Overdrive and camshaft selection - Chevelle Tech
 35Likes
post #1 of 194 (permalink) Old Mar 26th, 19, 4:10 PM Thread Starter
I haven't had a stick with a big cam in my car before. I have always had 3 speed autos built to handle the power.
Being that I am changing over to a t56 magnum, I have been thinking about how my build might work with over drive.
I feel like it should work fine, but I want some additional thoughts.
489 big block
Jegs 290 heads
Isky SFT cam
250/256 @ .050
.605/.620 lift (lash is I believe .016 and .018)
108lsa
edelbrock proflo 3 fuel injection--xt manifold(able to adjust cruise A/F ratio and have it currently set at 14.8)
long tube headers-2 inch primary/3inch exhaust
3.73 rear
I bought the magnum so I can have the benefit of both over drives as I do interstate and back road driving primarily. I take beach trips/trips down south and soon trips up north. Usually they are about 200 mile stretches.
My goal is to keep the engine sitting around 2000rpm. I currently have a th400 with a 3500 stall so I have never really gotten to experience that. At 75 right now the thing sit around 3800 on the free way. I feel like the converter slips quite a bit.
Would my cam work in this situation?
Planned cruise speeds:
55 in 5th(.8) would be 2000rpms
65 in 5th(.8) would be 2400
65 in 6th(.63) would be 1800--might work?
70 in 5th(.8) would be 2500
70 in 6th(.63) would be 2000
75 in 5th(.8) would be 2700
75 in 6th(.63) would be 2200
tacomatrd is offline
post #2 of 194 (permalink) Old Mar 26th, 19, 4:13 PM
Mr Bill
Re: Overdrive and camshaft selection
So how does the engine act now at 2000 rpm ?
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Enginerepairshop.com
Team Chevelle #100
BillK is offline
post #3 of 194 (permalink) Old Mar 26th, 19, 4:18 PM Thread Starter
It seems fine, usually the converter flashes passed that. I usually cruise at 2500rpm and up. I am not sure if the stall is causing an impression that it works great at that RPM.
Note: The only stick car I have owned was a tacoma 4 cylinder with a grabby clutch and honestly it was fun to drive.
I have driven a few stock camaros(2010+) but that is basically it.
post #4 of 194 (permalink) Old Mar 26th, 19, 4:53 PM
You’ll be fine unless your tune is not good.
255ish at .050
640ish lift
107 separation
502 big block
You won’t accelerate up any hills in 6th but will easily maintain speed and do a steady pass.
1968 Beaumont
502 big block
HP and ET not determined yet!
GoFast Beaumont is offline
post #5 of 194 (permalink) Old Mar 26th, 19, 5:45 PM Thread Starter
255ish at .050
640ish lift
107 separation
502 big block
That works for me!
Do you happen to have any videos of your car driving??
Tune should be spot on with the fuel injection.... plus I can always change it to work.
post #6 of 194 (permalink) Old Mar 26th, 19, 5:50 PM
Out of curiosity, how tall are your tires?
-SS454- is offline
post #7 of 194 (permalink) Old Mar 26th, 19, 9:39 PM
I have an 80E and is fine with my SR 262/269 at .050" in LU but have steeper gears.
I'd also be careful with your ignition advance while in od/lu.
WHT/73 is offline
post #8 of 194 (permalink) Old Mar 26th, 19, 10:22 PM Thread Starter
28 inches(28.4 to be exact)
Originally Posted by WHT/73 View Post
I have an 80E and is fine with my SR in LU but have steeper gears.
I hear you. Don't want it to ping like crazy. What's the size of your cam?
post #9 of 194 (permalink) Old Mar 26th, 19, 11:13 PM
I have a 230/[email protected] HFT 461 BBC with a T56 Magnum, 3.31 gears. 26.6-28" tall tires. I have a FiTech EFI as well.
I can low load cruise at 1200-1300 rpm when it just starts to complain. I think 1800 rpm won't be a problem for you.
