolutely do it Bill's way if it were mine as well. $30 in tools and material for peace of mind. Sold.
CNC BLOCKS N/E likes this.
70 Camino...Roller
Tommy the Cat is offline
post #19 of 25 (permalink) Old Sep 1st, 19, 1:15 AM
Yeah,, you are probably right I don't have a clue what I am talking about when it comes to surface finish for a gasket or machine work,,,,,,,,,,,,,,
I am guessing Cometic doesn't either being they only make the MLS gaskets
https://www.cometic.com/ft-2800-technical-support.html
You might try reading #2
If you decide to use an MLS here I would highly recommend using the FelPro it is more forgiving of surface finish than Cometic, has a different sealer & will have a better chance of working but those grooves are very concerning because a steel gasket doesn't really conform to them well at all
https://www.felpro.com/technical/tec...ce-finish.html
Mike (Wolfplace)
VISIT US AT
----John Wayne----
Wolfplace is offline
post #20 of 25 (permalink) Old Sep 1st, 19, 5:02 PM
Beth
I agree with Mike about Cometic.
I also think a perma-torque gasket would work fine, especially if he honed the surface with the Norton finishing stone.
The stone would knock down all the high spots and leave probably half of the original roughness or less.
Fel-pro says this :
Each type of Fel-Pro head gasket – whether it be PermaTorque® MLS, PermaTorque, solid or perforated core, single layer embossed steel, or other types – all require specific surface finish requirements.
If the surface is too smooth, the gasket will have less "grip" and may leak; if the surface is too rough, the gasket will have a difficult time conforming to surface imperfections and may also leak.
LeoP likes this.
nashville beth is offline
post #21 of 25 (permalink) Old Sep 5th, 19, 7:49 PM Thread Starter
Thank you BillK for posting the pictures. It's clear that my block machine work was not acceptable. Even Cometic replied to me and said their gasket would not work. A week ago I put it back in the crate and sent it back to be fixed. This is an assembled shortblock and I was adamant with the seller that I would not put all of the sanding grit into a new engine. BTW I am told they use a CBN cutter. I hope this has a good outcome. Thanks to everyone for the comments.
Bill70 is offline
post #22 of 25 (permalink) Old Sep 5th, 19, 8:12 PM
I find it hard to believe that was done with CBN unless it was on it's last legs,,,,
This is a Cast Iron block that I finished with CBN,,,,,, & an aluminum head with PCD
Name:	Dart block finish honed & decked (2).jpg
ID:	602468   Click image for larger version
Name:	Brodix Track1 227 Heads 005.jpg
77 cruiser, 71350SS, LeoP and 1 others like this.
Mike (Wolfplace)
VISIT US AT
----John Wayne----
post #23 of 25 (permalink) Old Sep 5th, 19, 8:19 PM
Mr Bill
Originally Posted by Wolfplace View Post
I agree unless it had a giant chip in it I don't see how a round CBN bit could leave a finish like that Looks just like the finish my machine makes if I put the multi tooth carbide head on it.
GuysMonteSS likes this.
Bill Koustenis
Waldorf Md
Team Chevelle #100
BillK is offline
post #24 of 25 (permalink) Old Sep 5th, 19, 8:25 PM Thread Starter
Could the operator be responsible for my outcome? Machine setting?
Bill70 is offline
post #25 of 25 (permalink) Old Sep 5th, 19, 8:43 PM
Mr Bill
I will have to say no but that is based on my machine and all other CBN machines I have seen. The CBN bit is actually round so there is no sharp point to give a finish like that. Even if they had the feed speed way too fast it would not look like that.
Here is an example: https://goodson.com/products/cbn-500d-cbn-cutter-insert That is the size that my machine uses. Unless there is a chip on the edge I cant see how it would leave a finish like yours. To be honest with you I have had a chip on mine and it still does better than that.
Unfortunately there are a lot of shops that do not want to keep up with technology. Probably 75% of my work is 100% stock parts and they still require a better finish than what you have. I have two sets of Ford Diesel heads to do tomorrow and I did a set of Subaru aluminum heads this afternoon. The Subaru's look like a mirror and the Fords will be pretty close
LeoP likes this.
Bill Koustenis
Waldorf Md
Team Chevelle #100
BillK is offline
