Polly vs rubber - Page 3 - Chevelle Tech
 7Likes
post #31 of 35 (permalink) Old May 16th, 19, 9:07 AM Thread Starter
Re: Polly vs rubber
Originally Posted by GuysMonteSS View Post
I installed a set of graphite impregnated Poly bushings from PST in my Monte several years ago.
Mark Savitske had recommended using a graphite bushing and those were what I went with.
It looks like they are still available from PST for your '69;
https://p-s-t.com/series-220192-poly...mount-kit.html#!
Guy
I checked these out. About $99 for the bushings and about another $200 for their hardware. Stainless is all they offer.
GuysMonteSS likes this.
mrpaticular is offline
post #32 of 35 (permalink) Old May 16th, 19, 4:54 PM
Guy
Re: Polly vs rubber
That's pretty expensive for some bolts.
I bet that there is a cheaper alternative.
Guy
'86 Monte SS,
513 Stroker,
AFR CNC'd 315 heads,
Isky .904 EZX Roll lifters,
9 inch rearend,
TC Member # 4921
GuysMonteSS is offline
post #33 of 35 (permalink) Old Jun 26th, 19, 1:29 PM
I also went with the energy suspension poly body mounts. I love them! What a big difference compared to my old worn out '68 mounts.
68elky396 is offline
post #34 of 35 (permalink) Old Jun 26th, 19, 3:51 PM
Re: Polly vs rubber
I went to the energy suspension poly body mounts about 4 years ago when I swapped my frame. I even added the "missing" body mount 1/2 way down the rocker panel. I didn't notice any measurable difference. I've had the poly control arm bushings front and rear for 19 years, never any issues or noise. I would go poly again.
1969 Beaumont
1977 Bronco
The rest are boring responsible adult vehicles not worth mentioning.
Chris27 is offline
post #35 of 35 (permalink) Old Jun 26th, 19, 10:24 PM
Gary
Re: Polly vs rubber
I recently changed all the control arm bushings front and back with Energy Suspension poly bushings along with Bilstein shocks, and it was a huge improvement. I noticed a little more road feel, but was expecting that. The ride and handling was greatly improved.
I have not changed out the body bushings yet, they will have to wait. I suspect the rubber body bushings are giving me enough road vibration isolation that the ride does not feel harsh.
Gary
(oo_____oo)
gman628 is offline
Rubber vs Polyurethane tie rod boots / bushings Krister Brakes, Suspension & Steering 4 Sep 7th, 17 8:10 PM
66 300 deluxe rubber floor mat 66 300 deluxe Interiors 5 Dec 2nd, 16 11:43 PM
Bench Seat Rubber stoppers gregnoe Interiors 4 Nov 12th, 13 10:56 AM
Window frame rubber? VenomGT Wagons & Four Doors 0 May 2nd, 13 6:56 PM
67 Quarter Window rubber install? HMartin Body Shop 1 Mar 5th, 13 10:11 PM
