572 questions / Help - Page 2 - Chevelle Tech
 3Likes
post #16 of 35 (permalink) Old Apr 21st, 19, 8:36 PM Thread Starter
Re: 572 questions / Help
I think I can get the 572 with carb, msd, dist, lemons headers, updated springs and lifters for what Marks cast iron head 467 cost.
I know the smaller cubic inch engines can be built up to have more horsepower but they have to be more radical to have the same power as the larger cubic inch.
Mike and mark do Great work no doubt….
I had hoped someone had installed a 540 or 572 with a cowl hood, stock booster and stock brackets..
Anybody know if stock brackets can be used on a 572??
Thank you for all the suggestions
71 Malibu 400 B B Conv _72 GS 455 Life is not a journey to the grave with the intention of arriving safely in a pretty and well-preserved body, but rather to skid in broadside, thoroughly used up, totally worn out and loudly proclaiming: "WOW! WHAT A RIDE!!"
Redmanf1 is offline
post #17 of 35 (permalink) Old Apr 21st, 19, 8:51 PM
There are several that have installed big-inch short deck blocks with no major issues.
The tall deck 572 is a horse of a different color, though.
You might try searching for someone who has done it with a tall deck build into a 496 or 505, they'll have the same external dimensions as the 572.
If this is a $6K deal, it's probably worth it, but for Pete's sake ditch GM's heads if they're the -401 castings, they're a major bottleneck on that engine. Many people have tried to port and rework those and few have succeeded in making decent power from them.
Gary Adrian
Busted Knuckles is offline
post #18 of 35 (permalink) Old Apr 21st, 19, 9:30 PM
Originally Posted by Redmanf1 View Post
I do not want to change the brake booster as it is original and I want to keep it somewhat original looking. Below is what I have now, I think the cam and compression are what is killing me. We were at back to the bricks and put it on the dyno and I remember not being happy. I would rather keep me Stainless works headers but I don't think they will work on a tall deck??? I want to keep a mechanical fuel pump.
CID 496
Block 512 casting H-30-9
Carb 850 vac sec
Intake edelbrock RPM
Heads Brodix aluminum RR ovals Intake Port: 270cc 119cc Intake 2.250'' / Exhaust 1.880''
Cam Lunati Hyd roller 60211 575_ 575 221 _ 229 112 @50
Lifter Lunati Hyd roller 72431
Rocker arm Crane gold roller 1.7
7/16 custom push rods
Timing set Cloyes Quick Button Two-Piece & Torrington roller chain
Crank Scat 4340 forged 4.250 stroker crank
Rods Eagle ESP heavy duty 6.385
Pistons KB flat top, compression with 119cc is 8.75 to 1
Oil pan Moroso 20403 scraper screen installed one piece pump shaft
Aluminum water pump
Ignition: stock with pointless pickup
Exhaust Stainless works headers 2” 2 ½ magnaflow SS system
If this were my 496 I would add some forged Speed Pro 10 to 1 pistons and change that cam, that big engine needs a little breathing room. Put something in there with 236° and around 242° duration at .050 and put the cam on a 110°LCA those two changes should give you all the power you need. Look at Vortecpro's 496, Marks is streetable and makes 650hp. I think yours should be able to do that real easy.
68Chevele is offline
post #19 of 35 (permalink) Old Apr 21st, 19, 9:46 PM
Beth
A 540 is the same size as a 454.
I posted where you can buy a shortblock for $4300. Everything from your current engine will bolt on. Cylinder heads, intake, etc.
https://www.summitracing.com/parts/m...RoCawAQAvD_BwE
It's the 572 that uses a tall deck block. Totally useless as you can buy a 598 shortblock that's the same size as a 454.
67 Chevelle convertible, 138 vin, original 4 speed, bucket seats, 12 bolt, Marina Blue with black interior
nashville beth is offline
post #20 of 35 (permalink) Old Apr 21st, 19, 10:05 PM Thread Starter
Thank you.....
I was thinking that the 540 was a tall deck..
