got it running! - Chevelle Tech
 26Likes
post #1 of 45 (permalink) Old Apr 17th, 19, 8:02 AM Thread Starter
Kris
got it running!
I got it running! I need to adjust the throttle linkage better and the test out the temp gauge but other than that it seem good!
I also need to install a second battery,,
13-1 compression 482 BBC (.125 bored over block filled)4 bolt main with good forged solid internals, square port heads, big solid roller camshaft ([email protected] intake/[email protected] ex .761 lift intake .707 exhaust 109 LSA),Weiand team G with 4150 flange, Holley model # 0-9380 850 cfm, 2 inch primary Hooker super comp headers with 12 inch collector extensions, TH-400 fully manual VB, Freakshow 4000 stall converter,4:10 gears
best time so far in the 1/8 May 18 2019 [email protected]
hear it running
MonteMan454 is offline
post #2 of 45 (permalink) Old Apr 17th, 19, 12:31 PM
Re: got it running!
why do you need a second battery?
post #3 of 45 (permalink) Old Apr 17th, 19, 12:59 PM Thread Starter
Kris
Re: got it running!
Hello Tom, when cranking is loosing too much voltage.. I had a post in the electrical section that explains it better..
https://www.chevelles.com/forums/27-...l#post11064814
hear it running
post #4 of 45 (permalink) Old Apr 17th, 19, 4:26 PM
Re: got it running!
Sounds good. What 4150 adapter did you use on that Team G? I have one but all I have is the 2" adapter and it's kinda tall.
68Chevele is offline
post #5 of 45 (permalink) Old Apr 17th, 19, 9:37 PM
Re: got it running!
I would get better battery cables seems there is too much drain when cranking, since that is the case your gonna always be chasing a electrical problem, what type of wire and what size is feeding the starter? what is the ground wire size and type? you have a very high draw in the system. is the fuel pump electric? is it running when your cranking the engine?
78 Malibu, 402, eddy heads, 174 B&M blower, th350, holley sniper EFI, 9" 3:70, 26X8.50-15 slicks.
96 chevy 1500, tow vehicle.
03 yz85 fun bike.
04 scion XB daily driver.
Jebchevelle is online now
post #6 of 45 (permalink) Old Apr 18th, 19, 7:23 AM
Check wire resistance and run a ground to the battery.
I had this problem myself once.
Option is to run the ignition box only from a small battery so it see only 13volts and no starter drain. Good luck
1968 hot rod is offline
post #7 of 45 (permalink) Old Apr 18th, 19, 8:12 AM Thread Starter
Kris
Re: got it running!
Hey guys, I actually didn't use a adapter; the carb and manifold both use the 4150 series flange. ( I need to change my stats )
I am using the thickest welding cable I could buy as a cabling, all the way to the starter
https://www.princessauto.com/en/deta...t-/A-p8228041e
I have 3 grounds with the same cables size attached to the frame..2 from the engine and 1 to the frame..
-I would like to try a ground from the negative post of the battery to the starter at some point and see if it makes a difference.
-Perhaps 90 amp Ford style solenoid might be giving me some problems or the 150 amp cut off switch? I don't know if the lower amperage rating on these items might give me a voltage drop?
To start the engine I turn on the pump to fill the bowls and then turn it off..I then turn over the starter and hit the IGN..
I went to a battery store last night and learned a lot. If I wasn't looking into short term solutions I would get a Northstar AGM battery, they initially give a lot of cold cranking for a few seconds and then steady down to a lower level. This engine was using a Optima red top battery to start it before that uses the AGM technology. My 78DT we cell battery is probably damaged due to being worked below 10 volts..
A separate battery for the IGN system might be a good option as well, for now I will try the 2 battery method..
hear it running
post #8 of 45 (permalink) Old Apr 18th, 19, 8:18 AM
Re: got it running!
I would try using larger battery cables before going to a 2nd battery. My $0.02 is that the second battery is just masking a voltage/amp drop problem.
https://www.wiringproducts.com/battery-cable
lucifershammer is offline
post #9 of 45 (permalink) Old Apr 18th, 19, 11:23 AM
Ground side resistance?
post #10 of 45 (permalink) Old Apr 18th, 19, 12:16 PM Thread Starter
Kris
Re: got it running!
