Went drag racing - major break down - Page 6 - Chevelle Tech
 66Likes
post #76 of 118 (permalink) Old Jun 7th, 19, 2:01 AM Thread Starter
Re: Went drag racing - major break down
I talked with where I bought the trans from, and basically all I can do is find a 31 spline slip yoke to see if the output shaft splines are twisted too. Otherwise, the mainshaft could be damaged but I wont know without disassembly, so basically if a slip yolk goes on freely, then I'll try driving it and see how it feels.
I talked with Moser, and they said if I can't get the Motul 300 that I could just run a Lucas Oil 75w-90. I asked if they suggested a 140w, they didn't say that's needed.
Youtube Channel.
Instagram:
Twitter:
-SS454- is offline
post #77 of 118 (permalink) Old Jun 7th, 19, 2:30 PM
Another tip Iíll offer is stage INTO the line lock. Meaning try to set the line lock at the pre stage bulb and bump into the stage beam with the line lock on. It keeps the drivetrain loaded. You donít want all the backlash in the driveline to open up. When you dump the clutch all those parts crash together.
I have my line lock wired to my trans brake so when I step on the brake and set the trans brake the front brakes are set on the line lock when the trans brake comes on. The car does not rock or move.
Tarheel Chevelle likes this.
Ray
bracketchev1221 is offline
post #78 of 118 (permalink) Old Jun 7th, 19, 7:04 PM
Idiot proofing your car by over building just slows you down. In the end you will still have a clutch that hits too hard to achieve an efficient launch. All it really takes to bring your car around without breaking it is just adding a little clutch slip time to soften the hit of that RXT.
I have my new version of a clutch hit controller installed in-line between my clutch master and hyd T-brg. It produces a stepped release curve that can also be set up to be active on launch only. It uses a timer to control the duration of the step, and an adjustable valve I call the "HitMaster" valve that separately controls the intensity of the hit. It basically converts a standard hydraulic clutch system to 2 stage, with a softer 1st stage hit that's on a timer, then the 2nd stage of full clutch clamp pressure comes in after the transition timer times out.
A few weeks ago I was experimenting with a Ram dual friction organic/metallic disc, combined with a 2800lb diaphragm PP. 2.78 1st gear, 3.73 rear gear, 28" M/T 275 radials @ 28psi. 1st stage timer was set to 1.0sec. Fired the car up, drove a few miles from the shop to warm the oil up a bit, then stopped on the chip sealed surface to make a hit. Just a random county road with zero rubber down, dead cold 275 radials, no burnout at all. 4500 clutch dump produced a dead hook launch that peaked at 0.98 G's @ 1.02sec. When the 2nd stage of the clutch kicked in at 1.0sec, it knocked the tires loose and accel G's dropped to .72.
Later I did basically the same routine except raised the 1st stage timer setting to 1.5sec for the purpose of extending slip time during launch. This time a 4900 clutch dump produced a dead hook launch that peaked at 1.22 G's @ 1.8sec, well after the clutch's 2nd stage transition.
Remember, this is dead hooked radials on a zero prep random chip sealed county road with no burnout at all. The dual friction disc doesn't mind the 1.5sec slip time that it takes to bring it all together even on a zero prep surface. Adding 0.5 sec of clutch slip time improved peak accel by .24G's, it also got to the same dead hooked driveshaft speed of 2200rpm .625sec quicker. No other changes at all between the two launches, all I did was add .5sec to the clutch transition timer.
Grant
Grant
website-
We make your non-adjustable clutch...ADJUSTABLE!
sr530 is offline
post #79 of 118 (permalink) Old Jun 12th, 19, 12:49 AM Thread Starter
Grant
I tend to agree that I need some sort of launch control with this clutch. I've looked at your Clutch Tamer before. I need to look more into the hydraulic version. Can it be controlled to only work on the launch and not on the shifts?
Youtube Channel.
