comp cams gold - Chevelle Tech
 49Likes
post #1 of 81 (permalink) Old Apr 8th, 19, 11:00 AM Thread Starter
Javier
comp cams gold
looks like im done with comp cams gold, its the second time its happened, anyone else having problems with this? and what other one (brand) would you recommend? thinking of going with steel instead if aluminum
JJ71CHEVELLE is offline
post #2 of 81 (permalink) Old Apr 8th, 19, 12:03 PM
Re: comp cams gold
Originally Posted by JJ71CHEVELLE View Post
Attachment 591092
Made by Scorpion.
Chris Straub
Mfg Performance Parts
www.straubtechnologies.com
www.distributorgears.com
cstraub is offline
post #3 of 81 (permalink) Old Apr 8th, 19, 12:38 PM
Vince
Re: comp cams gold
2nd time? Check your piston to valve clearances, retainer to seal, coil bind, geometry, retainer to rocker etc etc
427L88, fishhead and JJ71CHEVELLE like this.
*69 SS 502 EFI /224* HR/9.8:1/T56/3.90 11.5/124mph
*11 C6, 6.2, 6spd
*96 Stang 6.0 turbo 10.5/135mph
*61" Scag Kohler 22hp 7mph
***In progress...04 Mustang, 454, TKO***
69-CHVL is online now
post #4 of 81 (permalink) Old Apr 8th, 19, 1:00 PM
TKG
Terry
Re: comp cams gold
2nd time, same cylinder??
TKG
64 Malibu Coupe
283, Fitech
2004r, 4w discs
TKG is offline
post #5 of 81 (permalink) Old Apr 8th, 19, 1:27 PM
Re: comp cams gold
What length pushrod and what diameter pushrod?
Chris Straub
cstraub is offline
post #6 of 81 (permalink) Old Apr 8th, 19, 1:33 PM
Marcus
Re: comp cams gold
If its second time check what other suggested, quality rockers shouldnt brake like that.
I like crower Stainless Steel endurance roller rockers or comp chrome moly steel pro magnum.
Dont the comps have lifetime warranty?
Chevelle Malibu ss 64
Th 400 Edge 9.5" converter
Malibu ss 64 is offline
post #7 of 81 (permalink) Old Apr 8th, 19, 1:49 PM
Greg
Re: comp cams gold
Yeah that's binding, did you cut down the top of the valve guide any?
"A Nation of Sheep will beget a Government of Wolves." Edward R. Murrow
“The last official act of any government is to loot the treasury.” – George Washington
http://s146.photobucket.com/albums/r241/gregs_photo/
2cool is online now
post #8 of 81 (permalink) Old Apr 8th, 19, 2:24 PM Thread Starter
Javier
Re: comp cams gold
diffrent cylinder
post #9 of 81 (permalink) Old Apr 8th, 19, 2:25 PM
Re: comp cams gold
is the gold coating still in good shape? or look something like this?
Name:	rocker arm coating (1).jpg
ID:	591110   Click image for larger version
Name:	rocker arm coating (2).jpg
ID:	591112   Click image for larger version
Name:	rocker arm coating (3).jpg
ID:	591114   Click image for larger version
Name:	rocker arm coating (4).jpg
post #10 of 81 (permalink) Old Apr 8th, 19, 2:32 PM Thread Starter
Javier
Re: comp cams gold
no i didnt
post #11 of 81 (permalink) Old Apr 8th, 19, 2:34 PM Thread Starter
Javier
Re: comp cams gold
nothing like this...
gold coating is still good
post #12 of 81 (permalink) Old Apr 8th, 19, 2:37 PM Thread Starter
Javier
Re: comp cams gold
have to check on length and diameter, motor was put together years ago, and springs were upgraded to match cam lift
post #13 of 81 (permalink) Old Apr 8th, 19, 2:38 PM
Re: comp cams gold
I'm with Marcus, I think Crower is about the only vendor left making their own stuff here in the USA. Maybe Harland Sharp, But personally, (IMO) they're not in the same category as Crower. I think the nice shaft setup like T&D and Jesel are still from here in the US. Pricing tells the story right away.
Javier, how much lift and valve spring on that deal? Were all the clearances checked, like retainer to guide/seal? is the rocker damaged by contacting the retainer at all?
A post in this thread is reported as vendor bashing but I don't see it that way. it was #2 by Chris. I don't see that as bashing.
post #14 of 81 (permalink) Old Apr 8th, 19, 2:40 PM Thread Starter
Javier
Re: comp cams gold
everything looks fine , but i will check it again
post #15 of 81 (permalink) Old Apr 8th, 19, 2:49 PM Thread Starter
Javier
Re: comp cams gold
need to look for cam card, but lift is 700 plus, springs were upgraded for this lift, and rocker isn't contacting retainer, will check retainer to guide and coil bind
comp cams 11-456-8 camshaft Jebchevelle Performance 22 Dec 12th, 17 10:29 PM
Comp XOS circle track cams pockets Performance 6 Nov 2nd, 17 9:17 AM
COMP Cams® 4-Pattern Camshafts Steve439 Performance 23 Dec 10th, 12 7:15 PM
Comp Cams Nostalgia Plus? AscotBlue'71 Performance 21 Sep 27th, 12 7:11 PM
Comp Cams flywheel 1999 -- 13 Nov 5th, 99 10:02 PM
