How hot does your car run idle & cruise? - Page 3 - Chevelle Tech
 15Likes
post #31 of 48 (permalink) Old May 15th, 19, 3:29 PM
Re: How hot does your car run idle & cruise?
For me, it was Rockauto part number 35879 at $31.79. This is their choice of replacement cooling fan controller for a 1999 Chevrolet Silverado 1500 or GMC Sierra with a 5.3L LS engine.
I think you can get it slightly less expensive on Ebay.
Sent from my SAMSUNG-SM-N900A using Tapatalk
B52bombardier1 is offline
post #32 of 48 (permalink) Old May 15th, 19, 3:45 PM
Kerry
Originally Posted by tacomatrd View Post
Which controller are you using exactly?
I am about to order my radiator and am waiting to head to the junk yard to find a fan(or two).
Thinking LT1 style fans or Mark VIII
This one. The 2SP.
Relay Controllers and Accessories
pockets is offline
post #33 of 48 (permalink) Old May 15th, 19, 5:32 PM
Ron
69 Camaro
491...10 to 1...252/254 hyd roller...AFR 315's
EMP/Stewart 160 thermo with bypass holes
Edelbrock aluminum Victor high volume water pump
Timing...24/38 with vac advance(ported)
Probe is in the intake manifold
Becool aluminum direct fit radiator
Summit dual 11" HO fans(spal copy)..2760 cfm
150 amp alt
I have had this new radiator in the car for about 1 month. Prior radiator was a 4 core copper brass from US radiator. New set up so far has worked killer. Runs 170-175 at idle or freeway cruising. The temps have only been in the low/mid 80's so curious to see if anything changes in the 90's. I dont drive the car when its in triple digits.
tacomatrd likes this.
69 Camaro
491/AFR 315/Straub hyd roller/pump 91
TH400/GV OD/9" 3.50's/ 255/60/15 DR
10.86 at 124.8
3670 with driver
Last edited by dirtlips408; May 15th, 19 at 5:37 PM. Reason: more info for response
dirtlips408 is offline
post #34 of 48 (permalink) Old May 16th, 19, 9:41 AM
George
The solid roller 388 in the 71 is just under 12:1 compression. Weiand hiflow water pump. Advance Auto $69 aluminum 1 row radiator with plastic tanks, factory clutch fan and shroud, 180 thermostat. It ran right at 180 pretty much all the time. Would be 195ish at end of a run.
The wagon has a 454 with unknown internals. Factory clutch fan from the 388 and a Champion 3 row radiator. Runs 180-185 all the time.
'71 Malibu
355 [email protected]
125 [email protected]
383 Mud Motor- [email protected]
100 shot [email protected]
Geo71 is online now
post #35 of 48 (permalink) Old May 16th, 19, 12:26 PM
solid roller 383 11.5:1
Dewitts radiator
hi flow pump
160 stat
16 in spal
Wants to run around 180 or so in 70 deg heat
think an oil cooler would help
WIll buy a controller in a last attempt to keep it at 180 max. Like170-175 better car seems peppier there
Wiht lash I dont like the "up to 200" then back down"...or using a cooler switch and having it run all the damn time.
he 350 would run 10 deg cooler on avg.
cuisinartvette is offline
post #36 of 48 (permalink) Old May 16th, 19, 12:28 PM Thread Starter
This thread is showing that a lot of electric fan setups are working extremely well!
-SS454- is online now
post #37 of 48 (permalink) Old May 16th, 19, 12:45 PM
Ron
I think one thing that helps alot is the fan set ups that have the flaps in the shroud the allows the air to flow at highway speeds.
-SS454- likes this.
69 Camaro
10.86 at 124.8
3670 with driver
post #38 of 48 (permalink) Old May 16th, 19, 12:52 PM
If it aint broke....
