Thinking of going from MSD to HEi - Chevelle Tech
 15Likes
post #1 of 45 (permalink) Old Jul 5th, 19, 4:48 PM Thread Starter
Anyone done it? Only reason I used this was concern over fouling plugs due to a lot of overlap.
383 [email protected] SR cam, gears stick etc.
Experiences?? Dont need a rev limiter my ear works fine. In fact removing the tach also.
cuisinartvette is offline
post #2 of 45 (permalink) Old Jul 5th, 19, 7:28 PM
Re: Thinking of going from MSD to HEi
After my last MSD box failed, I put the HEI back the way it was. I have not had any issues since. My cam has 65° of overlap (282° intake duration, 288° exhaust duration) and I have not had any issues with fouling since I made the change. I think you will be fine.
My Chevelle w/ open headers:
WakkoWarner is online now
post #3 of 45 (permalink) Old Jul 5th, 19, 7:59 PM
Al
The HEI puts out a strong spark and I have run them to 7000 rpm with no issues. It's one of the best ignition systems out there. Some people say they won't pull the rpms I'm running, we'll they can come for a ride in my heap and I'll show them. YMMV. I would go with the GM Performance if I were to go buy another one. I'm pretty sure it's chinese made, but they got it right on this one.
https://smile.amazon.com/ACDelco-934...s%2C231&sr=8-3
post #4 of 45 (permalink) Old Jul 5th, 19, 9:36 PM
I took my MSD off this go round and just went with a std HEI. No issues, no regrets.
68SuperSport* is offline
post #5 of 45 (permalink) Old Jul 5th, 19, 9:45 PM
My msd is 8 years old or so now. Still works great!
Tarheel Chevelle likes this.
tacomatrd is offline
post #6 of 45 (permalink) Old Jul 6th, 19, 6:29 PM
Smile Re: Thinking of going from MSD to HEi
Bought our 1st MSD-6 box in 1980. Lots of folks bought one just for MPG.
39 years & 30+ MSD boxes/distributors/coils & 20+ sets of plug wires,
never an issue has arisen...not one.
71350SS likes this.
Tarheel Chevelle is offline
post #7 of 45 (permalink) Old Jul 6th, 19, 6:33 PM
Claude
My car has an MSD 6AL box, MSD "Blaster" coil and MSD distributor and I never had any problem with it. (everything was on the car when I bought it)
Claude.
boyd66k20 and p40 like this.
1971 Chevelle SS
toofastforyou is offline
post #8 of 45 (permalink) Old Jul 6th, 19, 9:36 PM
only problem i have had is the blaster coil leaking oil.
72 chevelle ss 454
chopperb is offline
post #9 of 45 (permalink) Old Jul 7th, 19, 10:54 AM
There are known issues with the coils but someone on here has posted recommendations for quality coils that can be used in place of the Blaster. Might have been Dave Ray or maybe some with a screen name of "Ignition Man". Not sure of the names but I know a replacement, including I think a NAPA part number, for the Blaster was mentioned. Early Blasters are supposed to be OK...something about Federal regulations concerning what is inside the coil to help keep it cool. New coils are built differently and overheat then fail if memory serves well.
I have a vintage 1990's 6AL and MSD billet along with an O-L-D Blaster. It never has missed a beat. Cannot comment on improvements in ET and top speed cause I have no inclination to race the car. I will say that the car starts very easily and warmed up easier with the MSD than with a stock ignition. When I lived in New England I could start the car when the temps were 10 to 20 degrees (F) and just run back from the garage into the house while the car warmed up.
oman is offline
post #10 of 45 (permalink) Old Jul 7th, 19, 12:17 PM
Personally I see no reason to run a box on the street, a simple HEI works fine.
Pete 67 likes this.
oldcutlass is offline
post #11 of 45 (permalink) Old Jul 8th, 19, 2:55 AM
just do it.
Best deal in rodding:
https://www.summitracing.com/parts/ado-93440806
Jeff65SS and davewho1 like this.
post #12 of 45 (permalink) Old Jul 8th, 19, 6:28 AM
Vince
I removed an entire msd setup - box and billet hei and installed the distrib That Tom linked. Didn’t notice even a HAIR of difference anywhere. Save your money
*69 SS 502 EFI /224* HR/9.8:1/T56/3.90/ 4000lbs RW 11.5/124mph
*11 C6, 6.2, 6spd
*96 Stang 6.0 turbo 10.5/135mph
*2011 Mustang GT premium
*61" Scag Kohler 22hp 7mph
69-CHVL is offline
post #13 of 45 (permalink) Old Jul 8th, 19, 7:09 AM
Years ago my MSD quit in my 64 Pontiac right before a car cruise, so I put the stock single points distributor and coil back in, wired it up to the factory resister wire, set the timing and left. I noticed how much faster it started and it was running better with a heavier exhaust note. I never replaced that MSD and just ran the stock points distributor after that and never had any issues..
jeff swisher likes this.
hydro462 is offline
post #14 of 45 (permalink) Old Jul 8th, 19, 11:27 AM
Harry
I have the MSD Digital 6 plus on my Chevelle with an HEI MSD distributer (coil in cap). I keep the HEI insert module for the distributer in my trunk to quickly convert back to HEI if the MSD Digital 6 plus fails. The MSD digital 6 plus has failed on me a couple of times through the last 10 years or so, but, I keep going back to it from the HEI because of the multiple spark. Bottom-line, I can just get my big cam Chevelle to run cleaner and more efficient with the MSD digital 6. The box just gives you that extra energy to really clean up your idle and low load conditions.
Bottom line for me, the MSD Digital 6 plus is not very realiable, but, has a great multi-spark that I really like. The HEI is very, very reliable, but, I miss the multi-spark with my big cam.
Harry
hjdca is offline
post #15 of 45 (permalink) Old Jul 8th, 19, 12:41 PM
Pat
I run a Chevrolet Performance HEI and have never had an issue. I have thought about going to the MSD setup but for now going with the "if it ain't broke don't fix it" philosophy, which I rarely utilize, I love buying new stuff
MSD quality now a days seems to be hit and miss. Some have no issues others have nothing but headaches. Good ole HEI seems pretty solid.
Pats70ss is offline
