Fuel system setup question. - Chevelle Tech
post #1 of 6 (permalink) Old Apr 15th, 19, 3:36 AM Thread Starter
I was hoping to get a little input on my setup to make sure I get it right the first time. I have a 72 chevelle, I have been doing a lot of work on it and getting it ready for this summer. I currently have a mild 468 in the car, but for next year I have a pump gas 540 for it. The car will stay pump gas, and will primarily be a street driven with trips to the track on some weekends. For the fuel setup I have a sumped tank, and am installing a Mallory 250 pump, thru a relay located in the trunk not far from the batt. I have an inline 40 micron filter before the pump, and another 40 micron filter up front going to the fuel log. I am running a bypass regulator to a HP950. I know this system is overkill for the 468, I tend to over do everything for the 468 I have, but am building it to handle the next engine going in the car. My question is what size fuel line should I run, I am thinking -8 supply and return from back to front would be sufficient, but want to be sure, I can also do -10 supply and return from the rear to the reg, and then branch down to -8 feeding the carbs, but not sure if that is too much? Not really sure if there is such a thing as too much to be honest, just wanting to get input on the setup, from more experienced guys. Thanks fellas
Ronnie
Raron455 is offline
post #2 of 6 (permalink) Old Apr 15th, 19, 12:07 PM
Re: Fuel system setup question.
Typically you go 100 micron before the pump and 40 micron or smaller after the pump.
-10 to the regulator won't cost much more and will ensure plenty of room to grow. -8 as a return from the bypass regulator is fine. But -8 to and from the regulator will work just as well.
-8 to the bowls is fine, really -6 is fine. The flow through a single .150 needle and seat is much smaller than the -6 line itself.
1967 Chevelle Malibu 4 door
The 7.99 at 173mph pass:
8.02 at 171mph:
Calculated Risk is offline
post #3 of 6 (permalink) Old Apr 15th, 19, 1:24 PM
I agree with all of this. 10 doesn't cost much more than 8, but 8 would work on a street car. I ran #10 to the regulator and 8's to the carb though 6's will work there as well due to the small flow. My car made almost 1000 hp on that setup as well.
Ray
bracketchev1221 is offline
post #4 of 6 (permalink) Old Apr 16th, 19, 12:22 AM Thread Starter
Thanks Fellas, I will feed -10 supply and return to the regulator. I went with a 40 micron pump inlet filter because the Mallory is a gerotor style pump, I was reading it was recommended to run a finer filter than the 100 for this style pump because it can clog and bind easier than a rotary vane style pump. hope the 40 is not too fine of a filter,
Raron455 is offline
post #5 of 6 (permalink) Old Apr 16th, 19, 1:56 AM Thread Starter
No sir, a 40 micron filter will catch much smaller particles than a 100 micron filter will
40 micron = .00157 inch
100 micron = .00393 inch
Raron455 is offline
post #6 of 6 (permalink) Old Apr 16th, 19, 2:01 AM
Yeah I was trying to flip it around, after I posted. sorry
Mike Lewis street 572
Cale Aronson
Black Magic clutches
Cam by UDHarold
Menscer Motorsports
TRZ
CEAutoelectric
aukai is offline
This Thread is more than 486 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
Fuel System Cleaner - Real World Experience... 1971-Chevelle Bench Racing 4 May 30th, 18 2:57 PM
Electric fans/aluminum radiators/real lowdown oktunes Heating & Cooling 184 Jun 26th, 16 10:33 AM
69' Fuel system replacement hdw1679 Chevelle Tech 6 Apr 15th, 14 8:37 AM
Fuel system setup questions? 70ssclone Engine 0 Dec 24th, 13 6:49 AM
Fuel system question Pringle Performance 11 Jan 30th, 13 8:18 PM
