best drag radial for a heavy 3700 pound chevelle - Chevelle Tech
 8Likes
post #1 of 21 (permalink) Old Aug 20th, 19, 6:27 PM Thread Starter
im looking at drag radials for my Chevelle and currently run a 28x10.5 stiff wall slick.I run right at 6.4s in the 1/8th with my car.It weighs 3700 with me in it.The car is a bbc with turbo at 9psi.The engine is a stock 1974 bbc with a summit 500 lift cam on a 114 center.The trans is a th400 with brake and ptc converter that stalls at 3700rpm with ford 9 inch 35spline and 3.50 gear.Im looking at drag radials and was wanting opinions on the best drag radial for a car like mine.I also run the moroso trick front and rear springs with 90/10s and racing rear shock and bmr anti rollbar.Would love to hear opinions on your favorite drag radial and what you feel works the best.Also is ther any that can take the place of my current slicks as far as times ..thanks in advance
joes69 is offline
post #2 of 21 (permalink) Old Aug 20th, 19, 9:30 PM
George
Re: best drag radial for a heavy 3700 pound chevelle
MT Pro Bracket Radials....they hook with very little burnout.
Jeff65SS and rel3rd like this.
'71 Malibu
355 [email protected]
125 [email protected]
100 shot [email protected]
Geo71 is online now
post #3 of 21 (permalink) Old Aug 21st, 19, 8:33 AM
Justin
Bracket radial i hear is good. I loved the 275 pro radial tho. But may want a real shock instead of 90/10ís to really take advantage of that combo
1989 Iroc-Z Camaro
Dart SHP 401" Twin Turbo
8.24 at 169 street car
Orr89rocz is offline
post #4 of 21 (permalink) Old Aug 21st, 19, 9:34 AM
I made the leap last year, ran a 28x9 MT stiff wall for 30yrs. I ran consistent mid 1.40 60`s and the car was not pleasant on the big end.
The first pass with a 28x9 MT PBR the car went 1.35 60 and was much better on the big end. I have double adjustables on both ends and did need to change the shock settings quite a bit when going to the radial. What is the "best" that is a matter of opinion but I will say there are a lot of good options and you will need to tune the suspension to whatever tire you decide on.
Kirk's67SS and rel3rd like this.
66 chevelle
New Combo
555
10.2 comp
Straub ProMaxx heads
Straub solid roller
TH400/373
3815lbs
1.31 60'
[email protected]
[email protected]
B433 is offline
post #5 of 21 (permalink) Old Aug 21st, 19, 1:06 PM
Greg
^^^This!!
Greg C.
1969 Chevelle Malibu
New, waaaay overcammed 496 "The Dud"
[email protected]
Iforgot is offline
post #6 of 21 (permalink) Old Aug 23rd, 19, 9:14 PM
hopefully you can see the picture. these are my 28x10.5 Pro Bracket Radials. over 100 passes, cords showing, went 1.31 sixty foot and 8.54 at 161mph. it's the best radial i've used so far.
low number of passes is due to my propensity for doing excessively long burnouts.
69 Malibu, Stokerboats and dell72 like this.
1967 Chevelle Malibu 4 door
The 7.99 at 173mph pass:
8.02 at 171mph:
Calculated Risk is offline
post #7 of 21 (permalink) Old Aug 23rd, 19, 10:05 PM
Greg
And my 29.5/10.5 PBRs are well over 200 passes old!!
I’m getting a little worried now lol
Greg C.
[email protected]
Iforgot is offline
post #8 of 21 (permalink) Old Aug 24th, 19, 1:08 AM
M/T 3355 on my '66. Best was a 1.301 60' with a 3.73 gear.
If they chatter they can break stuff. Ask my gopro mount.
By comparison I've run 1.306 with the 3055s slick and a 4.11gear.
'66 SS Chevelle
bored small big block
performance to be determined.
91 octane special.
Stokerboats is offline
post #9 of 21 (permalink) Old Aug 29th, 19, 5:23 PM Thread Starter
very nice..Thanks everyone I really appreciate all the comments
joes69 is offline
post #10 of 21 (permalink) Old Sep 5th, 19, 9:49 AM
Beth
I have a manual trans ; a stock LS1 T56 from a 2000 Camaro and the two drag radials I'm looking at are what Dan recommends, the 10.5" wide M/T 3355 or the 9" wide M/T 3354, which is identical only narrower.
I am afraid of "hooking too well" and damaging the trans. The rear is bulletproof (Strange S60).
Should I stay away from the 10.5" wide slick ? The clutch is a single disc diaphragm centerforce type, so it should not be "too grabby."
The engine is a small-cammed (224/234) wolfie 489. Probably 525 hp.
https://www.jegs.com/i/Mickey-Thomps...3355R/10002/-1
https://www.jegs.com/i/Mickey-Thomps...3354R/10002/-1
nashville beth is offline
post #11 of 21 (permalink) Old Sep 5th, 19, 10:32 AM
I still think for a stick car, I would stay with a bias ply tire. They are more forgiving and will not chatter. they will spin and recover.
bracketchev1221 is offline
post #12 of 21 (permalink) Old Sep 5th, 19, 12:27 PM
There are a couple different ways to make a stick compatible with a radial, they involve softening the hit of the clutch and letting the radials dead hook. When the tire dead hooks there won't be much difference between the two tires mentioned, you will be able to make the choice based on aesthetics.
Grant
Grant
website-
We make your non-adjustable clutch...ADJUSTABLE!
sr530 is offline
post #13 of 21 (permalink) Old Sep 5th, 19, 12:31 PM
Beth
Grant
I am installing a clutch tamer.
Is that what you are referring to ?
post #14 of 21 (permalink) Old Sep 5th, 19, 1:15 PM
I think I'd go with a bias ply on a stick car. Only thing you might sacrifice might be some slight mph.
'66 SS Chevelle
91 octane special.
post #15 of 21 (permalink) Old Sep 5th, 19, 4:15 PM
If you are installing a 'tamer, either one of the radials will work.
Grant
Grant
website-
sr530 is offline
