Holley Fuel Pump Gushing Fuel - Chevelle Tech
post #1 of 16 (permalink) Old Jul 20th, 19, 5:51 PM Thread Starter
blm
I have what is basically a brand new fuel pump. Has about 3 hours of run time on it. There is fuel gushing from the aft end of the cylindrical shaped boss that runs front to back and for lack of a better term is part of the top cap. Does this mean it has ruptured an internal diaphragm? It is the same model as in the link.
https://www.summitracing.com/oh/parts/hly-12-454-11
blm is offline
post #2 of 16 (permalink) Old Jul 20th, 19, 6:11 PM
Al
Re: Holley Fuel Pump Gushing Fuel
Sounds like a ruptured diaphragm. The fuel should never be on that side of the diaphragm.
You've had a run of bad luck lately.
DUTCH MAX HEADWORK is offline
post #3 of 16 (permalink) Old Jul 20th, 19, 6:17 PM
Gary
yep they go bad. no telling how long it has been on the shelf. it's a big reason I plan to put a late model fuel injection type pump in the tank of my car before i start driving it long distances. make sure you didn't add a bunch of gas to your crankcase after you change the pump
gnicholson is offline
post #4 of 16 (permalink) Old Jul 20th, 19, 6:30 PM Thread Starter
blm
I just changed the oil due to it being dilluted with gasoline from a messed up carburetor and had only run it less than two minutes when I noticed the fuel gushing from the fuel pump. Dont know how long it was spitting fuel out but dont believe it just started. Maybe both the carburetor and the pump were putting gasoline in the crankcase?
blm is offline
post #5 of 16 (permalink) Old Jul 20th, 19, 6:38 PM
Gary
quite possible
post #6 of 16 (permalink) Old Jul 20th, 19, 7:15 PM
Al
If the leak is big enough, the fuel will rise into the crank case. The area above the diaphragm is open to the crankcase.
post #7 of 16 (permalink) Old Jul 20th, 19, 7:26 PM
I have warrantied more than a dozen of those in the last year. They are junk. Return it and replace with a Carter. Holley must have their head up there azz with these right now.
82c10step is offline
post #8 of 16 (permalink) Old Jul 20th, 19, 9:10 PM Thread Starter
blm
Were they all returned for the same issue?
blm is offline
post #9 of 16 (permalink) Old Jul 20th, 19, 10:01 PM
Yes they all leak. Externally most of the time. Some internally. I had one guy put 3 on his street rod in the course of a month. We took one apart and the diaphragm was deformed and split. Put a Carter on and problem solved.
post #10 of 16 (permalink) Old Jul 20th, 19, 10:37 PM Thread Starter
blm
Based on your recommendation I have ordered a Carter M4889 which I should receive Monday. Will take my chances with returning the Holley pump to the engine builder. It has less than 3 hours on it and under 50 miles. What a shame that their products have deteriorated. Thing is the fuel pump is only about 3 inches from the header tube on the number 2 cylinder and when I noticed the fuel gushing it was soaking the header tube. Very strong chance for a fire.
blm is offline
post #11 of 16 (permalink) Old Jul 21st, 19, 1:13 AM
I've replaced every one of them with a Carter. These are guys I see at the car shows every month. Zero problems with the Carter's. I don't know why Holley has not done anything about it. The first one I returned was over a year ago.
post #12 of 16 (permalink) Old Jul 21st, 19, 2:58 PM
A few years ago coming home to Pittsburgh from the Chevelabration. Mark ( 65 Chevelle S.B. Mt. Pleasant,Pa) . Driving on the I-State his " Super Duper Chrome Plate High Dollar fuel pump ". Took a crap!
I stay with the cars, Mark and a friend get a STOCK CHEVY fuel pump from a local parts store. That was 6-8 years ago. That ugly, NON Chrome plated off the shelf fuel pump is still on the car.
Years ago, Remember the old saying, " If it dont go,,, Chrome it. " !
Robinls5 is offline
post #13 of 16 (permalink) Old Jul 22nd, 19, 9:19 PM
yep, those used to good pumps and you could get a rebuild kit for them. too bad, so sad. same as all the rest of the china sourced ****.
post #14 of 16 (permalink) Old Jul 22nd, 19, 9:19 PM
82c10step, are you a vendor or a shop?
post #15 of 16 (permalink) Old Jul 23rd, 19, 8:09 AM
I think this guy has or can make rebuild kits for any pump.
781-335-8860
mrpaticular is online now
