best drag radial for a heavy 3700 pound chevelle - Page 2 - Chevelle Tech
 8Likes
post #16 of 21 (permalink) Old Sep 5th, 19, 5:27 PM
Scott Foxwell
Re: best drag radial for a heavy 3700 pound chevelle
Donnie Edmonds runs a 29.5x10.5x15 Pro Bracket Radial on his 3700# Chevelle. He's been [email protected] 118 1/8th, 9.18 @ 146 in the 1/4 with a best of 1.292 60', naturally aspirated.
FOXWELL MOTORSPORTS
Straub Technologies
steelcomp is online now
post #17 of 21 (permalink) Old Sep 5th, 19, 5:44 PM
Greg
On a normal stick car, probably would stay with a bias ply if you are worried about the transmission. At least on my junk, if the PBRs spin and then grab it'll rattle the fillings out of your teeth! Feels a lot like tire shake on a big tire car. The handful of times my PBRs spun and grabbed or 'chattered' I was positive that the ring and pinion, planetaries, driveshaft, or something was going to explode..
Greg C.
1969 Chevelle Malibu
New, waaaay overcammed 496 "The Dud"
[email protected]
Iforgot is offline
post #18 of 21 (permalink) Old Sep 5th, 19, 6:35 PM
Beth
Originally Posted by sr530 View Post
If you are installing a 'tamer, either one of the radials will work.
Grant
I'm definitely leaning towards the 9" wide.
nashville beth is offline
post #19 of 21 (permalink) Old Sep 5th, 19, 10:27 PM
George
Originally Posted by nashville beth View Post
I have a manual trans ; a stock LS1 T56 from a 2000 Camaro and the two drag radials I'm looking at are what Dan recommends, the 10.5" wide M/T 3355 or the 9" wide M/T 3354, which is identical only narrower.
I am afraid of "hooking too well" and damaging the trans. The rear is bulletproof (Strange S60).
Should I stay away from the 10.5" wide slick ? The clutch is a single disc diaphragm centerforce type, so it should not be "too grabby."
The engine is a small-cammed (224/234) wolfie 489. Probably 525 hp.
https://www.jegs.com/i/Mickey-Thomps...3355R/10002/-1
https://www.jegs.com/i/Mickey-Thomps...3354R/10002/-1
Alot of the racers around here with sticks like the Hoosier QTPs. Seem to work well.
'71 Malibu
355 [email protected]
125 [email protected]
383 Mud Motor- [email protected]
100 shot [email protected]
Geo71 is offline
post #20 of 21 (permalink) Old Sep 6th, 19, 11:56 AM
Todd
I've gone 1.27 5.55 130 on a 275 pro at 3475 lbs with me. trying the 28x10.5 pro bracket tomorrow if the rain stays away
oliver69 likes this.
13.5-1 572, HP innovations 1150, 1.8 glide, 3.70 gear, Nitrous outlet hornet
Best 1/8 ET 5.55
Best 1/8 MPH 130
Best 60 1.27
8.93 147mph
69 Malibu is offline
post #21 of 21 (permalink) Old Sep 6th, 19, 7:37 PM
Beth
I would like to go with a radial, but from everything I've read, the bias-ply slick is what I need for a manual trans.
Since I have 4 wheel disc brakes, I'm stuck with a 17" rim but I see Hoosier makes a 17" slick 28 X 9 or 10.
