comp cams gold - Page 3 - Chevelle Tech
 49Likes
post #31 of 81 (permalink) Old Apr 9th, 19, 7:22 AM
Re: comp cams gold
I love these, but there's ALOT to love. $$ https://www.summitracing.com/parts/cro-73605-16
post #32 of 81 (permalink) Old Apr 9th, 19, 8:03 AM
Re: comp cams gold
Do you know the history of the engine? What is the piston to valve clearance, vertically and radially. When did the last rocker break?
bracketchev1221 is offline
post #33 of 81 (permalink) Old Apr 9th, 19, 11:06 AM
Re: comp cams gold
Originally Posted by JJ71CHEVELLE View Post
https://www.summitracing.com/parts/cca-7951-1
rocker tips rolls right at the center of the valve
How wide is the sweep? If more than .060" the pushrods are too short.
Chris Straub
Mfg Performance Parts
cstraub is offline
post #34 of 81 (permalink) Old Apr 9th, 19, 11:49 AM
Vince
Re: comp cams gold
everything looks fine , but i will check it again
"Looks" or actually is fine?? 700 lift cam is a pretty good size and has some duration, meaning less p/v clearance.
I would guess that retainer to seal should be ok being an aftermarket head. Coil bind could be an issue with 700 as that's what some springs are rated for.
Even if the pushrods were slightly too long or short, I can't see that breaking rockers. Somethings really binding up here.
JJ71CHEVELLE likes this.
*2011 Mustang GT premium
*61" Scag Kohler 22hp 7mph
69-CHVL is online now
post #35 of 81 (permalink) Old Apr 9th, 19, 12:14 PM
Gary
Re: comp cams gold
Hi Gene, yeah Mark likes these too but I had the Comp Cams Hi Tech Stainless ones that look virtually identical to these and broke them. So that's why I went with the Ultra Pro Magnum, they are rated to 850lbs open spring pressure. There is a Comp Cams Ultra Pro Magnum XD that is rated to 1000lbs that may be better for .700 lift for OP.
1970 Chevelle 454 M22 4.10
1970 El Camino 350 TH350
2014 Corvette Convertible LT1 Auto
2016 2500HD Duramax Allison
CRV CRW is offline
post #36 of 81 (permalink) Old Apr 9th, 19, 1:18 PM
Re: comp cams gold
I ran Crane "energizers" before and decided that the Crowers were the answer. And this with light pressures and only .610" lift. I'm not big on alum bodies.
post #37 of 81 (permalink) Old Apr 9th, 19, 1:39 PM
Re: comp cams gold
Short pushrod will leave a wide sweep pattern. This will "work" the valve and increase the clearance in the valve guide. Going unchecked this will create added harmonics in the valvetrain.
Pushrod flex, just like a pole vaulters pole, the stored energy the pushrod release on the closing side of the lobe will send harmonics into the valvetrain.
Not saying either one of these is the cause, but can be contributors to a very unhappy valvetrain.
Chris Straub
cstraub is offline
post #38 of 81 (permalink) Old Apr 9th, 19, 2:28 PM
Greg
Re: comp cams gold
Reading through my old trusty "How to hot rod a big block" book it list aluminum rockers used by professional racers as having a life span of just 6 hours! it may just be metal fatigue.
2cool is offline
post #39 of 81 (permalink) Old Apr 9th, 19, 4:49 PM
Re: comp cams gold
Mercury Marine factory installed Crane Gold on the Blue motors. Ford installed them the factory Cobra Mustangs in the late 80's and 90's.
427L88, Wolfplace and rp930 like this.
Chris Straub
cstraub is offline
post #40 of 81 (permalink) Old Apr 9th, 19, 5:05 PM
Re: comp cams gold
Javier
These are the AFR heads correct?
If so I can all but guarantee that with the stock Comp rockers if the pattern is in the middle of the valve the pushrods are too short & the geometry is incorrect
In lieu of the backset Crowers The Crane Gold were the better rocker for many years because they had a shorter pivot length
Now the rocker to use is either the custom ones you can get from myself, Chris or direct from AFR for aluminum
Or the backset Crower which I also have but they are not exactly budget friendly
Malibu ss 64 and JJ71CHEVELLE like this.
Mike (Wolfplace)
VISIT US AT
----John Wayne----
Wolfplace is offline
post #41 of 81 (permalink) Old Apr 9th, 19, 5:42 PM
Re: comp cams gold
Something tells me these arent the same metallurgy, other than the gold anodized finish.
Malibu ss 64 and rp930 like this.
post #42 of 81 (permalink) Old Apr 10th, 19, 10:17 AM
Re: comp cams gold
Same extruded bar as all other Crane rockers, they were the wide body design and had more area.
427L88 likes this.
Chris Straub
cstraub is offline
post #43 of 81 (permalink) Old Apr 10th, 19, 11:57 AM
Re: comp cams gold
Have you measured the sweep pattern on the tip of the valve?
Chris Straub
cstraub is offline
post #44 of 81 (permalink) Old Apr 10th, 19, 1:54 PM
Greg
Re: comp cams gold
For its tensile strength, 6061 (T651 Bare) is listed at 45,000 psi, with a yield point of 40,000 psi. The Brinell hardness is rated at 95. The elongation at break is 12% and shear strength is 31,000 psi. 6061 has a thermal conductivity of 170 W/m-K. And finally, its strength to weight ratio is rated at 115 kN-m/kg.
Spring Rate = (273 – 105) ÷ 0.450
Spring Rate = 168 ÷ 0.450
Spring Rate = 373 lbs./in.*
*Comp Cams lists the spring rate at 370 lbs./in.
To me just pushing the valve too much to the side would result in wearing out the guide more than breaking the rocker, I suspect the rocker is hitting something to cause enough force to break it and it is hitting hard by looking at the break.
2cool is offline
post #45 of 81 (permalink) Old Apr 10th, 19, 5:28 PM
Re: comp cams gold
Bottom line, this engine is not happy and it needs to come apart. I would say it will be found that there is a combination of issues all contributing to parts failing. It's not the parts fault, its just the weakest link in the system.
Chris Straub
cstraub is offline
comp cams 11-456-8 camshaft Jebchevelle Performance 22 Dec 12th, 17 11:29 PM
Comp XOS circle track cams pockets Performance 6 Nov 2nd, 17 10:17 AM
COMP Cams® 4-Pattern Camshafts Steve439 Performance 23 Dec 10th, 12 8:15 PM
Comp Cams Nostalgia Plus? AscotBlue'71 Performance 21 Sep 27th, 12 8:11 PM
Comp Cams flywheel 1999 -- 13 Nov 5th, 99 11:02 PM
