Thermostat bypass hole - Chevelle Tech
 19Likes
post #1 of 33 (permalink) Old Apr 13th, 19, 1:58 PM Thread Starter
I have a thermostat that looks like this:
where would I drill the bypass hole? I found some EMP ones that have them drilled on the side, would that be correct?
-SS454- is offline
post #2 of 33 (permalink) Old Apr 13th, 19, 2:25 PM
Re: Thermostat bypass hole
This is the only picture I found for that type. Not sure if it's correct for this application, but looks like it.
https://www.speedwaymotors.com/Speed...stat,1836.html
Mike Lewis street 572
http://www.lewisracingengines.com/
Cale Aronson
Black Magic clutches
http://www.blackmagicclutches.com/
Cam by UDHarold
Menscer Motorsports
http://menscerms.com/
TRZ
https://www.trzmotorsports.com/
CEAutoelectric
https://ceautoelectricsupply.com/
My Showroom
aukai is offline
post #3 of 33 (permalink) Old Apr 13th, 19, 2:47 PM
The bypass hole should be in line with water flow. Just my thought.
mrpaticular is offline
post #4 of 33 (permalink) Old Apr 13th, 19, 3:04 PM
You can go here too.
77 Monte
11.93 @ 112.7 & tuning
http://myweb.midco.net/77cruiser/
77 cruiser is offline
post #5 of 33 (permalink) Old Apr 13th, 19, 6:59 PM
why not just buy one that fails open? or is there another reason for the bypass hole?
DragRac69 likes this.
78 Malibu, 402, th350, 2400-2600 stall, holley sniper EFI, 9" 3:70, Hoosier 26X8.50-15 slicks.
69 VW baja 1600cc. about to have fun banging gears.
96 chevy 1500, tow vehicle.
02 vw beetle daily driver
Jebchevelle is offline
post #6 of 33 (permalink) Old Apr 13th, 19, 11:57 PM Thread Starter
I've had 2 fail. Regardless of packaging name, they all seem to come from the same manufacturer. So now I will try a bypass to see if anything changes.
-SS454- is offline
post #7 of 33 (permalink) Old Apr 14th, 19, 1:58 AM
I use the bypass thermostat to eliminate the bypass hose, I've had good luck with thermostats, but that was awhile ago. New ones maybe different.
rp930 likes this.
Cale Aronson
Cam by UDHarold
Menscer Motorsports
TRZ
CEAutoelectric
My Showroom
aukai is offline
post #8 of 33 (permalink) Old Apr 14th, 19, 5:58 AM
Geoff
First, unless you are using a race pump that has no bypass, or you have blocked the bypass [ why would you? ] there is no reason to drill holes in the stat. Stewartcomponents.com started the drilled stats because some of their pumps had no bypass.
Drilling the stat will just make the engine take longer to warm up....not good.
If you look at the pic in post #4, at about the 10 o'clock position, you can see the dimple in the rim that that lets the air purge. Once again, no need for holes.
Failures. The problem I have had is that there is a rubber seal on the inner piston that is tight. When new, sometimes the stat won't open because of this. I put some auto trans fluid in there to lubricate it & test it for on/off on the stove a couple of times. Seem to work ok once they have open/closed a couple of times.
Gtogeoff is online now
post #9 of 33 (permalink) Old Apr 14th, 19, 8:45 AM
That's a pill thermostat, I had nothing but trouble with them. The Stant Hi flow works the best for me.. I drill a very small hole in my thermostats to keep the stat surrounded in moving water..
hydro462 is offline
post #10 of 33 (permalink) Old Apr 14th, 19, 9:01 AM
Autozone Hi-flow works for me. Only accurate one I found out of several brands including pill type on a stove. I do drill a small hole for bleeding.
rlowe likes this.
69 461" BBC 11.25:1 Compression
Orig Exhaust Manifolds
Straub (Clay Smith) Hyd Roller cam, 288/300 .600/.569 109.
TH400, 3500 stall, 4.11 12 bolt posi
rp930 is offline
post #11 of 33 (permalink) Old Apr 14th, 19, 3:37 PM
Small 1/16 hole wherever you can get it to let the air bleed by.
It won't effect warm up time with a 1/16" hole, but the 1/16" hole will help prevent an air pocket
hydro462 likes this.
1967 Chevelle Malibu 4 door
http://s145.photobucket.com/albums/r...ton/?start=all
The 7.99 at 173mph pass:
https://youtu.be/SIF0dosu-7s
8.02 at 171mph:
https://youtu.be/hH3PS_TrHOc
Calculated Risk is offline
post #12 of 33 (permalink) Old Apr 15th, 19, 12:49 PM
w/calculated risk. Been using MIlodon hi flows since the 80s, finally had one stick about a month ago probably from sitting too long. It let loose and works fine, gotta drive these things.
cuisinartvette is offline
post #13 of 33 (permalink) Old Apr 15th, 19, 1:56 PM
Back in the day, the top shelf thermostat was an all brass 180 degree Robert Shaw unit. Iím not sure if they still make them but I have one in my car and a spare in itís original box on a shelf. ()
I installed a 55GPM electric pump on my car that has no heater hose inlet or manifold bypass hose inlet. Because of that and that Iíll never drive it in the cold, I decided to eliminate the heater lines.
I was concerned that SOME coolant needs to bypass the thermostat upon cold startup, I added a few holes in the perimeter of the thermostat. It seems to work as the engine gets to operating temp fairly quickly and it settles around 180 degrees. Then the fans cycle on & off by the fuel injection system.
I remember seeing holes in a thermostat like I did in some magazine article from long ago. It seems some old tricks still work.
Jeff65SS, 427L88 and boyd66k20 like this.
LS1tech.com supermoderator.
How may I help you?
1999 Trans Am-500hp
paul bell is offline
post #14 of 33 (permalink) Old Apr 15th, 19, 1:58 PM
Naw, some of us do it so all the "burps" of air escape the block much faster. Otherwise the closed thermo blocks escaping air ( high point on engine) . So there is reason #1 anyway. And it makes a world of diff .
Molly's 70, paul bell and rp930 like this.
post #15 of 33 (permalink) Old Apr 15th, 19, 6:08 PM
I've never drilled a hole in a thermostat.
I have a feeling that some people do it just because they read that other people did it, not because a hole is actually needed.
454 Head bolt hole thread repair - critique. chrisstandring Performance 40 Dec 16th, 16 12:27 AM
center hole size on ralley wheels il69smbk48 Wheels & Tires 2 Aug 26th, 16 11:47 PM
How do you block the oil filter bypass? ToocoolZ28 Performance 91 Aug 21st, 16 7:34 PM
Thermostat bypass davlac89 Engine 10 Aug 24th, 14 10:20 AM
Picture(s) Needed Cowl Drain Hole to Rocker Panel LevonH Body Shop 3 Feb 10th, 14 12:31 AM
