SPal fan conroller, or dual/oem upgrade? - Chevelle Tech
  • 1 Post By Iforgot
post #1 of 15 (permalink) Old Apr 22nd, 19, 1:53 PM Thread Starter
Have a single 16" spal and DeWitts BB radiator..Would like to keep this around 180 avg
At some point Ill be making a product similar to the "Big Mount" air damn as I had on some C4s. It will cool it quicker at speed so it runs less...want to run it this summer and not worry about it but dont know much about wiring or controllers. Believe this one has a wire off the batt, goes to a relay, to a fan switch then the fan. Alt is a denso 80/120 with a larger gauge wire and grounded to the block.
-Is there a simple controller I can use for this fan
Is there a dual fan setup they make? Dont like the temp fluctiation. Using their 200 on/185 switch as the 185 on 165 off runs all the time.
Or is there an OEM fan setup that fits?
Id need some wiring instructions, not real understanding of all that. Now I have the fan switch in the intake, sent to a relay they supplied wiht the fan.
cuisinartvette is offline
post #2 of 15 (permalink) Old Apr 22nd, 19, 2:00 PM
Mr Bill
Re: SPal fan conroller, or dual/oem upgrade?
What temp do you want to be at ? What thermostat are you running ?
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Enginerepairshop.com
Team Chevelle #100
BillK is offline
post #3 of 15 (permalink) Old Apr 22nd, 19, 2:08 PM Thread Starter
160 Milodon, 180 tops....honestly like it a few deg cooler but thats not realistic. At cruise speed it wants to settle around 180.....down the road Ill install an oil cooler which ought to help. But not now
Dont want summer temps to hold me back. It gains heat quick once the fan is shut off and Im sitting at lights or-
post #4 of 15 (permalink) Old Apr 22nd, 19, 2:44 PM
Dual fans is a good approach...OEM mechanical fan with clutch and a helper electric fan inside the shroud set to turn on as needed
70GS455 is offline
post #5 of 15 (permalink) Old Apr 22nd, 19, 2:50 PM
Mr Bill
I haven't been following your other posts so please excuse this question. How much horsepower do you think the engine is making ?
Bill Koustenis
Waldorf Md
Team Chevelle #100
BillK is offline
post #6 of 15 (permalink) Old Apr 22nd, 19, 3:42 PM Thread Starter
Id have to fool with the brackets so I have some WP snout sticking out.....I do have a flexalite nylon flex that I loved..but yrs ago I had an electric shop do some work on this and he got the bright idea beers later to hack the whole system up?? So for now stuck with electric otherwise I think your idea is great.
Bill I have no idea on power....more than 5 less than 6 Im guessing
11.5:1 385, may be a hair more as once Mamo ported them (now 230cc) they got more chamber work and angle milled to death, may be 60cc now?
294cfm int 232 exh around .600ish
Isky SR 260/268 294/302 108 lsa .670 gross, Jesel 1.6
Fully ported Team G, AED HO 850
Dougs 1-3/4 longtubes, TT 3" duals, X, ULtraflows. RCR lightweight underdrive system. nothing exotic.
Typical overcammed sbc but its what i had so-
Alt is 80/120, I heard the controllers with the probe are unreliable?
post #7 of 15 (permalink) Old Apr 22nd, 19, 3:51 PM
Greg
This is what I have on my car and have used for 2+ years with absolutely no issues. Works very well, looks kinda neat or you could pretty easily hide it if you wanted. Around $27 from Amazon. I wired mine to trigger a 40A relay on my electric fan..used to forget to turn off the fan between rounds, now I don't have to worry about it at all.
Inkbird ITC-106VL (12V) Single DIN mount, 1.73"wide x 1.73" tall
https://www.chevelles.com/forums/att...592178&thumb=1
dirtlips408 likes this.
Greg C.
1969 Chevelle Malibu
New 496 bullet under construction..
Iforgot is offline
post #8 of 15 (permalink) Old Apr 22nd, 19, 6:24 PM
Using this w/2 Spal fans. Works like a champ.
https://www.proformparts.com/product...n-probe-sensor
'66 SS Chevelle
565 BBC Mamofied 300cc Ovals
4.11 12 bolt
Best e.t. to date [email protected] @115.31
1.315 60'
Stokerboats is offline
post #9 of 15 (permalink) Old Apr 22nd, 19, 7:07 PM
Iforgot, that's an interesting product. With multiple outputs, it can support low & high speed.
https://www.ink-bird.com/products-PI...er-itc106.html
LS1tech.com supermoderator.
How may I help you?
