Morel lifter and Straub HR cam update with dyno numbers - Chevelle Tech
 3Likes
  • 3 Post By 72BB Nova
post #1 of 4 (permalink) Old Jun 29th, 19, 4:26 AM Thread Starter
Last summer I had to do a cam and lifter swap in my 75 C20 454. Cam specs are 210/[email protected] .553in .481ex lift on a 109 lobe separation. The morel lifters are the Street Performance part #5374. I've put over 3200 miles on it since the change and everything is working great. I had noise at first but they did quiet down. There was a point when I had between 1000-1500 miles on it that they would for no apparent reason just start making noise, confusing AND frustrating. The more miles I put on it the less that happened. Now on a rare occasion I will here a click or two and then nothing.
With the cam I also upgraded the intake to the Chevy version of the Performer RPM Qjet, "identical" and went from a 750 qjet to a Sean Murphy 800 qjet.
Dyno numbers, flash back to July 2017. I did a base line to see what I had. The truck had 53,000 miles on it. Everything was stock except a small ignition upgrade, better coil and module in stock HEI distributor, flat cast iron intake, 750 qjet, cast iron exhaust manifolds into 2" dual exhaust no cats generic turbo mufflers, stock exit behind rear tires. HP was [email protected] and torque was [email protected], not impressive.
Upgrades are, cam and lifters, intake, carb, and 1-3/4" full length tube headers into 2-1/2" exhaust with X pipe, Dyna Max Ultra Flow mufflers and exiting behind rear tires. HP was [email protected] and torque was [email protected] I was very pleased with a 40HP gain but a little disappointed in the torque numbers. The guy that ran it was very impressed with just doing some basic bolt on parts. Mileage also increased, before I was getting 8-9 city/hwy I checked it a couple weeks ago and got 11.6 city/hwy, double digit gas mileage .
The heads are 781's and I pretty sure they've never been off. Not huge numbers but nice gains for a little work.
von, mr 4 speed and 71454Chevelle like this.
1972 Nova
496/T56 Magnum/3.73
1964 Corvair Spyder coupe
1975 C20 Camper Special 454/TH400
72BB Nova is offline
post #2 of 4 (permalink) Old Jun 29th, 19, 6:58 AM
Re: Morel lifter and Straub HR cam update with dyno numbers
A lot of things changed at one time but a gain is a gain!
Especially gaining from 8/9 mpg to 11.6!!
That's always nice!
WHT/73 is offline
post #3 of 4 (permalink) Old Jul 2nd, 19, 7:49 PM
andy
Well that is something like a 25% increase in power, nothing to sneeze at!
66360horse is offline
post #4 of 4 (permalink) Old Jul 2nd, 19, 10:58 PM
Those lifters are not the noisy ones as the 5374 are made by Eaton to Morel's specs. Very nice results and gains..
Website is up and running
Machine shop tour
Monthly Specials
CNC BLOCKS N/E is offline