67 Chevelle
439 10>25:1 w/ LEAN azz tripower carburetion
1985 Z/28 clutch 7 blade GM fan
67 shroud
3 core Harrison, w/ modern cores
Carquest NEW pump ( took a few tries to get a proper casting btw )
RobertShaw Hiflow stat
**MANUAL TRANS** ( i think this makes a huge difference)
Cant get it to run hotter than just above t stat opening. Although I had to rebuild the engine after the old WP went unexpectedly, and it didnt take long for the oil rings to lose tension. Like 5-7 minutes of run time w/o noticing the temp gauge had pegged.
Stock works mint for me, but again, not having transmission fluid to cool likely makes it work as mint as it does. My Harrison is not a 67 and does have the AT ports on the bottom.
post #39 of 48 (permalink) Old May 16th, 19, 12:52 PM
Yep! That is why I am heavily looking at the LT1 fans and want to roam the junkyard looking for other ideas--they have the flaps where the ones you buy as aftermarket repos dont.
I would say that I am going to switch over to electric fans and a griffin 2x1.25 radiator when I return.
dirtlips408 likes this.
tacomatrd is offline
post #40 of 48 (permalink) Old May 16th, 19, 4:58 PM
If you going to make the switch, look into the ford windstar fans. I run them on my car, twin fan setup. Rated at 4500ish cfm. The shroud is a perfect size, it just needs a little trimming around the tanks to make it perfect.
If you want to up your cooling game to the next level look into a electric waterpump. I purchased a stewart brushless motor water pump. You simple cut it into the lower RAD hose and wire it up. I went from 220 all the time down to 170 at any speeds on +30-32C days. massive change.
1968 Beaumont
502 big block
HP and ET not determined yet!
GoFast Beaumont is offline
post #41 of 48 (permalink) Old May 16th, 19, 5:22 PM
I love seeing things like this, now I can add to my list of fans to look for at the junk yard.
Do you have a picture of this water pump? I likely won't switch to it, but if I ever build a dedicated race car, that is what I would go to.
post #42 of 48 (permalink) Old May 16th, 19, 5:48 PM Thread Starter
How reliable are the electric pumps these days?
post #43 of 48 (permalink) Old May 16th, 19, 6:02 PM
Beth
Look at the Cold Case 2 x 1.25 aluminum radiator ($360)
Plus it looks just like stock if you paint it black :
https://www.summitracing.com/parts/rad-che542
67 Chevelle convertible, 138 vin, original 4 speed, bucket seats, 12 bolt, Marina Blue with black interior
nashville beth is offline
post #44 of 48 (permalink) Old May 16th, 19, 11:32 PM
Oh I am looking at this griffin: https://www.summitracing.com/parts/g...2-xs/overview/
Fans appear to be a little too wide though...
post #45 of 48 (permalink) Old May 20th, 19, 8:37 PM
10,000 hr life cycle is what stewart warner says. It is a brushless motor.
Most others are around 2-2500hr life cycle.
Most OE cars/trucks might make it to half that. As well electric pumps are becoming standard equipment on modern cars now as it offers better control with water cooling if tied up with a PWM controller.
Using a PWM controller with a electric water pump would allow you to not run a thermostat any longer and really maximize coolant flow WHILE still allowing adequate warm-up times.
Current setup is a Performance World Radiator (MOPAC), stewart warner electric pump, Spectra Ford Windstar fans, and a Performance World thermostat.
At this point, even with a 4`` thick intercooler in front of the radiator, it only takes 1 fan to drop engine temp from 190 to 180, at idle and slow movement(less than 30km.hr) Approx 3 minutes to complete the task. Daytime temp was 15-18C. Plenty of cooling left for highway driving and hotter days.
1968 Beaumont
502 big block
65 ss alhewitt What's it worth? 15 Feb 26th, 18 8:12 AM
What kind of fuel filter do you run on your 11 second or faster car? ddeennis Performance 26 Sep 15th, 15 2:26 PM
Mutha Thumpr Cam issues Please !HELP! stony Engine 48 Jun 21st, 14 7:42 AM
Smokey Yunick #13 Build tc72chev Body Shop 23 Nov 12th, 13 8:22 AM
