Donnie Edmond's 3700# 69' all motor.... - Page 2 - Chevelle Tech
 62Likes
post #16 of 32 (permalink) Old Aug 3rd, 19, 1:09 AM
Durand
Re: Donnie Edmond's 3700# 69' all motor....
What does he run for rear tire size and gear ratio?
LaVelle is offline
post #17 of 32 (permalink) Old Aug 3rd, 19, 7:15 AM
Gavin
I watched this run on Facebook yesterday, very impressive. A full bodied/full weight Chevelle capable of running high 8s N/A is just mind blowing. Great work, guys! Congrats, Donnie!
steelcomp likes this.
My father tells me I was born 30 years too late.
Ghaasl is online now
post #18 of 32 (permalink) Old Aug 3rd, 19, 8:51 PM
Sounds incredible. Beautiful car.
1775SS is online now
post #19 of 32 (permalink) Old Aug 4th, 19, 10:40 AM
Nice car. Reminds me of Rocky's blue 69 street car that ran at cayuga back 10 years ago. It ran 8.70 with the 498.
RickyHill is offline
post #20 of 32 (permalink) Old Aug 4th, 19, 9:19 PM
Dang! that mill sounds GLORIOUS!
post #21 of 32 (permalink) Old Aug 5th, 19, 11:29 PM
Congrats on a cool build
1967 Chevelle 496BB/TH400/Strange S-60 (Show and Go)
1967 El Camino 388SB/700R4/12-bolt posi (Rat Muscle Parts Hauler)
2015 Harley Davidson Road Glide Special (Cruiser)
2007 Harley Davidson Road King Custom (Bar Hopper)
2018 Chevy Silverado LTZ Duramax (Daily Driver)
My Chevelle:
C & D Performance
North Texas Chevelles
Motorhead62 is offline
post #22 of 32 (permalink) Old Aug 6th, 19, 1:43 AM
While we're waiting for the tire size, and gear ratio that Durand asked about above, how is the rear suspension setup?
Mike Lewis street 572
Cale Aronson
Black Magic clutches
Cam by UDHarold
Menscer Motorsports
TRZ
CEAutoelectric
aukai is offline
post #23 of 32 (permalink) Old Aug 6th, 19, 9:05 AM
Scott Foxwell
Here's a complete run down of the car from Donnie's FB page. Go to the right of the page and click on "Our Story"
https://www.facebook.com/DSmotorspor...29243&fref=tag
FOXWELL MOTORSPORTS
steelcomp is offline
post #24 of 32 (permalink) Old Aug 6th, 19, 11:20 AM Thread Starter
Here you go sir:
Welcome to D&S Motorsport. The Home of Big Bertha, our 1969 Chevelle SS 396. She is a very solid all original panel car. She has had only 1 repaint in Dark Red Mica. She has a Extreme Automatics turbo 400 trans prepared by Lonnie Diers with a Griner Billet Pro Tree trans brake, and lots of Coan and EXA. billet aluminum goodies inside. An Ultimate Converter Concepts.llc 9 inch converter resides inside a full Reid Racing fully rollerized case that keeps everything from getting ugly just in case, and to keep NHRA happy.
Global West Drag Pack front suspension with a TRZ bump steer kit and TRZ Motorsports double adjustable upper and lower rear suspension, along with a TRZ anti roll bar, and a Chevy 12 bolt rear end full of Strange Engineering 35 spline Pro Race axles, Spool and c-clip eliminators with a Richmond 4.11 Pro Gear, and Strange Engineering disc brakes front and rear, Menscer Motorsports double adjustable shocks are on the front with GM conversion coil over front springs, and Afco Eliminator double adjustable shocks with QA1 variable rate springs on the rear.
The wheels are Sander Engineering. 15x8 with a 4 1/2" BS on the rear and 15x4 with a 1.7 BS on the front all wrapped in Mickey Thompson Tires 27.5x4x15 front and 29.5x10.5x15 Pro Bracket Radial slicks on the rear. The car has not been mini tubbed or cut in any way, other than the holes that had to be put in the floor for 10 point Moly cage install. No trimming. bending or cutting had to be done to fit the rear tires under the car.
