Any Plug Readers Here ? - Chevelle Tech
 13Likes
post #1 of 44 (permalink) Old Jun 8th, 19, 7:16 PM Thread Starter
What do you think ?
Reelysalty is offline
post #2 of 44 (permalink) Old Jun 8th, 19, 7:20 PM
Re: Any Plug Readers Here ?
It's not too lean. Not oily and not black or sooty. I would not change a thing if all eight look like that one.
E10 ethanol fuel, I predict.
B52bombardier1 is online now
post #3 of 44 (permalink) Old Jun 8th, 19, 7:32 PM
It looks great!
tacomatrd is online now
post #4 of 44 (permalink) Old Jun 8th, 19, 8:13 PM Thread Starter
I should have mentioned I use either 93 ethanol free 50/50 w/airplane gas, lightly leaded, or 93 w/Race Gas Concentrate.
383, MSD 8360 and Holley 750 DP, deleted progressive linkage.
This is after driving around town today.
post #5 of 44 (permalink) Old Jun 8th, 19, 8:54 PM
Harry
the bright orange color tan is from the octane additive. I freaked out when I first saw it, but, it means nothing, it is just a by product of the additive.
Harry
hjdca is offline
post #6 of 44 (permalink) Old Jun 10th, 19, 9:43 AM
If that is after just driving around for a day then it looks aweful in my opinion. In a day of driving it should look like it just came out of the box.
1967 Chevelle Malibu 4 door
http://s145.photobucket.com/albums/r...ton/?start=all
The 7.99 at 173mph pass:
https://youtu.be/SIF0dosu-7s
8.02 at 171mph:
https://youtu.be/hH3PS_TrHOc
Calculated Risk is offline
post #7 of 44 (permalink) Old Jun 10th, 19, 4:57 PM Thread Starter
“This is after driving around town today”
post #8 of 44 (permalink) Old Jun 10th, 19, 5:18 PM
Looks to me like you should put it back in a keep driving. Any driveability issues or just trying to dial it in a bit?
1969 Beaumont
1977 Bronco
The rest are boring responsible adult vehicles not worth mentioning.
Chris27 is offline
post #9 of 44 (permalink) Old Jun 10th, 19, 7:01 PM Thread Starter
Plugs were fine, no engine issues then I re-jetted with bigger jets that came with Holley HP center section.
Plugs turned black. I went back to old jets in new HP body. Changed out plugs. Drove around town. Pink tint caught me off guard. Hadn’t noticed pink in past. I rotate between half 93/half airplane fuel and 93 w/Race Gas Concentrate. Luck of the draw I had just mixed RGC for test.
hjdca confirms what “pink plugs” Google search suggested
All seems fine although I’d rather word not get out about my “Pink Plugs” 😁
post #10 of 44 (permalink) Old Jun 10th, 19, 8:07 PM
I'm sure searching "pink plugs" in google might not return the results you're looking for. Assuming you're looking for something spark plug related.
Some things are better kept private
Pioneer4x4 likes this.
1969 Beaumont
1977 Bronco
Chris27 is offline
post #11 of 44 (permalink) Old Jun 11th, 19, 7:33 AM
jeff
I would keep an eye on the plugs and watch for faint lines on the outside where the steel nut area meets the white portion of the plug.
Faint lines going up and down the spark plug..those will be telling you it is misfiring.
Faint carbon tracking.
Tighten the gap if you see that.
I run my HEI sparked plugs at .035".
Here is a set of 4 from the right bank of my 906 vortec head 357" that runs a much modified 750 double pumper #4779.
These are AC 44 heat range plugs and been in the vehicle since June of last year.
AFR is 12.8 at wide open throttle and 13.5 was the last idle AFR I got.
jeff swisher is offline
post #12 of 44 (permalink) Old Jun 11th, 19, 7:39 AM
Please know that "airplane fuel" is likely 100 octane Low Lead AVGAS. But its actually more lead than the best Sunoco 260 fuel that money could buy in 1970. A lotta' lead.
So some of that could be lead deposits and I would not worry about it.
post #13 of 44 (permalink) Old Jun 11th, 19, 8:15 AM Thread Starter
blob:https://www.chevelles.com/dcdbc538-0...8-658003a56eca
WOW ! 👍
B52bombardier1, airport guy said octane was 110 or so and airplane gas is figured differently than car gas. It’s tinted light blue. Thanks for the explanation of “low lead”
I don’t hear so well (used to be married, haha) and am afraid of spark knock especially the modern ping which isn’t so loud. IMO, some RGC or airplane gas is cheap ins on a 4 speed car, 37* all in at app. 1700.
post #14 of 44 (permalink) Old Jun 11th, 19, 8:17 AM Thread Starter
WOW ! 👍. Is in reference to pic of Jeff swisher’s plugs.
For some reason pic didn’t copy.
post #15 of 44 (permalink) Old Jun 11th, 19, 12:25 PM
What i'm saying is that if that is just from driving around for a day, it is way rich. They should look like they came out of the box after a day of use.
427L88 likes this.
8.02 at 171mph:
