Cam timing big block 540 - Chevelle Tech
post #1 of 12 (permalink) Old Aug 21st, 19, 5:08 AM Thread Starter
Håkan
I have a long time project. A 540 big block that i will be installing the cam and timing set on soon. So the cam card calls for a 108 icl, no advance. do you guys think that sounds right or should i install it advanced? I have a stock 572 timing set so I would have to use a ofset key.
Engine specs are. 4.5x4.25 540, brodix bb2 xtra heads, super victor intake, 10.75:1 comp, cam is 260/268 108 lsa, 714/714.
How much would I gain or loose with say four degree advance?
berserker is offline
post #2 of 12 (permalink) Old Aug 21st, 19, 7:30 AM
Justin
Re: Cam timing big block 540
I wouldnt. 108 icl should work good there. There will be plenty of bottom end, more advance would just lower rpm range and build lower rpm power thats just not needed
1989 Iroc-Z Camaro
Dart SHP 401" Twin Turbo
8.24 at 169 street car
Orr89rocz is offline
post #3 of 12 (permalink) Old Aug 21st, 19, 2:37 PM
Dial the cam in, and make sure it ends up at 108, you'll be good.
Mike Lewis street 572
Cale Aronson
Black Magic clutches
Cam by UDHarold
Menscer Motorsports
TRZ
CEAutoelectric
aukai is offline
post #4 of 12 (permalink) Old Aug 21st, 19, 5:22 PM
I'd put it in at 103 ICL. Would run it there. Then I would loosen intake lash .004" and tighten exahaust lash .004". Big improvement after that adjustment.
Chris Straub
Mfg Performance Parts
cstraub is offline
post #5 of 12 (permalink) Old Aug 21st, 19, 9:46 PM
In an effort to learn, why?
68 Chevelle 138 car, 6.0 LQ4 w/ 75mm and 4L80e
73 CJ-5 with a 468 BBC 10:1, 265 AFR's, Sniper EFI. The wheelie machine
bh10 is offline
post #6 of 12 (permalink) Old Aug 21st, 19, 10:03 PM
Travis
If you don't take Chris's advise on advancing the cam you need to definitely do the lash change. Do a before/after test and you won't be sorry!
'62 Chevy Bel Air 461bbc AFR 335, 9x30 slicks, Powerglide, 4.30 gear, stock suspension and drum brakes. 6.320 at 109.28mph-9.942 at 135.91mph.
horton409 is offline
post #7 of 12 (permalink) Old Aug 22nd, 19, 2:21 AM
Is that a test lash, or he can run it there with out seeing how it it does at 108, and the called for lash? He's in Sweden, a new cam may be pricey, and take awhile to show up. Not doubting, just checking.
Cale Aronson
Cam by UDHarold
Menscer Motorsports
TRZ
CEAutoelectric
aukai is offline
post #8 of 12 (permalink) Old Aug 22nd, 19, 6:25 PM Thread Starter
Håkan
Yes I guess the intake/ exhaust split is a little bit small for the heads, So i will try the lash change.
post #9 of 12 (permalink) Old Aug 23rd, 19, 12:20 AM
you'll need to check carefully on the valve to piston clearance after changing the cam timing.
have you already checked?
post #10 of 12 (permalink) Old Aug 23rd, 19, 6:29 AM
If Chris recommends a different split why not just get a different cam ground and be done with it. For that matter you can have the one you already have reground, take a little off the intake side to shorten intake duration and add a few degrees on the exhaust side. Then you're not messing with playing with lash and staying right within the ramps where the lifters should run for durability.
PS I understand you're in Sweden so it's not as simple as just shipping something out via UPS, but if it's a long time project why risk having P/V clearance problems just to beat a couple extra weeks wait.
Status: Car-Less
GRN69CHV is offline
post #11 of 12 (permalink) Old Aug 24th, 19, 4:36 AM Thread Starter
Håkan
Right now I will not change or regrind the the cam becuse cams are expensivie especialy here in sweden, and I don't belivie it will be all that bad. What kind of hp and torque numbers do you think it will make?
post #12 of 12 (permalink) Old Aug 24th, 19, 10:33 PM
JIM
The very first iteration of my 540 was very similar. 10.5 compression, out of the box Brodix 2Xtra's...but I had an older Team G intake (short one) with a 1050 Dominator...no spacer. My cam was a 262/273 on a 112 LSA. .731 lift. It made [email protected] 6400 or so. The Super Victor should help 20+ HP at least.
Those heads respond very well to some port work. The same basic engine made 870'[email protected] after becoming a 555" with another point of compression, ported heads, SV and a 268/272" cam. Still dyno'ing and racing on 93 octane pump gas.
All of this was with a belt driven water pump and no vacuum pump.
JIM
'67 Vette-555"/Gforce 5 Spd/Dana 60 IRS-3.07's
Best ET
Best MPH
200 MPH at TX Mile
"...when it's not pointing at a wall...grab a gear!"
*This Life Stuff ain't no dress rehearsal"
540Hotrod is offline
