Leaking Valve Cover Gaskets - Chevelle Tech
post #1 of 3 (permalink) Old Mar 9th, 19, 2:24 PM Thread Starter
Aluminum head SB, finned cast aluminum valve covers, 5/16 cork/rubber gaskets. I can’t keep SS acorn nuts snug on SS studs. Seems every heat cycle, I have to retighten. I can’t tell if studs loosen in head, or nuts loosen onstuds.
Reelysalty is offline
post #2 of 3 (permalink) Old Mar 9th, 19, 2:28 PM
Gerry
Re: Leaking Valve Cover Gaskets
Blue loctite is your friend.
Second thought is try not to use SS to SS it will pick up and gall.
67 SS BBC
4.11's
bradley67 is offline
post #3 of 3 (permalink) Old May 8th, 19, 10:39 PM Thread Starter
Locktite on studs, changed from acorn nuts to nuts. One side sealed at 50”#, rt side took 90”#.
Valve adjustment Mild454 Engine 21 Dec 23rd, 18 10:51 AM
Mr. Gasket 182 Valve Cover Gaskets Pats70ss Engine 14 Apr 17th, 18 6:39 PM
PCV in left valve cover, do I need breather in the right? Dan Orgill Engine 14 Jun 2nd, 16 8:27 PM
Header Gaskets - LEAKING Bend.Budd Engine 24 Oct 7th, 13 6:16 PM
solid type lifters and valve lash - help needed. ChuckD396 Engine 12 Aug 20th, 13 5:03 PM
