Interesting valve failure - Chevelle Tech
 14Likes
post #1 of 19 (permalink) Old Mar 21st, 19, 8:31 AM Thread Starter
Greg
This is from a buddy’s pro charged 565, happened during testing and we tore it down last night. Engine had about 6-7 330’ passes on it since everything was new. Not a cheap piece at all, “best of the best” kind of deal. Not gonna say who’s car, but it is a no prep outlaw car.
54# boost, EFI(methanol), engine died at 7800 rpm 1.7 seconds into the run. He killed it, and still coasted to a 5.50 1/8th mike et!!
Any ideas?
Greg C.
1969 Chevelle Malibu
New, waaaay overcammed 496 "The Dud"
[email protected]
Iforgot is offline
post #2 of 19 (permalink) Old Mar 21st, 19, 10:30 AM
Re: Interesting valve failure
Ouch! That stinks!
How bad is the rest of it?
Looks like it can't be good but hope I'm wrong!
WHT/73 is online now
post #3 of 19 (permalink) Old Mar 21st, 19, 11:15 AM Thread Starter
Greg
Originally Posted by WHT/73 View Post
Ouch! That stinks!
Would you believe the only damage was a few scuffs on top of a piston, where the valve fragments ended up? Fragments ended up on top of #4 piston, came from #1 intake valve. Weird stuff goes on inside an engine!!
WHT/73 likes this.
Greg C.
[email protected]
Iforgot is offline
post #4 of 19 (permalink) Old Mar 21st, 19, 12:34 PM
Are those valves steel or titanium ?
68Chevele is offline
post #5 of 19 (permalink) Old Mar 21st, 19, 1:38 PM
Wow that's good news.
I "lost" an intake bolt washer once.
I wasn't so lucky.
Beat up the head and ended up getting a knock after that.
post #6 of 19 (permalink) Old Mar 21st, 19, 3:05 PM
Cory
I'm no expert but it seems to me that the valve broke during the compression stroke on #1 and blew it into the intake and #4 sucked it in during the intake stroke. 54# of boost would have "pushed" the valve fragments to the first area of differential pressure.
Firing order 1-8-4-3 etc. #8 Had already finished it's intake stroke so #4 following close behind got the prize.
427L88, shovelrick, rp930 and 1 others like this.
dream66 is offline
post #7 of 19 (permalink) Old Mar 21st, 19, 3:25 PM Thread Starter
Greg
Kinda my theory also. Now as to WHY it broke, really no good idea on that. Titanium intakes, Iconel exhaust valves I believe, but I’m not 100% sure.
427L88 likes this.
Greg C.
[email protected]
Iforgot is offline
post #8 of 19 (permalink) Old Mar 21st, 19, 3:49 PM
They say Ti dont do long, severe duty as well as steel. ?? I have NEVER seen a valve go that way.
post #9 of 19 (permalink) Old Mar 21st, 19, 4:24 PM
Exclamation Re: Interesting valve failure
Any ideas?
Honestly, sometimes stuff just breaks. Small defect in the material that you would never see or know about would be my guess
1967 Chevelle Malibu 4 door
The 7.99 at 173mph pass:
8.02 at 171mph:
Calculated Risk is offline
post #10 of 19 (permalink) Old Mar 21st, 19, 8:08 PM
Seen this many times on Diesel engines. Problem is with in the valve. Either as Rick says a defective valve or just Ti valves being at the end of the life span with aggressive ramps slamming the valves closed at high rpms. Just Google 2012 6.7L diesel there valves look just like these and they were all defective parts and at only 3000 rpms.
rp930 likes this.
64 Chevelle 496
StevenS is offline
post #11 of 19 (permalink) Old Mar 21st, 19, 8:51 PM
Lang
You would be surprised at what can fail and look just fine from the outside. I cannot remember how many "Fan" blades I removed from both GE and Pratt & Whitney engines that when Xrayed had Metal Fatigue/Cracks, and this was from engines that were still in service, but had timed out.
langss is offline
post #12 of 19 (permalink) Old Mar 21st, 19, 9:17 PM
Bill R
My guess is that the lifters were being "tossed" at full open, caused by the lifter not following the cam lobe as result of too high RPM range and/or wrong valve springs. When this happens, the valve tends to bounce off the seat as it closes resulting in valve and/or valve seat failure.
64 Chevelle Malibu Sport Coupe (original owner) car now has 427" BB, Jerico 5-spd. trans., Dana 60 rear end.
SAE Member (25+ years)
ASE Master Certified Engine Machinist
AERA Certified Professional Engine Machinist
engineguy is offline
post #13 of 19 (permalink) Old Mar 21st, 19, 9:54 PM Thread Starter
Greg
Well..results are in-kinda.
Took #4 rod and piston out, ring lands not collapsed, really very very little “damage” at all.
Not gonna name the valve manufacturer, but they definitely want that set of intakes back and are red-labeling him a new set of intake valves, which I thought was pretty stand-up of them.
Springs are 430ish on the seat..every piece of this sucker was new 6 or 7 330’ passes ago. It honestly looks like it’s never been fired on the inside.
It’s in Scott Taylor’s ‘Track Doe’ Firebird, got a big ol’honkin Procharger on the front...
ID:	589770   Click image for larger version
Greg C.
[email protected]
Iforgot is offline
post #14 of 19 (permalink) Old Mar 21st, 19, 10:11 PM
DANG!
post #15 of 19 (permalink) Old Mar 22nd, 19, 1:26 AM
Vince
thats a strange looking break
it looks fresh
i wonder if dye penetrate would have found this defect...
VinceS427bb is offline
Valve adjustment Mild454 Engine 21 Dec 23rd, 18 10:51 AM
188 heads max potential untouched? genoapb Engine 32 Dec 21st, 18 4:41 PM
Worn valve guides...repair options? DK77TA Performance 11 Oct 20th, 18 10:04 AM
NEW - Wilwood Master cyl and Adjustable Prop valve! MCB Sponsors 10 Nov 19th, 13 12:21 PM
454 valve keeper fails, but valve not bent? CoolBlueGlow Engine 25 Dec 16th, 12 4:57 PM
