Thoughts on Demon carburetors - Chevelle Tech
 4Likes
  • 1 Post By pockets
  • 1 Post By 68Chevele
  • 2 Post By 67-468
post #1 of 13 (permalink) Old May 17th, 19, 7:34 AM Thread Starter
I am currently running a vacuum secondary 3310. My build is in my signature line. Chris Straub recommended an 850 for it so I tried an 850DP. It made 12 more HP on the dyno but I really didn't like it on the street, thought it was a little lazy even though I spent a lot of time dialing it in as best I could get it but I really like my 750 better and feel that an 850 vacuum might be a better choice. I have a chance to buy an 850 vacuum secondary Demon for 1/2 the cost of a new one from a guy who converted to fuel injection for his pro touring Chevelle. Anything particular I should now about? Thanks.
_____________________________________________
'65 Buick Skylark,
406 sbc, 10.07 comp, ported Trick Flow 195 heads, RPM Air gap, Holley 3310, Straub HR .547/.516 233/243, Hedmans, 200-4R, 10" 3,200, 4.10 12 bolt.....and factory a/c
http://s1085.photobucket.com/albums/...t=Buick007.jpg
65 Skylark is offline
post #2 of 13 (permalink) Old May 17th, 19, 8:05 AM
Re: Thoughts on Demon carburetors
I ran an 850 Demon mech secondary on my ZZ502 for a summer. I really did not like the carb. Tried different jets etc. but it never really worked well. It also seemed to be cheaply made.Switched to a Quick Fuel 950 and it works great.
SS427Rick is offline
post #3 of 13 (permalink) Old May 17th, 19, 8:39 AM
"Wild Bill"
I've had great success with Demon carbs...large and smaller ones.
Even the newer Holley produced ones run awesome.
1967 Camaro SS-Gen I
2017 Camaro RS-Gen VI
2019 Cadillac XT5 AWD
1990 Ford F150 XLT Lariat
BillsCamino is offline
post #4 of 13 (permalink) Old May 17th, 19, 9:14 AM
Hi Bill, I've had a Demon 825 mechanical secondary on my 468 for about 9 years with no complaints. Like you I purchased it second hand for half the price of a new one. I've read several posts on this site and other about problems with Demon carbs, but I haven't experienced any problems. Good luck with your project!!
dell72 is offline
post #5 of 13 (permalink) Old May 17th, 19, 9:37 AM
Kerry
Like many other holleys it will need emulsion changes, relocate the IFR and likely smaller than as delivered. The good thing is that all jets are threaded in them so easy to calibrate by drilling your own jets. A set of pin drill bits, and brass set screws from McMaster Carr is all you need.
I suggest contacting jmarkaudio for baseline calibration ideas.
Camaro_fever68 likes this.
pockets is offline
post #6 of 13 (permalink) Old May 17th, 19, 6:21 PM
I ran a 850 Demon on my 496 until I went to EFI. Demon worked perfect. Infact I feel the Demon was faster at WOT.
64 Chevelle 496
StevenS is offline
post #7 of 13 (permalink) Old May 17th, 19, 6:32 PM
I have 6 Demon carburetors and all of them work great for me. I am really impressed with annular discharged ones, work much better then the Holley annular's that I have tried in the past. I mostly race with the 850 Mighty Demon and it has out shined my old tricked out 750 Holley DP that I used for a long time. Last one I got was from an old guy that said he had an Edelbrock Demon carb for sale. I had to go over there as he did not have a clue to what it was, turns out the stock 350 had a 750 Mighty Demon on it, the y gut told me to give him a $100 and get it out of his garage he hated it so bad. Got it home and it was setup pretty bad, gave it a good cleaning, gaskets and adjusted it put it on my 461 it fired right up and runs great. I guess it's just something else to test at the track.
BillsCamino likes this.
68Chevele is offline
post #8 of 13 (permalink) Old May 18th, 19, 7:29 PM Thread Starter
Thanks for the replies. I went and bought it today. Now I just have to find time to get the car in the shop to swap it on and a couple other things on my list.
'65 Buick Skylark,
post #9 of 13 (permalink) Old May 19th, 19, 1:47 AM
Kerry
https://www.tapatalk.com/groups/raci...ms/holley-f25/
Join this forum and ask for some baseline set up on it.
pockets is offline
post #10 of 13 (permalink) Old May 19th, 19, 6:21 AM
I had an older BG Race Demon dp on my big block with a 600/600 cam. 4 spd. Ran and idled great. I sometimes wish I went a little bigger. I was always told back in the old days a double pumper for a stick car and Vacuum for an automatic.
NickeyChevelle and 68Chevele like this.
67-468 is offline
post #11 of 13 (permalink) Old May 19th, 19, 7:59 PM
Jason
I went from a 4779, 750DP to a 850 Mighty Demon Annular I got for $500 and after lots of tuning it ran good but my old 750 still felt better on the street. Wish I would have gotten a 750 Mighty Demon or Holley 750 XP.
69 Chevelle SS
Budget 454, 10.4:1, small valve 781's, Engle hyd cam 244/260 @ .050, .560/.570 lift ICL/LSA 108/108, Performer RPM w/ 750DP
1.75 Dynomax coated headers, Full 3" exhaust with 17665 Super Turbos
700R4 w/10" 3500, 12 Bolt 3.73's, 275/60-15 DOT Hoosiers, 3650lbs without me
Best time: 11.96 @ 111, 60' 1.65 (6-20-2014)
JB SS 396 is offline
post #12 of 13 (permalink) Old May 20th, 19, 1:55 AM
Shane
Dont you have to change the springs on the distributor also?
Sometimes you just cant swap a carb...
1969 chevelle
fishhead is offline
post #13 of 13 (permalink) Old May 20th, 19, 2:11 PM
Ray
I could be wrong, but I don't think you're going to like an 850 vacuum squarebore carb. Your combo screams a decent 4779 750 holley
Ray
Camaro_fever68 is offline
Diode Dynamics Universal RGBW™ Multicolor LED Demon Eyes! USA Made! Diode Dynamics Diode Dynamics 0 Mar 2nd, 18 6:06 PM
Dodge Demon - $84,995... WakkoWarner Bench Racing 17 May 23rd, 17 10:30 PM
Street Demon (#1904) install vjp38 Performance 17 Dec 8th, 15 10:55 AM
On the fence choosing a Demon carb budsthe3 Performance 22 Aug 17th, 15 8:14 PM
Help choosing a Demon carb budsthe3 Performance 14 Dec 16th, 14 12:00 AM