1999 Trans Am-500hp
paul bell is offline
post #10 of 15 (permalink) Old Apr 22nd, 19, 7:14 PM
cuisinartvette, I suggest you find a radiator shroud the covers the entire radiator and has two high capacity fans. At least 3,000 CFM each.
The more an electric fan moves in CFM, the more current it will draw. Some fans run over 20 amps each.
The positive and negatives should come directly from the battery, fuses in the positives. Each fan needs it's own relay.
Using the above controller, you can have one fan on at say 190 degrees and the second fan come on if the temps keeps rising to say 210.
Or, you can do a low speed/high speed fan setup with a series/parallel relay set, it takes three relays. In low, both fans run at low speed and in high, they kick up to full speed. Dual low speed fans are quieter that one at full speed.
How may I help you?
1999 Trans Am-500hp
post #11 of 15 (permalink) Old Apr 22nd, 19, 7:59 PM Thread Starter
Thanks Paul I have some reading to do!
Strokerboat that one in your link..instructions say you can change when it turns on what about when it cuts off?
(Obviously I know nothing about electrical).
Other than the wire from the alternator what upgrades would need to be done to handle higher amp stuff? New M and H harness.
What dimensions are the dual spal setups? Not saying ILl buy them just looking into different options. I know they will do the job but like the idea of an OEM type also
The one in an old E430 we have (duals) move a rediculous amount of air..love a bulletproof system.
post #12 of 15 (permalink) Old Apr 22nd, 19, 8:20 PM
Spal in my experience makes the best fans available. You'd have to check their website. I have my fans set to come on at 160* but I don't recall the shut down temp or if it is even something which can or can't be set. I don't drive my car on the street anymore. Too many 3rd world drivers here. The controller has an over ride which you can set "on" temp with. I just let mine run. Always can call tech at ProForm and pick their brains if interested.
'66 SS Chevelle
4.11 12 bolt
1.315 60'
post #13 of 15 (permalink) Old Apr 22nd, 19, 8:59 PM
Greg.
Have a SPAL Dual Efan/Shroud setup/system on my 67's stock type/size DF Rad
When I bought the Rad from Don at Alumitech I had him put Brackets on it for this particular Efan/Shroud Unit
that I already had/bought which came with all the Wiring / Relays / etc.
I wired it up myself based on the great Instructions included
I setup 1 Efan to come on at 170* based on the Temp Unit put into the Intake at/just under the Thermostat
the 2 Efan I wired to a Toggle Switch under my Dash so I can flip it ON if needed
each Efan has it's own Relay
https://webstore.spalusa.com/en-us/p...-11-p-12v.aspx
Type: High Performance - 12V Puller
Height: 16.26" (413mm)
Width: 23.46" (596mm)
Depth: 4.25" (108mm) at the Fan Motors, in the middle where the Pulley/Water Pump Snout is ,, it is less see pics
It keeps my 468 ci running at 180* or less on the Hwy and in City Traffic
plus back to back trips down the 1/4 Mile Track
67 Chevelle Malibu SS Cdn
Born 283 / PG / A51
Now 468/Th400 2,500 stall/ S60 3.70 Gs
Prev Best on M/T S/R #6641 street Tires/Dress 2016/10/9
60' = 1.720
1/8 = 7.747 et / 89 mph
1/4 = 12.112 et / 112 mph
NEW Best on M/T ET S/S #3454 street Tires/Dress 2018/05/20
60' = 1.664
1/8 = 7.532 et / 91 mph
1/4 = 11.814 et / 115 mph
Kirk's67SS is offline
post #14 of 15 (permalink) Old Apr 22nd, 19, 9:35 PM Thread Starter
Thanks all got some calls to make. 180 is the hottest I want this getting. This Dewitts looks identical did they take them over?
Need to learn more about wiring looks like, cant afford to be ignorant. lol
Dont care about noise just function.
post #15 of 15 (permalink) Old Apr 22nd, 19, 9:52 PM
Greg.
I believe Don use to work for Dewitts but he started his own business selling the same type of well made Rads
Don's Dad got sick and Don had to close down for awhile
Don was back selling them again, try a Search on here for "Alumitech" and you might be able to reach out to him
Try sending him a PM
https://www.chevelles.com/forums/11-...Alumitech+Rads
Born 283 / PG / A51
60' = 1.720
60' = 1.664
Cooling 101/setup that keeps old school bbc/sbc motors nice & cool! SWHEATON 2014 74 Jul 13th, 17 11:07 AM
Radiator/fan decision 72 468/400chevelle Heating & Cooling 14 Mar 30th, 15 2:30 PM
Electric fans EB 67 Heating & Cooling 27 Jun 15th, 14 11:58 AM
Fan blades issue alexdrastico Heating & Cooling 8 Oct 14th, 12 2:47 PM
