New heads and intake, now engine bog off the line - Page 3 - Chevelle Tech
 17Likes
post #31 of 45 (permalink) Old Jul 4th, 19, 1:02 PM
Re: New heads and intake, now engine bog off the line
Originally Posted by hjdca View Post
Here is a pic of my 15 year old un-modified Holley 750 Double pumper zinc body (116-112). I broke the ear off tightening it, so, it is garbage now. You can see the big hole in the middle with the air channels. This is the perfect size for the idle-ease. This is an unmodified throttle body. If you buy a new aluminum 116-112, it will look exactly the same, except the hole will be half the size or smaller, which gives you less tuning ability. Fortunately, the air channels are the same size, so, you can just drill out the hole to the same size as the old zinc baseplates. This is what I did, and I ended up using the "whole hole" for the best tuning of my cam - idle-ease turned counterclockwise all the way.
I have fixed 2 of those broken baseplates. I drill holes where it's cracked and add small pins for both sides then I JB weld them together. I bolt it to an old intake manifold so it stays flat. Both Holley's are still going strong today.
68Chevele is offline
post #32 of 45 (permalink) Old Jul 5th, 19, 12:20 PM
Harry
Great idea. Mine looked like it had some internal "gaps" where it broke. I am using it for parts now. I also stripped the threads for the bowl screw on a zinc HP body. I like the new aluminum parts better, I think they are stronger and much lighter and less chance of breakage and screw stripping. Since I changed to the Aluminum ultra XP body and aluminum base plate, my carb. is a lot lighter than the old zinc stuff.
Note: That hard core grey coating on the aluminum ultra XP bodies is also really nice. Very smooth and I would not be surprised if it helps with carb. cooling.
Harry
hjdca is offline
post #33 of 45 (permalink) Old Jul 5th, 19, 6:37 PM
To fix that main body mix up some JB Weld and put some in the hole, take the bowl screw and put teflon tape on it, screw it in the hole and wait until its semi hard unscrew the bolt and let it sit 24 hours and it should hold great. I tried to fix one with the helicoil and it worked like crap now I just use some kind of epoxy.
post #34 of 45 (permalink) Old Jul 16th, 19, 8:44 AM
I am currently running a Holley 670 SA vac. secondaries. I have Holley 770 SA vac. secondaries which I took off because I thought it might be over carbed causing the off idle stumble. I haven't had much time to play with it lately though. I do need to get it dialed in over the next four weekends before the big Dream Cruise here in Michigan.
68elky396 is offline
post #35 of 45 (permalink) Old Jul 17th, 19, 8:14 AM
Either carb on a 396 should work fine. Just need some carb and ignition tuning.
mrpaticular is offline
post #36 of 45 (permalink) Old Jul 17th, 19, 8:40 AM
Thanks mrpaticular, I appreciate your advice. I will try to tune it this weekend starting with timing. The 670 SA is performing well except for the off idle bogg. I will give an update with my results sometime this weekend. Here are a couple of photos of my '68.
ID:	598492   Click image for larger version
guitargeak99 and MNmalibu like this.
post #37 of 45 (permalink) Old Jul 25th, 19, 5:44 PM Thread Starter
Just wanted to update the guys that reached out to help me. I replaced my carter afb with a quickfuel 670 brawler and the bog I was experiencing when stomping the gas wide open is now gone. The new carb has vacuum secondaries and seems to run great right out of the box. I'd like to get it on a chassis dyno and a/f sensor to see if the jetting can be optimized but I am very happy with the way its running right now. Would be nice to make a few runs at the dragstrip also. Best run with the old 350 in it was 15.07 @ 93.7, hoping it would be in the 13's now. Thanks to everyone who helped me out and gave me advice much appreciated. I don't believe the problem was the air gap intake. I think I just opened up the engine with the heads and intake and the little carter didn't have enough accelerator pump shot.
ID:	599042   Click image for larger version
ID:	599044   Click image for larger version
guitargeak99 and 68Chevele like this.
MNmalibu is offline
post #38 of 45 (permalink) Old Jul 27th, 19, 7:46 PM
Glad to hear someone got a Quick Fuel VS to work. Looks nice, let us know how the adjustable sec. screw works to dial it in.
post #39 of 45 (permalink) Old Jul 27th, 19, 9:08 PM
Thanks for the update.
Mike Lewis street 572
Cale Aronson
Black Magic clutches
Cam by UDHarold
Menscer Motorsports
TRZ
CEAutoelectric
aukai is offline
post #40 of 45 (permalink) Old Jul 29th, 19, 1:42 PM
Louis
Glad to see your 400 is running good with the new vacuum secondary Carb.
Louis
Original owner
lg1969 is offline
post #41 of 45 (permalink) Old Aug 2nd, 19, 7:27 AM Thread Starter
15mph rolling start, no bog, block long one wheel wonder burnout.
Time for a posi upgrade
Name:	rolling burnout.jpg
68Chevele likes this.
MNmalibu is offline
post #42 of 45 (permalink) Old Aug 2nd, 19, 1:04 PM
Well, you could always go on the other side of the road and lay down the another black mark to match it to look like it has a posi. LOL.
WHT/73 and MNmalibu like this.
post #43 of 45 (permalink) Old Aug 2nd, 19, 1:22 PM
Eaton for the win!
Dino oil only.
Been beating the crap out of mine for almost 18yrs!
WHT/73 is offline
post #44 of 45 (permalink) Old Aug 4th, 19, 10:41 AM
Well, here's the latest update on tuning the off idle stumble out of my Holley 670SA. This carb is on my 396 now 402. Yesterday I changed the 6.5 PV to a 9.5. It has 17 inches of vac at idle, and 15 to 17 at cruising speeds. I changed the sec. spring from silver to purple, float adjustment is correct, a/f mixture screws are one turn out, stock 65 main jets, changed the stock 31 main squirter to a 35 and installed a black pump cam on the number 2 hole. It is way better now, the stumble is almost completely gone. I still need to recheck the timing. I think it's around 18 initial and 39 total. Lot of good info on this thread and others. Thanks to everyone.
MNmalibu likes this.
post #45 of 45 (permalink) Old Aug 28th, 19, 8:26 PM Thread Starter
I installed a lock right locker in my open diff and I'm really happy with it. Now I have uncovered a new problem, wheel hop!! lol
and on and on it goes....it's all good though, I love the car and I love chasing more and more performance.
MNmalibu is offline