The engine is a Naturally Aspirated Foxwell Motorsports 565 Inch BBC which consist of a Dart Big M block 4.600 bore. The heads are a custom set of AFR Magnums that have been worked over by Scott Foxwell. A Moroso enhanced 3 vane vacuum pump, Lemons Headers, coated by Power Shield Coatings feeding a Burns Stainless 4 exhaust with a custom built X-Pipe, and Flowmaster Top Ten race mufflers that dump at the rear axle. A Callies Dragon Slayer Crank 4.25 stoke, Oliver 6.385 Rods, Ross gas ported Pistons with 14.7 to 1 compression, Pro-Filer Sniper II Intake, a BRE 1250 CFM Dominator sitting on top of an HVH, Super Sucker 1 inch spacer. Harland Sharpe shaft mounted 1.7 roller rockers, The cam is a billet solid roller custom grind from Straub Technologies with a 7/4 swap riding on it are a set of Morel Black Momba roller lifters that activate a set Smith Bros. 7/16 push rods that open and shut REV 2.375/1.85 Titianium valves. All covered by a set of Biondo aluminum fabricated valve covers chromed by CRC. The engine makes around 1035 HP @ 7300 RPMs and 804 FPT @ 5600 RPMs, N/A. It has motivated Bertha down the 1320 @ 9.25 @ 144 MPH and 5.89 @ 117 in the 1/8. With a 1.32 60' Not too bad for 3700 lbs of steel.
427L88 and Pat_McNeil like this.
Chris Straub
Mfg Performance Parts
cstraub is offline
post #25 of 32 (permalink) Old Aug 6th, 19, 2:16 PM
Thank you guys, very impressive car
Cale Aronson
Cam by UDHarold
Menscer Motorsports
TRZ
CEAutoelectric
aukai is offline
post #26 of 32 (permalink) Old Aug 7th, 19, 1:14 AM
Another impressive Foxwell unit, great job as usual,,, ,
Beautiful ride too, love the no drama all business leave
Pat_McNeil and steelcomp like this.
Mike (Wolfplace)
VISIT US AT
----John Wayne----
Wolfplace is offline
post #27 of 32 (permalink) Old Aug 7th, 19, 8:12 AM
Once sorted this car i think this can run 8.60 or 8.70. There was a thread about a 900 horsepower chevelle on here a while back that ran about what this car ran but last i saw the owner past on rip. I put this through the calculator and it is only showing 851 horses at 3700 since he is not hitting it fully. Nice work to all involved.
RH
Pat_McNeil likes this.
post #28 of 32 (permalink) Old Aug 7th, 19, 1:11 PM
Test and Tuner
RH
You bet Ricky! The Crazy D Chevelle was a legit 8 second ride. Heck, even the 11 to 1 CR Foxy/Straubie top end BBC that won drag weekend a couple of years back (best ET of 8.96) ONLY dynoed at 881HP. Must be something going on with the water down in Tennessee!
mr 4 speed likes this.
'69 Chevelle 416" LSA TONY MAMO TFS Heads and custom Hyd roller cam.
Best 60' so far....1.34
Steve Sharp Turbo 400
Motivational Engineering 3.07 12 bolt rear.
Chris Alston's complete "Auto - Cross" coil-over suspension.
Pat_McNeil is offline
post #29 of 32 (permalink) Old Aug 7th, 19, 1:57 PM
Donnie's car rocks. Period. Outstanding results with even more to come.
mr 4 speed is offline
post #30 of 32 (permalink) Old Aug 23rd, 19, 8:57 AM
Scott Foxwell
Donnie gettin it done. Not even leaning on it yet.
427L88, Wolfplace and oliver69 like this.
FOXWELL MOTORSPORTS
