Edelbrock X-C96 cross ram - Chevelle Tech
 9Likes
  • 1 Post By aukai
  • 2 Post By aukai
  • 3 Post By obseSSed
  • 1 Post By MarkP
  • 2 Post By 540Hotrod
post #1 of 11 (permalink) Old Mar 22nd, 19, 5:13 PM Thread Starter
Michael
Hi Chevellers,
I bought an Edelbrock X-C96 for my 582 BBC. I'm thinking about putting two TB EFI units on top of it. My 68 is still in progress so I can't check the hood clearence but I know that it will not fit.
Is it possible to modify the stock SS hood to get the intake under the SS humps? Is anybody running this setup?
Thanks,
Michael
Muckl is offline
post #2 of 11 (permalink) Old Mar 22nd, 19, 5:32 PM
Re: Edelbrock X-C96 cross ram
What is the combination, and what are your plans for the 582?
Mike Lewis street 572
Cale Aronson
Black Magic clutches
Cam by UDHarold
Menscer Motorsports
TRZ
CEAutoelectric
aukai is offline
post #3 of 11 (permalink) Old Mar 24th, 19, 7:27 AM
Jesse
Please do, I love the look of those old cross rams. Would be interesting to see results with that many cubic inches under it.
Jesse
6426yy is offline
post #4 of 11 (permalink) Old Mar 24th, 19, 8:51 AM
My 572 choked out at 6600 IIRC with 2 x 1000 cfm TBs on a regular 4150 tunnel ram. It made decent power, and torque, but it wanted more air.....
Tarheel Chevelle likes this.
Cale Aronson
Cam by UDHarold
Menscer Motorsports
TRZ
CEAutoelectric
aukai is offline
post #5 of 11 (permalink) Old Mar 24th, 19, 10:30 AM
aukai, whose throttle bodies did you use? I have a '55 Chevy truck project that I can easily fit a tunnel ram under the hood of, I want to be able to run the injection and a 4L80E trans with them. I recall seeing at least one of the new TBI companies that makes a pair for a TR.
Is there any combination that you haven't tried??
Gary Adrian
Busted Knuckles is offline
post #6 of 11 (permalink) Old Mar 24th, 19, 12:18 PM
Always enjoyed the looks of a cross ram - very cool. Post images please!
1969 Nova SS 350
EFI 407 / TKO600 / 4.11
11.41 at 121 MPH
L48M20 is offline
post #7 of 11 (permalink) Old Mar 24th, 19, 5:47 PM
Gary,Holley HP/Dominator EFI the 1000 cfm's were on a Wiend TR, and the 2000 cfm's were on a Victor Ram for the dyno. The final product is a sheet metal TR. I was extremely fortunate for Mike to agree to test, the support from Holley, and Harold for cams. Paint prison is killing me. lol
71350SS and Tarheel Chevelle like this.
Cale Aronson
Cam by UDHarold
Menscer Motorsports
TRZ
CEAutoelectric
aukai is offline
post #8 of 11 (permalink) Old Aug 7th, 19, 5:34 PM
I run an edelbrock crossram on a LS6 454. Merlin heads crane roller cam 10:1 pistons with two 500 cfm edelbrock carbs. It has a little idle issue when cold but idles fine after its hot. Great throttle response, very fast and everytime I raise the hood it draws a crowd. Its pretty cool. I did use a 4" fiberglass cowl hood to clear the carbs and air filters. You can see pics if you search the Username ObseSSed . I hope this works
https://redirect.viglink.com/?format...b%3E%20Gallery
obseSSed is offline
post #9 of 11 (permalink) Old Aug 11th, 19, 4:41 PM
Mark
If you're close, you can raise your body up slightly (about 1/2 inch) and only have to modify the fan shroud.
71350SS likes this.
ZZ502 Short block
Holley Avenger MPFI
612HP/594TQ
MarkP is offline
post #10 of 11 (permalink) Old Aug 12th, 19, 6:03 PM
System will have clearance problems with hood. If throttle bodies are used, yu MUST add spacer plates under them to plumb hot water through them from heater system, or the thing will never get hot enough to work right. Set stock hood aside, use different hood to add a shaker or cowl induction system through the hood.
Think about alternatives.
Dave Ray is offline
post #11 of 11 (permalink) Old Aug 15th, 19, 12:00 AM
JIM
I've still got the tunnel ram!! Though small for a 572...It was a TQ monster. A 'glide and some tight gears would have been killer!! JIM
ID:	600624   Click image for larger version
aukai and Tarheel Chevelle like this.
'67 Vette-555"/Gforce 5 Spd/Dana 60 IRS-3.07's
Best ET
Best MPH
200 MPH at TX Mile
"...when it's not pointing at a wall...grab a gear!"
*This Life Stuff ain't no dress rehearsal"
540Hotrod is offline
BBC Cross ram NW68SSBBC Performance 13 Mar 18th, 17 10:06 PM
Offenhauser sbc low rise cross ram intake sexy69SS What's it worth? 6 Dec 11th, 15 2:13 AM
Edelbrock STR 10 cross ram setup GotGrunt What's it worth? 21 Dec 10th, 14 1:38 PM
Big Block Cross Ram Intake JKennedy 1999 -- 1 Feb 21st, 99 11:26 AM
Cross Ram Manifold ID BillK 1999 -- 5 Jan 26th, 99 5:33 AM
