Trick Flow Oil Can - Chevelle Tech
 53Likes
post #1 of 54 (permalink) Old Jul 2nd, 19, 5:01 PM Thread Starter
Guy
Trick Flow Oil Can
I just plumbed this in with my ME Wagner Dual Flow adjustable PCV valve.
It's been sitting collecting dust for a year or more,so today was the day to get this project off of the old "To Do" list,lol
I didn't have the proper fittings but I made do.
I gutted an old PCV valve for the top "out" hose to the back of the carb.
For the bottom I put a 5/8 hose on the 8 an fitting and put the 3/8 hose from the PCV valve inside the 5/8 hose.
Might not be the correct way to do it,but hopefully it will work until I can get the proper fittings.
Other than starting it to make sure that it still runs I haven't gone for a trial drive yet,but that will be soon.
Guy
ID:	597300   Click image for larger version
ID:	597302   Click image for larger version
'86 Monte SS,
513 Stroker,
AFR CNC'd 315 heads,
Isky .904 EZX Roll lifters,
9 inch rearend,
TC Member # 4921
GuysMonteSS is offline
post #2 of 54 (permalink) Old Jul 2nd, 19, 7:41 PM
Re: Trick Flow Oil Can
I'm unfamiliar - what does it do?
David
davewho1 is offline
post #3 of 54 (permalink) Old Jul 2nd, 19, 10:54 PM
I have one with a catch can as well. Heres what it does. A tad pricey but at least you can set at idle and cruise and verify it. The others are just a guess with the springs.
Dual Flow Adjustable PCV Valve ? M/E Wagner Performance Products
davewho1 and paul bell like this.
USN-SSBN 645-G
boyd66k20 is offline
post #4 of 54 (permalink) Old Jul 3rd, 19, 6:33 AM Thread Starter
Guy
I copied this from a Google search on oil can;
"The idea of an oil and air separator is to extract the oil from the air before it's sent back to the intake manifold and put it someplace where it won't cause a problem, either back in the crankcase or in a small receptacle called a catch can"
I found out about the Wagner adjustable PCV valve on here and it sounded like a good idea.
Once you get it dialed in as per the instructions they work great.
And the instructions are easy to follow and well written.
I'll be going on a four hour + trip on Sunday and will give an update then.
Guy
David Bates, davewho1 and hydro462 like this.
'86 Monte SS,
513 Stroker,
9 inch rearend,
TC Member # 4921
post #5 of 54 (permalink) Old Jul 3rd, 19, 11:09 PM
Wouldn't it be simpler, easier, cheaper, and require less maintenance/attention to just baffle the PCV fumes so the oil doesn't get pulled through the PCV valve to begin with?
You know...like billions of OEM valve covers are built.
Your solution would NOT be my first choice.
Schurkey is offline
post #6 of 54 (permalink) Old Jul 4th, 19, 12:15 AM
Trying to keep "contaminated" air out of the intake, would be my guess.
Mike Lewis street 572
Cale Aronson
Black Magic clutches
Cam by UDHarold
Menscer Motorsports
TRZ
CEAutoelectric
aukai is offline
post #7 of 54 (permalink) Old Jul 4th, 19, 1:07 AM
Thanks for the explanations, gents.
David
davewho1 is offline
post #8 of 54 (permalink) Old Jul 4th, 19, 6:22 AM Thread Starter
Guy
Yep,you hit the nail right on the head Mike !!!
Guy
'86 Monte SS,
513 Stroker,
9 inch rearend,
TC Member # 4921
post #9 of 54 (permalink) Old Jul 4th, 19, 7:36 AM
Here's what a OEM baffled CTSV valve covered engine with a catch can.
Had one on the ol 406 (actually still on it in my sons 67 C10)and will have one with the new TT 441 sbc.
GuysMonteSS and boyd66k20 like this.
WHT/73 is offline
post #10 of 54 (permalink) Old Jul 4th, 19, 9:32 AM
Seems like when you see whats in the can, it sells itself, (the catch can).
The pcv valve is a great idea. Adjustable to a couple of situations and accurate above all else. How do you know the others are accurate?
Seems I have a few inches of crap oil in the catch can at the end of the season., with just street use.
WHT/73 and GuysMonteSS like this.
USN-SSBN 645-G
post #11 of 54 (permalink) Old Jul 4th, 19, 1:06 PM
I think that a great idea, I put one on my wife's 2011 Silverado that was sucking oil into the intake. Stopped the oil problem completely, I just drain the tank when I change oil. Truck runs better also.
WHT/73, GuysMonteSS and rel3rd like this.
68Chevele is offline
post #12 of 54 (permalink) Old Jul 8th, 19, 12:29 PM Thread Starter
Guy
Just wanted to update this thread.
So far I've put about 5-6 hours driving time in since I put the oil can on.
Even though there was nothing showing in the sight glass I drained it just to see how much came out,and there wasn't very much,a couple of drops at the most.
There would be more on the bottom that wont drain as the drain pipe sits off of the bottom of the can a little bit.
So it definitely works like its supposed and helps keep unwanted oil out of the intake.
Guy
aukai and rel3rd like this.
'86 Monte SS,
513 Stroker,
9 inch rearend,
TC Member # 4921
post #13 of 54 (permalink) Old Jul 8th, 19, 6:55 PM
TKG
Terry
I had something similar on a work truck. After 3K mi there was about a cup of whatever in it. About 1/2 oil and 1/2 something else. The deal was it wasn't in the engine. I don't know if the engine heat would have burned off the stuff or not.
GuysMonteSS likes this.
TKG
64 Malibu Coupe
283, Fitech
2004r, 4w discs
TKG is offline
post #14 of 54 (permalink) Old Jul 8th, 19, 8:46 PM
Kim
I have a pair of Moroso cans on my CTSV with about 16.5 lbs of boost which work like a charm keeping oil out of the intake path.. I also have one on my '17 Raptor which is running a bit more boost than stock and it will accumulate a half cup of oil in about 2000 miles. I've never used one on a N/A engine, although it makes sense if you're running a rowdy setup.
shelteredv is offline
post #15 of 54 (permalink) Old Aug 13th, 19, 9:27 PM
Guy
Five or six hours of running, and you prevented "a couple of drops at the most" of "contamination" from getting into the intake manifold.
Seems like a total waste of time, money, effort, and enthusiasm to me.
Again, billions of vehicles do just fine with the "contamination" in the manifold. It's not like you're going to cook food inside the thing.
There is some small percentage of worn-out junk that genuinely has too much blowby--but stuffing a catch-can under the hood of one of them is not an appropriate fix for a totaled engine.
Schurkey is offline