If I have some time this Easter weekend; I will use booster cables to ground the battery right to the starter..that might show some problems.
I have to adjust throttle linkage (pedal needs more travel), install another temp gauge, etc
hear it running
post #11 of 45 (permalink) Old Apr 18th, 19, 3:20 PM
Greg.
Re: got it running!
Glad my Power Pack helped you start it .
In the 80s my Winter Car had two Batteries as the 318 ci Dodge Monaco would not turn over fast enough with just one
But the good part was the bugger never got stuck in a Snow Storm,
it would plough through anything since she weighed so much
67 Chevelle Malibu SS Cdn
Born 283 / PG / A51
60' = 1.664
1/8 = 7.532 et / 91 mph
1/4 = 11.814 et / 115 mph
60' = 1.547
1/8 = 7.311 et / 91.76 mph
1/4 = 11.595 et / 114.28 mph
Kirk's67SS is offline
post #12 of 45 (permalink) Old Apr 18th, 19, 7:52 PM
Re: got it running!
He is correct! Welding cable is not good for 12volt as it has too much resistance, you really need to look at the link above I quoted and see the difference, 12 volt battery specific cable looses less amps and voltage over distance then welding cable, many a racer has chased voltage drop due to using welding cable instead of proper 12volt cables. Just FWIW.
lucifershammer likes this.
03 yz85 fun bike.
post #13 of 45 (permalink) Old Apr 18th, 19, 10:09 PM
Kerry
#4 is too small. Go to 2/0 and use proper battery cable. Most big truck shops will have rolls of Grote brand 2/0, and the crimper tool. Use the good heavy cable ends with the proper size 5/16” stud hole. Not 3/8”.
See what they would charge you to make some up.
I went from #4 to 1/0 and there is a huge difference in the voltage they carry.
Be sure the block is clean where the starter mounts. No paint. Battery grounded to the engine, then engine to frame from the same place on the engine. Then frame to body.
Your voltage issues will be gone.
bradley67 likes this.
pockets is offline
post #14 of 45 (permalink) Old Apr 18th, 19, 11:23 PM
Re: got it running!
Jeb, you have it backwards.
Welding cable has more strands per inch for greater current flo vs battery cable. We also use DLO, it's very similar.
I'll take more strands per inch all day.
Double the current carrying capacity for the same size conductor.
Battery Cable - Car Battery Cable Comparison
"Everywhere. You should always know the amps your machine(s) will be using and the amp ratings of your cables.
SGX Car battery cable"
AWG Possible Stranding Amp
6 133/27 60
4 61/22 75
2 133/23 100
1 133/22 110
1/0 1064/30 140
2/0 1330/30 160
3/0 1627/30 200
4/0 2109/.010* 220
*2109 strands each with a diameter of 0.010 in.
Welding cable
6 259/30 115
4 364/30 150
2 625/30 205
1 778/30 240
1/0 990/30 285
2/0 1248/30 325
3/0 1586/30 380
4/0 2054/30 440
77 cruiser likes this.
WHT/73 is offline
post #15 of 45 (permalink) Old Apr 19th, 19, 10:01 PM Thread Starter
Kris
Re: got it running!
thanks again Greg!!
I did the negative battery cable to the starter connection and didn't notice any change as compared to no connection...
This was after I just charged the battery but I did notice it turned over much quicker for both scenarios. I had turned over the engine before after a charge before and it didn't turn over this fast??
I also changed the water temp gauge, replaced a faulty relay, put new oil oil, figured out throttle linkage. I still need to change some carb gaskets, the rear accelator pump needs to be changed..
Kirk's67SS likes this.
hear it running
Running rough 69mike327 Engine 13 Nov 3rd, 18 6:09 AM
Running hot at freeway speeds... peterskin Heating & Cooling 59 Sep 20th, 14 1:47 AM
496 BBC running hottt goods Heating & Cooling 18 Sep 13th, 13 9:08 PM
Running 210 degrees - problem? Va72Chevelle Heating & Cooling 46 Aug 26th, 13 3:33 AM
Had it with electronic fans! 70 nialator Heating & Cooling 95 Jun 8th, 13 7:34 PM
