HR cam w/ SR lifters pro's & cons - Page 4 - Chevelle Tech
 29Likes
post #46 of 61 (permalink) Old Feb 19th, 19, 10:57 PM
Jeremy
Re: HR cam w/ SR lifters pro's & cons
I sure wish VortecPro would explain why you need a BIG oil pan with those lifters. I have been running them for since 2013 with a stock oil pan, with no issues. Maybe Chris Straub could explain the issue? I hate to think I am hurting the engine.
69 Camaro SS Clone fully restored
496, Straub cam, 700R4, 3200 stall, Fitech Meanstreet EFI with Ahhhh... A/C,
3.42 12 bolt posi rear end
1bad69 is offline
post #47 of 61 (permalink) Old Feb 23rd, 19, 12:22 PM
troy
any ideas how much power is lost going to a solid roller on a hydraulic roller cam, rough estimate unnless someone dyno'd the difference
1965 Biscayne 4000 lbs 454 stock suspension
7.29 94.13 mph
1.61 60 ft
wheels in air
300stw is offline
post #48 of 61 (permalink) Old Feb 23rd, 19, 1:18 PM
Gary
Here's my VotecPro 467
4.310 x 4.00, 9.7 compression, 781 ovalport GM heads ported 2.190/1.880, reproduction GM low rise LS6 intake manifold, 780 CFM factory LS6 carb. 228/238/.553/.578/111/106 Hyd roller, solid roller lifters lashed @ .010/.012. Modified GM 4 quart oil pan, M77 oil pump. Tested on 91 octane gas. Maxima 10/40 oil. 560 HP @ 5800 RPM, 588 TQ @ 4000 RPM.
The solid lifters are going to make the cam numbers a little smaller due to lash.
You can go to the VortecPro YouTube channel and compare the various 467 builds with similar cam and hyd lifters.
There are minor variations in various details but solid lifters didn't appear to cost me too much power wise. My intake and carb lost a bunch of hp for sure, so take that in consideration too. Granted, Mark designed the build with the solid lifters in mind so he could adjust for them. Not sure exactly what it would be if you only changed the lifters?
Others can chime in but it seems nominal for solid lifters only.
mr 4 speed likes this.
1970 Chevelle 454 M22 4.10
1970 El Camino 350 TH350
2014 Corvette Convertible LT1 Auto
2016 2500HD Duramax Allison
CRV CRW is offline
post #49 of 61 (permalink) Old Feb 25th, 19, 10:29 AM
What happens to any hydraulic functioning system if it get air in it? Aeration of oil is not good for bearings or hyd roller lifters.
Chris Straub
Mfg Performance Parts
cstraub is offline
post #50 of 61 (permalink) Old Feb 26th, 19, 4:56 AM
Absolutely, we documented it three days apart, near identical weather conditions, no change but the lifters. Going from hydraulic rollers (verified with both Crane and Morel, two different motors) to solid rollers on hyd roller cams ("0" lashed dead cold) both cars picked up 2-3 mph. Conclusion was had to be bleed off due to aeration.
427L88 likes this.
Status: Car-Less
GRN69CHV is offline
post #51 of 61 (permalink) Old Feb 26th, 19, 6:51 AM
Wow. Air sucks as a lube or pneumatic media.
post #52 of 61 (permalink) Old Feb 27th, 19, 10:05 AM
Jeremy
Thank you for repsonding Chris... how is that different from any hydraulic lifter? Does that mean I need an 8 qt oil pan? Different lifter?
1bad69 is offline
post #53 of 61 (permalink) Old Feb 27th, 19, 10:45 AM
No difference. Aeration of any hydraulic system will not allow it to function correctly. This affects all lifter brands.
Chris Straub
cstraub is offline
post #54 of 61 (permalink) Old Mar 1st, 19, 10:20 AM
aRe: HR cam w/ SR lifters pro's & cons
I have 12 years of bbc hydraulic lifter experience. I have to run .I will post up when I get back .
straub pm me, I need a cam for a 550HP sbf
427L88 likes this.
78 Camaro,3495,Driven to the track.
UD Harold hydraulic roller
REC90/112
1.27
5.87 @116.76
9.24 @141.64
vp 109
1.35
[email protected]
[email protected]
Jesse 496 is offline
post #55 of 61 (permalink) Old Mar 6th, 19, 7:30 AM
I hope to soon start clocking my 12 yrs + Jesse! I'm curious as to what oil the pro builder recommends. ( I do have 3 cases of VR1 10-30)
Jesse 496 likes this.
post #56 of 61 (permalink) Old Mar 7th, 19, 12:11 PM
Not much if any under 7000 rpm IMO
Tale of the tape
496 with comp hydraulic 854s 9.71 compression
555 with howards pressure fed solids 10.4 compression (+ 60ish LBS)
496 1.39 [email protected] [email protected]
555 1.41 [email protected] [email protected]
I knew after that first night with the 9.82 we would be going back to hydraulic lifters.
REC90/112
1.27
5.87 @116.76
9.24 @141.64
vp 109
1.35
[email protected]
[email protected]
post #57 of 61 (permalink) Old Mar 7th, 19, 1:12 PM
I've seen oil aeration effect my combo.
One night near the end of the night after many passes it just blew the tires off so I zoomed down there didn't shut the car off did a hot lap pass time was ok for a soft leave and almost 200 degree water when I staged it.
I pulled my helmet off and pull up to get my slip and hear very loud tapping and clacking undrivable nasty sounding .I thought I broke a valve spring.
Great! turn if off and coasted into the grass pop the hood let it cool down and walk down to the burger stand grab a drink sit down and watch the last of the cars and Contemplate life's choices.
I'm by myself on a Wednesday night its heading toward 11pm all my friends live an hour away that have trailers and they have to work the next day.
So its Fix it ,drive home on 7 time or IDK $400.00 tow bill??
The track is out in no mans land and I live about 40 miles away. I'm sure that charge extra for midnight calls
I carry a load of tools and a lot of spare parts like extra rocker arms and poly locks etc...
Fire it up to determine what valve cover to pull. Quiet now yup it fixed itself. Pulled dipstick could see some bubbles.
If I had a cheaper oil pan the problem would have only been worse
and I want to say after installing a vacuum pump I haven't had an issue since.
REC90/112
1.27
5.87 @116.76
9.24 @141.64
vp 109
1.35
[email protected]
[email protected]
post #58 of 61 (permalink) Old May 17th, 19, 1:52 PM
troy
bringing this back up, any consensus on lash clearance for iron heads and block, hydraulic roller cam and morel solid lifters, i started with .006/.008, for a half hour breakin, now i want to check lash,
seems vortec pro had a setup with .008/.010, lookin for suggestions
7.29 94.13 mph
1.61 60 ft
wheels in air
300stw is offline
post #59 of 61 (permalink) Old May 18th, 19, 8:34 PM
Gary
VortecPro set mine at .010 and .012
CRV CRW is offline
post #60 of 61 (permalink) Old May 19th, 19, 4:49 AM
Geoff
Iron heads/iron block I would use 0.006"/0.008" cold, no more.
Gtogeoff is offline
