Big Block Brainstorming - Chevelle Tech
 2Likes
  • 2 Post By cstraub
post #1 of 11 (permalink) Old Jun 18th, 19, 1:37 PM Thread Starter
Tyler
I have a 454 that I pulled out of my 70 Chevelle and I've be considering swapping it into a 94 mustang v6 i planned to flip to make it a drag car. Id make my chevelle more street oriented and probably swap in a tko600 to use the th400 i built for mustang. As far as im concerned this motor should be pretty fresh with potentially a forged rotating assembly... I'd verify all of this first but it did run a 12.77 in the 70 chevelle with a small hyd roller, 063 heads, edelbrock performer rpm air gap, 650 cfm double pumper and the th400 with a very tight 2000ish converter. Would anyone have a solid roller cam recommendation for this motor? I'm wondering if i could get enough out of this set up with just a cam or maybe piston swap also to increase the compression. Since the mustang is close to 1000lbs lighter I think it could make a pretty fun track car. Thanks for the input.
1970 Chevelle 461" BBC
Lunati Hyd Roller Cam/781 heads
3800 FTI converter, TH400, 12 bolt 3.73
Stock suspension
Old 454 PR (no passes on new motor yet)
1.717 60', 12.773 @ 101.86 MPH
tgmperformance is online now
post #2 of 11 (permalink) Old Jun 18th, 19, 3:45 PM
Re: Big Block Brainstorming
Drag cars are hard to sell. I hope you don't have much money in the Mustang and the 454.
69SS454 is offline
post #3 of 11 (permalink) Old Jun 18th, 19, 6:00 PM
I thought about doing the same thing with some extra 454's I have but I was going to use a 99-03 Mustang. Sure as hell am not going to use a 4th gen Camaro for this as it's a nightmare to get stuff to work in those old Camaro's and the rear end is made of glass. The only drawback would be making some headers so I guess the tig welder will need to be used for that along with a good turbo 400.
68Chevele is offline
post #4 of 11 (permalink) Old Jun 18th, 19, 9:39 PM Thread Starter
Tyler
My bad, if I make it a drag car id keep it for myself
Stock suspension
post #5 of 11 (permalink) Old Jun 18th, 19, 9:40 PM Thread Starter
Tyler
Yeah thatís exactly what I want to take the 400 out of the chevelle because I just built it and itís got a new FTI converter
Stock suspension
post #6 of 11 (permalink) Old Jun 18th, 19, 10:20 PM
I donít know about where you live, but around here, SF Bay Area, with a little patience and some effort you can find a competitive turn key 10 second bracket car for $10,000-15,000, considerably less you you are looking for grudge night or T&T bomber. It doesnít make sense to build something from scratch unless you have a sentimental attachment.
Steve R
Steve R is offline
post #7 of 11 (permalink) Old Jun 20th, 19, 7:35 AM
850 Carb
victor Intake
get compression to at least 12.5 to 1
Solid roller camshaft and lifters
With the untouched 063 should be able to get very close to 600HP and 560#ft. In the stang that should put you in the 10's with some suspension mods.
Chris Straub
Mfg Performance Parts
cstraub is offline
post #8 of 11 (permalink) Old Jun 20th, 19, 9:39 AM
Why doesn't the OP just build a streetable 454/468 with 550-600 HP, rebuild the TH400 to handle the power, and go with 3.31 gears....IN THE CHEVELLE?
That's a high ten/low eleven second car that could be driven to the track....with mild manners.
blue_69_malibu is offline
post #9 of 11 (permalink) Old Jun 23rd, 19, 1:14 PM Thread Starter
Tyler
my chevelle just got a new 461 and the th400 im speaking of is also a fresh build and the car already has 3.73 gears... the motor im talking about is what i took out for the new motor
Stock suspension
post #10 of 11 (permalink) Old Jun 23rd, 19, 1:14 PM Thread Starter
Tyler
Originally Posted by cstraub View Post
850 Carb
victor Intake
what would you recommend to touch 9s? probably different heads
Stock suspension
post #11 of 11 (permalink) Old Jun 23rd, 19, 4:53 PM
Buddies 468 peanut port engine touched 567hp this weekend, I would rock that all day in a new edge mustang pulling 10 sec. times.
This Thread is more than 410 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
