Oil Pan Selection Help - Chevelle Tech
 5Likes
  • 1 Post By nashville beth
  • 2 Post By GuysMonteSS
  • 1 Post By mrpaticular
post #1 of 13 (permalink) Old Apr 17th, 19, 10:53 AM Thread Starter
I'm looking for a higher than stock capacity oil pan for a hot street Chevelle. I'm a little worried that I'll buy one and the thing won't fit because I've read a lot of bad stories. Does anyone have experience with a 7 qt pan? Maybe a double kick out so the pan isn't so low its in danger of hitting small bumps in the road? Prefer passenger side dipstick. The car is a 1970 Chevelle SS396 with headers. Thanks.
Oreo C is offline
post #2 of 13 (permalink) Old Apr 17th, 19, 11:28 AM
Beth
Re: Oil Pan Selection Help
7 qts is huge. Summit makes a nice 5 qt pan.
https://www.summitracing.com/search/...rder=Ascending
Jebchevelle likes this.
nashville beth is offline
post #3 of 13 (permalink) Old Apr 17th, 19, 11:59 AM
Guy
The Moroso # 20403 is a popular one,and I'm pretty sure that it fits Chevelle's.
https://www.summitracing.com/int/par...elle/year/1970
Guy
badrad and Jebchevelle like this.
'86 Monte SS,
513 Stroker,
AFR CNC'd 315 heads,
Isky .904 EZX Roll lifters,
9 inch rearend,
TC Member # 4921
GuysMonteSS is offline
post #4 of 13 (permalink) Old Apr 17th, 19, 5:19 PM Thread Starter
Does this seem like a decent pan for my application:
1970 CHEVROLET CHEVELLE Dorman Oil Pans 264-161
https://www.summitracing.com/parts/r...model/chevelle
Its a 5 quart +filter. What I have now is about 7 total and it was custom. Problem was that it sat too low and would take damage from any bumps in the road so to speak.
Oreo C is offline
post #5 of 13 (permalink) Old Apr 18th, 19, 7:07 PM
Beth
The dorman is a good pan but the summit looks the same for half the price.
https://www.summitracing.com/parts/s...model/chevelle
post #6 of 13 (permalink) Old Apr 19th, 19, 1:33 PM
you did not say what engine. if it is a 396 there are alot of pans that are ok. if it is stroked oil control is huge and i talk from experience believe me.
Mike 70SS is offline
post #7 of 13 (permalink) Old Apr 19th, 19, 4:11 PM
jerry
If you decide on a higher end pan that has welded structure, do yourself a huge favor and powder it with flour and fill the pan with solvent BEFORE install. It's all too common for them to leak.....happened on my moroso pan and I had to fight for an "in store partial credit"
cheveslakr is offline
post #8 of 13 (permalink) Old Apr 19th, 19, 4:37 PM
VortecPro, Mark Jones modifies the moroso kick out pan. Get with him. I have one in my 69, 2"primaries, easy access to filter and starter.
GuysMonteSS likes this.
mrpaticular is offline
post #9 of 13 (permalink) Old Apr 19th, 19, 8:04 PM
Beth
This 6 qt from Mr Gasket fits a 70 Chevelle.
https://www.summitracing.com/parts/m...model/chevelle
Where do the rods on a 4.25 stroker tend to hit the oil pan ?
None of the pans that say they are "clearanced" look any different than the other pans ?
I would like to use this pan but it says it's not clearanced for a stroker.
post #10 of 13 (permalink) Old Apr 20th, 19, 7:41 PM
they can hit along the sides where the pan meets the block or in the center of the shallow part of the pan. 4.25 motor will likely have issues. Check out the Moroso pans like this:
https://www.moroso.com/chevrolet-big-block20406/
with this pump and pickup assembly:?
https://www.moroso.com/oil-pump-and-...-package22185/
they also have a straight sided pun similar and an if you are still of the "drown it in oil" persuasion there's a couple HP/HV versions. If you build your engine right there's no need for the HP/HV deal. More is not always better with oil and stroker cranks.
post #11 of 13 (permalink) Old Apr 21st, 19, 11:15 AM
Beth
I see now where the "stroker-clearanced" pans have side notches to clear the rods.
This Moroso pan isn't as expensive as it looks ($266) considering it has a screen windage tray and scraper included. It might be the same pan you linked to.
https://www.summitracing.com/parts/mor-20403/reviews/
My oil pump is a mellings standard volume with a high pressure blue spring if I remember correctly. That was the best setup I was told to use years ago by guys on here (maybe you and wolfie, LOL)
post #12 of 13 (permalink) Old Apr 21st, 19, 2:10 PM
Todd
Factory pan works great
tday815518 is offline
post #13 of 13 (permalink) Old Apr 21st, 19, 11:53 PM
still is. Moroso has some decent pan/pump/welded pickup setups if you need the stuff. These pans are well known to be good due to wolfie and others using them over the years.
Oil Extreme Concentrate Additive - Put to the Test 540 RAT 2013 17 Nov 29th, 17 6:37 AM
What oil do you use BrocLuno Performance 159 Feb 14th, 17 12:22 PM
Engineering Test Data on "High Mileage" Motor Oils 540 RAT Performance 26 Dec 9th, 15 8:13 PM
Who Uses ZDDPlus? rocks66ss Performance 44 Feb 18th, 13 8:07 AM