Instagram:
Twitter:
-SS454- is offline
post #80 of 118 (permalink) Old Jun 12th, 19, 1:53 AM
If the timer is triggered off of line lock release, then it's only active for a short period just after launch only.
If you trigger it with a clutch switch, it's active on launch + shifts.
You can also use two timers, one triggered off of the line lock release, one triggered by a clutch switch. That allows separate timer settings for launch vs shifts.
Grant
Name:	HitMaster system Plumbing Schematic PNG.jpg
Grant
website-
sr530 is offline
post #81 of 118 (permalink) Old Jun 12th, 19, 2:16 AM Thread Starter
Grant
Given that clutch fluid has to go through the system at all times, won't that have an affect on how the clutch reacts/feels during normal driving?
Youtube Channel.
Instagram:
Twitter:
-SS454- is offline
post #82 of 118 (permalink) Old Jun 12th, 19, 2:42 AM
No effect at all during casual driving, as the transition valve is normally open which allows fluid to bypass the hit control valve. It's only when the timer trigger sees 12v that the hit control system becomes active. When 12v is removed from the trigger, the timer countdown begins. After the timer times out, the transition valve opens and fluid is again allowed to bypass the hit control valve.
Grant
Grant
website-
sr530 is offline
post #83 of 118 (permalink) Old Jun 12th, 19, 4:47 PM
PS...with no basis in fact or science, I still prefer dino gear oil in my slightly upgraded 12 bolt and stick. 80-90 is fine.
And if I ever do alot of racing, thanks for the heads up Richy Rich... bias ply slicks...who wouldve thunk,but it make sense.....
post #84 of 118 (permalink) Old Jun 12th, 19, 6:41 PM Thread Starter
Moser recommends Motul 300 for TrueTrac LSD's, even though Eaton recommends conventional. Local shop here says they put in Red Line. I've also been told to run a simple Lucus 75w90.
If I could, I would gladly run a synthetic oil for a very small improvement in friction loss, but also more thermal capacity.
Youtube Channel.
Instagram:
Twitter:
-SS454- is offline
post #85 of 118 (permalink) Old Jun 12th, 19, 7:10 PM
I am running richmond 85-140 synthetic because that is what they recommended.
Lets's see how my rear holds up with my stick
427L88 and -SS454- like this.
tacomatrd is offline
post #86 of 118 (permalink) Old Jun 12th, 19, 8:17 PM
My informal research into rear gear lube resulted in plenty good reports for Amsoil Severe Gear so that's what I use.
LS1tech.com supermoderator.
How may I help you?
1999 Trans Am-500hp
paul bell is offline
post #87 of 118 (permalink) Old Jun 12th, 19, 9:17 PM Thread Starter
I use their ATF in the T56 and am quite happy with that. Thanks for the suggestion.
Youtube Channel.
Instagram:
Twitter:
-SS454- is offline
post #88 of 118 (permalink) Old Jun 12th, 19, 9:20 PM
My opinion is that Amsoil is the finest lubricant you can buy. When I win the lottery, I'll use it in everything. But until then, just my diff.
427L88 likes this.
How may I help you?
1999 Trans Am-500hp
post #89 of 118 (permalink) Old Jun 12th, 19, 10:58 PM Thread Starter
Grant
Since reaction time isn't critical for me, wouldn't I only need the "2nd stage transition valve" which appears to be the adjustable bleed valve?
All I want is a device that bleeds slows the rate of clutch engagement and of course is adjustable.
Youtube Channel.
Instagram:
Twitter:
-SS454- is offline
post #90 of 118 (permalink) Old Jun 12th, 19, 11:38 PM
Beth
The helical gear posis like the S-trac and tru-trac require non-synthetic.
If the oil is too slippery, the torque-bias doesn't work.
Just something to consider.
I don't think the type of oil is going to prevent overloading and sudden failure of parts.
Synthetics are great for slowing normal wear.
nashville beth is online now