-SS454- is offline
post #10 of 194 (permalink) Old Mar 27th, 19, 12:08 AM
Mark
Mine doesn't like being below 1700 cruise rpm. It will start to buck below that. The t-56 Magnum is a very nice transmission, so you'll find the right gear. I have problems at 35mph. At 35, it seems too high for 3rd and to low for 4th. My exhaust is a little loud, so I try to keep it down in town, and third gear seems too loud.
I love the way my car drives with the t-56 Magnum and the hydraulic clutch. I'm sure that you won't have any problems.
502, 600hp, hydraulic roller cam 238/[email protected] .680/.650 110LSA, Holley MPFI, hydraulic McLeod RST twin disk clutch, 4.10 gears, and 28" tires.
'69 Chevelle SS ("NOT" ON THE ROAD NOW! )
ZZ502 Short block
Holley Avenger MPFI
612HP/594TQ
MarkP is offline
post #11 of 194 (permalink) Old Mar 27th, 19, 12:10 AM
262/269 @ .050, 110, .630 net lift. 10.5 compression.
My timing was locked out at 36*
WHT/73 is offline
post #12 of 194 (permalink) Old Mar 27th, 19, 1:01 AM Thread Starter
Dang you can get it that low?? I thought about going to something with 236/242 and 0.600 lift but we will see.
I love the way my car drives with the t-56 Magnum and the hydraulic clutch. I'm sure that you won't have any problems. <img src="https://www.chevelles.com/forums/images/smilies/thumbsup.gif" border="0" alt="" title="Thumbsup" class="inlineimg" />
Interesting. I'm excited to get it in. I don't care about loud, but in your case what is the issue? Just the lug going to 4th?
Oh heck I should be alright then
427L88 likes this.
post #13 of 194 (permalink) Old Mar 27th, 19, 7:27 AM
For sure. [email protected] on a 439 ci and it can easily cruise at 2200-2000 rpms. Not much below tho. These are PERFORMANCE cams , so trying to run it at 1700 rpms is simply not happening. Here, vacuum advance is your friend, as full mechanical advance is not all in yet.
Ialone likes this.
post #14 of 194 (permalink) Old Mar 27th, 19, 9:58 AM
I'm still fighting mine. 55MPH is 1700 RPM and it bucks quite a bit at that speed. 60 MPH is around 1800 and it's better but it really needs 1900 + RPM to smooth out. That's also with my small 770 carb. The QF 950 is worse. The cam in it now was supposed to fix the bucking issue but it's no better than the other one. I think to run overdrive it will take something no bigger than 230 duration on at least a 110 LSA to make it nice at low RPM.
https://www.chevelles.com/showroom/s.../2/ppuser/6549
540 BB
10 to 4 comp.
Brodix Race Rite BB-2 Plus heads
Edelbrock RPM Air Gap
Quick Fuel 950 CFM Carb
Hooker Super Comp 2" primary headers
Straub hyd roller 236/[email protected] .050 646/623 107 LSA
Tremec TKO 600 .82 overdrive
3.73 Posi
William Hennke is offline
post #15 of 194 (permalink) Old Mar 27th, 19, 11:34 AM
Mark
Yes, it lugs it down. I just seems too low rpm. I made some changes to the EFI to smooth it out some, and it does run much better, but it still seems too low of rpm at 35 mph in 4th.
The beauty of the t-56 is 5th (.80) OD. At 55mph, I'm running right about 2200 rpm in 5th, which is about the same cruise rpm at 70mph. Since the speed limit is only a suggestion, I can bump the speed up to 60mph in a 55mph zone and run 1800 rpm in 6th, which seems smoother. Going slower than 55mph in a 55mph zone is out of the question! A 3.73 rear gear would make it a little more comfortable to drive at 35, 55, and 70 mph, but I still want to have fun at the track occasionally so I'll keep my 4.10 gears for now.
71350SS and tacomatrd like this.
ZZ502 Short block
Holley Avenger MPFI
612HP/594TQ
MarkP is offline
