Header Help - Chevelle Tech
  • 1 Post By blasttime
post #1 of 6 (permalink) Old Mar 26th, 19, 7:31 PM Thread Starter
Header Help
69 Chevelle 396/4speed, no a/c. I’d like to replace rusty cast iron manifolds which dump to Pypes system.
Are there some header style ceramic coated or stainless manifolds that are direct replacement for my cast iron stockers ?
This is not so much a performance car, so not concerned w/equal length or long tube headers.
I live in a small community no local access to custom exhaust shop. Need direct replacement
Reelysalty is online now
post #2 of 6 (permalink) Old Mar 26th, 19, 8:05 PM
Re: Header Help
Remove manifolds get them blasted and paint them
lucifershammer likes this.
blasttime is offline
post #3 of 6 (permalink) Old Mar 27th, 19, 7:38 AM Thread Starter
I’d rather labor for an improvement and not a continuous cycle of remove paint and reinstall.
post #4 of 6 (permalink) Old Mar 27th, 19, 8:44 AM
Re: Header Help
There are several shorty headers out there to choose from. Iím not sure though if any will just bolt up to your stock exhaust pipes. Iím guessing that a lot will though. Youíll have to check with individual manufacturers.
BUT... Iíd point you toward ceramic and away from stainless when you make the jump. After having gone down both roads Iím really surprised at just how much better ceramic coated headers keep the heat in the system rather than radiating it out under the hood. And unless you like gold/blue/purple look that stainless will soon take on, the ceramics will stay whatever color they start at.
any4xx is offline
post #5 of 6 (permalink) Old Mar 27th, 19, 9:57 AM Thread Starter
Originally Posted by any4xx View Post
BUT... I’d point you toward ceramic and away from stainless when you make the jump. After having gone down both roads I’m really surprised at just how much better ceramic coated headers keep the heat in the system rather than radiating it out under the hood. And unless you like gold/blue/purple look that stainless will soon take on, the ceramics will stay whatever color they start at.
😁 Thanks, good point on stainless. Not such a fan of gold/blue/purple !
post #6 of 6 (permalink) Old Mar 28th, 19, 9:24 AM
Re: Header Help
There are NO direct fit shorty headers that will bolt in place of your manifolds and hook up to your exhaust.
A simple choice would be if you don't want any down time,is buy a pair of brand new repro exhaust manifolds and have them send out to be coated,inside/out (there are small HP gains to be had just from them being coated internally) and install them yourself at your leisure.
mr 4 speed is offline
This Thread is more than 375 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
What kind of gaskets and header bolts on 496? FAT SACK Engine 6 Jan 24th, 18 4:01 PM
Header on engine crossmember Slick71ss Performance 9 Oct 17th, 16 10:53 AM
Header Fitment Doesn't Look Right RickH Performance 24 Dec 29th, 14 8:28 AM
3" exhaust to header collector question Gossamer454 Headers and Exhaust 5 Apr 5th, 14 11:11 AM
'71 Chevelle: Clutch Z-Bar hitting Header tube. Black29 Transmission & Driveline 3 May 20th, 13 11:35 PM
