Staggered jetting - Chevelle Tech
  • 1 Post By 72FourFiftyFour
post #1 of 7 (permalink) Old Apr 26th, 19, 8:57 AM Thread Starter
Staggered jetting
Does anyone know of any dyno tests comparing staggered jetting to conventional jetting with a 4781 on a bbc with a hogged out 163 intake. Right now I’m at 77’s in the front with 84’s in the rear. It seems ok but curious if gains are to be made.
aimhard is offline
post #2 of 7 (permalink) Old Apr 26th, 19, 11:35 AM
Re: Staggered jetting
I would say all are staggered. What is with the hogged out intake?
You need to supply much more info about your entire setup.
mrpaticular is offline
post #3 of 7 (permalink) Old Apr 26th, 19, 2:07 PM Thread Starter
I should have said 163 intake with plenum divider removed. According to my old "How to Hotrod Big-Block Chevys, it suggested left front 80, right front 76, left rear 76, right rear 78, as a starting point, for dual plane intakes with no divider.
aimhard is offline
post #4 of 7 (permalink) Old Apr 26th, 19, 2:36 PM
I remember reading that book and thinking of doing that with mine. Remind me, the factory Holley had little tabs on 2 of the 4 venturi....were they also staggered jet or was that in place of staggered jet? I would think if you removed the plenum divider, staggered jets would have not effect.
rp930 likes this.
1972 Monte Carlo 454 (W code), now with ZZ502.
TH400, 2000 stall, 3.31s
11.9 @ 114
72FourFiftyFour is offline
post #5 of 7 (permalink) Old Apr 27th, 19, 9:10 AM
I misunderstood your idea for staggering. Think about it. With no divider, the fuel/air goes into the intake and goes where the vacuum is. Staggering not effective on left and right jets. But absolutely is effective front to rear. Jetting depends on usage.
post #6 of 7 (permalink) Old Apr 27th, 19, 9:59 AM
Gerry
I'm not familiar with a 4781.
Are you running a power valve?
67 SS BBC
4.11's
bradley67 is offline
post #7 of 7 (permalink) Old Apr 27th, 19, 11:08 AM Thread Starter
Yes a 6.5 power valve. The book says the staggered jetting recommendation allows equal amount of fuel to all cylinders.
aimhard is offline
BBC stagger jetting physics: Explained anywhere? 69ZL1 Performance 31 Aug 16th, 18 1:11 AM
Holley Jetting currently at 11.5:1 AFR 66PetRat Performance 16 Dec 20th, 14 9:52 PM
Year One 5 Spoke Staggered??? jacen33606 Wheels & Tires 3 May 28th, 14 10:24 AM
Holley 850 jetting experience mr 4 speed Performance 28 Nov 6th, 13 2:59 PM
Budget blower-time to remove 600's and put on my 750's, jetting help. ddeennis Performance 3 Dec 19th, 12 10:07 AM