Redmanf1 is offline
post #21 of 35 (permalink) Old Apr 21st, 19, 10:30 PM
That 540 short block is a good deal if it has a Dart or World block. Tri-star engines used to sell some 540 short clock for a good price also.
post #22 of 35 (permalink) Old Apr 21st, 19, 10:47 PM
Jason
It uses a Blueprint block:
https://www.jegs.com/p/Blueprint-Eng...60513/10002/-1
That would be another option. Buy an 4.500" bore based block and pistons. Prepare the block and wait to pull the 496 until the block is ready.
Reuse your crank and rods. Will just have to have the crank re-balanced, but that should only take a few weeks.
Assuming you will be doing all the work
Jason Gore
AKA DragRacer
Naturally Aspriated 450 SBC - 915 HP / 714 lb-ft
3370 lbs
1.36 - 60', 5.93 @ 116.7 MPH - 1/8th
DragRacer is offline
post #23 of 35 (permalink) Old Apr 22nd, 19, 3:16 AM Thread Starter
Is the dart M block better than the Blueprint series or would you pay $200-$300 more for the dart?
What will not interchange from the old style chevy block to the new Dart m block? I know the oil pan will not what about timing cover and chain?
If I purchase the short block would go for the 540ci or 555ci?
Redmanf1 is offline
post #24 of 35 (permalink) Old Apr 22nd, 19, 7:53 AM
Beth
I'm pretty sure blueprint is using the GM sportsman block.
post #25 of 35 (permalink) Old Apr 22nd, 19, 8:45 AM
^ nope, they have their own castings. The only drawback I've seen is that they didn't design them with splayed outer main bolts. Word I've gotten is that they're cast out of similar material to GM OEM blocks, not the harder stuff used in Bowties, Big M, etc.
Go for the Big M, it's a hoss.
Gary Adrian
post #26 of 35 (permalink) Old Apr 24th, 19, 4:08 AM Thread Starter
Well found out the lemons headers are over the frame headers so that kills those headers for me.
Is the one-piece rear main seal a better option? I would have to get a different oil pan, will the stock style timing cover and chain still fit?
Redmanf1 is offline
post #27 of 35 (permalink) Old Apr 24th, 19, 7:21 AM
Beth
I would think the intended rpm of the motor should determine which way you go.
I would go the "big inch - low rpm" route. I would build a 540-598 and never turn it over 6000 rpm. The block could be the cheaper blueprint block and all the stock parts will fit.
Valvetrain will be cheaper. Not as easy to destroy parts with a low rpm torquer.
Just an all-around more fun car.
Build a sleeper and put 396- 350 hp stickers on it. No wild cams- just killer torque.
post #28 of 35 (permalink) Old Apr 24th, 19, 8:01 AM
Anyone that knows anything can pick out a tall deck engine faster than you can tell them it is a factory engine. If you try to fake it you will get nailed.
mrpaticular is offline
post #29 of 35 (permalink) Old Apr 24th, 19, 9:49 AM
That would never work.... 555" 6000 rpm shifts = 1.31, 9.89 @ 132
66 chevelle
New Combo
555
10.2 comp
Straub ProMaxx heads
Straub solid roller
TH400/373
3815lbs
1.31 60'
[email protected]
[email protected]
https://www.youtube.com/watch?v=Ib53PMc3HVw
https://www.youtube.com/watch?v=nlnUpBdEsQU
B433 is offline
post #30 of 35 (permalink) Old Apr 24th, 19, 11:22 AM
Beth
The blueprint short blocks are std decks
454 engine build options and questions bwiencek Engine 11 Sep 30th, 16 9:50 PM
BBC street/strip build critique & questions steigst Engine 7 May 6th, 16 6:13 PM
572 questions Proxyl Engine 0 Mar 10th, 14 3:03 PM
Correct oil pan for 572 in '66 ? Surfin' 66 Engine 0 Jul 24th, 13 3:05 AM
68 build with lots of questions... 5004man Chevelle Tech 2 Dec 5th, 12 12:05 AM
