Aftermarket Cowl Induction Hood for Cooler Air? - Chevelle Tech
 32Likes
post #1 of 17 (permalink) Old May 2nd, 19, 6:16 PM Thread Starter
Question Aftermarket Cowl Induction Hood for Cooler Air?
Performance Mod
65 Chevelle
BBC
AMD 2" Cowl Induction hood
14" Open-element Chrome Air Cleaner, w/drop-base (Carb), AC Delco style
All I wish to do is use the '69 Z-28 or '70 Chevelle single-snorkel "outer" air cleaner w/above, which seals to the hood via a rubber moulding ring. I would remove the snorkel horn & seal the resulting hole. This arrangement has the carb breathing only non-underhood air. (No flapper)
I'm betting many others have done this adaptation over many years with all-years of Chevelles. AMD's underhood CI sheetmetal stamping invites what appears to a factory-appearing mod.
Did you detect any Performance gain from the mod described above?
Tarheel Chevelle is offline
post #2 of 17 (permalink) Old May 2nd, 19, 9:03 PM
Bruce
Re: Aftermarket Cowl Induction Hood for Cooler Air?
Yes (as long as the Air Cleaner is sealed to the underside of the hood), under the correct atmospheric temperature conditions there will be a seat-of-the-pants increase.
Tarheel Chevelle likes this.
Our You Tube Vids:
NickeyChevelle is online now
post #3 of 17 (permalink) Old May 3rd, 19, 9:47 AM
Go through Oliver's Elcamino thread. He used a kit from Summit.
mrpaticular is offline
post #4 of 17 (permalink) Old May 3rd, 19, 11:12 AM
Lol, I just did this mod to my stock non C/I hood (domed), but built an air box because my hood didn’t have the sealing ring. Also had to cut out the block off plate in the hood. I call it “true cowl induction”.
Used 5052 aluminum and an old air cleaner base. My fitech has an intake air temp sensor, on previous logs I was seeing over 110 deg temps. The new arrangement is at minimum 25 deg cooler.
First two pics are of the template. Yes, those are toothpicks to set the trim height, minus the compressed bulb seal.
Was able to complete it in a weekend. All in, I’m out about 75 bucks.
ID:	592896   Click image for larger version
ID:	592898   Click image for larger version
ID:	592900   Click image for larger version
SSJohn is offline
post #5 of 17 (permalink) Old May 3rd, 19, 11:31 AM
Like it!!I used a Camaro CAI on my 67 it worked fine. Did I feel anything? Not really around town on the hwy it may have helped.Never tracked it though
Do believe lowering the air temp a bunch is a good thing. WIsh I had metal fab skills!!!
Tarheel Chevelle and SSJohn like this.
cuisinartvette is offline
post #6 of 17 (permalink) Old May 3rd, 19, 8:16 PM
Josh
Originally Posted by Tarheel Chevelle View Post
Performance Mod
65 Chevelle
BBC
Where did you find a steel 65 cowl hood?
Cheveezy is offline
post #7 of 17 (permalink) Old May 4th, 19, 9:15 PM Thread Starter
Post should read 66. Too late to edit. My apologies.
post #8 of 17 (permalink) Old May 4th, 19, 9:31 PM
Josh
No problem, I wish one was made for a 65!
Cheveezy is offline
post #9 of 17 (permalink) Old May 4th, 19, 9:45 PM
Lew
Here I mine. I have a 1965 Chevelle with a 2.5-3 inch cowl used the stuff from a 1970 Chevelle. That is a 16x4 air filter on a Holley 4150 carb. Standard deck height BBC 540. I have a Hardwood cowl seal in the hood.
ID:	592988   Click image for larger version
Lew540 is offline
post #10 of 17 (permalink) Old May 5th, 19, 9:03 AM
Lew
Here is a photo shows the entire set up better.
mino65 and SSJohn like this.
Lew540 is offline
post #11 of 17 (permalink) Old May 5th, 19, 12:38 PM
Simple and clean Lew how do you like it?
I can only think once the engine is hot it would make some difference (ambient vs engine bay temp)
post #12 of 17 (permalink) Old May 5th, 19, 1:07 PM
Guy
I know that my Monte SS isn't quite the same car,but the end result would be similar.
I used a Model # 14HS from Ram Air Box,heres a link;
Models of Ram Air Box
Heres a picture of it installed;
Guy
Name:	12039319_10153034680821573_2824459269129456640_n (2016_04_18 13_36_38 UTC).jpg
'86 Monte SS,
513 Stroker,
AFR CNC'd 315 heads,
Isky .904 EZX Roll lifters,
9 inch rearend,
TC Member # 4921
GuysMonteSS is offline
post #13 of 17 (permalink) Old May 5th, 19, 1:32 PM
Nice work.
'66 SS Chevelle
565 BBC Mamofied 300cc Ovals
4.11 12 bolt
Best e.t. to date [email protected] @115.31
1.301 60' 3355 pbr 1.306 3055S
Stokerboats is online now
post #14 of 17 (permalink) Old May 5th, 19, 5:16 PM
Lew
It works well I have been running this set up since 1992 (540 came in 1994). Air cleaner is cold to the touch even in traffic it is not too bad at highway speed of course it is fine. That is a 16x4 filter. I would say a solid 30 degrees cooler than outside air when I did a thermometer test. The air cleaner base is a cut up 1970 Chevelle cowl induction base. I will post another photo.
SSJohn likes this.
Lew540 is offline
post #15 of 17 (permalink) Old May 5th, 19, 7:30 PM
Lew
Here is a photo of the base. Basically a 16 inch drop base with the cowl induction part left intact but the middle is cut out for the new wide body base. It is riveted to the aluminum drop base so the cowl seal work like the original design. If you look through windshield you can see air cleaner very easy. The red line in the base is so I know where front is every time. I meant to say above that the it is very close to the outside air temp and probably 30-40 degrees cooler than the under hood air especially at speed.
Lew540 is offline
Correct non cowl induction air cleaner spaceace77084 Chevelle Tech 9 Feb 19th, 19 7:43 PM
Cowl induction hood versus non cowl induction appearance mersol Body Shop 11 Jan 18th, 17 12:32 AM
Why was there a cowl hood without, and cowl hood with flapper offered? YankeeRodder Bench Racing 58 May 14th, 14 1:04 AM
66 Chevelle Hood Alignment 66ChevelleMalibu Body Shop 5 Apr 14th, 14 10:10 PM
SS Cowl Induction Hood Kevin Long 1999 -- 3 May 13th, 99 9:42 AM
