498 Dyno, RR270 ovals and Straub cam - Chevelle Tech
 42Likes
post #1 of 42 (permalink) Old Jan 11th, 19, 12:40 AM Thread Starter
Thor
I've been S L O W L Y gathering parts for an engine for my 69. Got it on the dyno yesterday.
I already had the heads. The cam and balanced rotating assembly came from Chris Straub, I want to thank him for listening to what I wanted and delivering EXACTLY that. I told him I wanted 600 hp with a peak at 5700 to shift at 6000, and a bunch of mid range torque. He came up with a package that delivered that. Consider me a happy customer. BTW these numbers were with 2-1/2 dyno headers. The pyro was messed up on #4 confirmed with i/r.
I know we could have made a bunch more power if i wanted more rpm, but I am building this to drive. This is going in a 69 malibu, bench seat, column shift car with a th-400, and 3.42 gear.
Any how, engine did suffer from a minor self inflicted injury that stopped us at one recorded pull attached bellow. the pull after this the power was down and it coughed. had a rocker arm stud back half way out, the rocker, stud, helicoil and push rod were fine, but it broke the guide plate.. upon further inspection there were 3 loose. Goes to show why we should double check stuff as it comes in. I would have liked to tune on it a bit, but all in all i consider it a success.
ID:	582976   Click image for larger version
ID:	582978   Click image for larger version
kermitsass is offline
post #2 of 42 (permalink) Old Jan 11th, 19, 1:21 AM Thread Starter
Thor
Re: 498 Dyno, RR270 ovals and Straub cam
Combination is
9.4:1 Mahle flat top +070, 4340 crank and rods 6.385 H beams
289 4 bolt block, arp studs ( I've had this block since the 80's when I built it as a 427)
Heads BRO2061006 Race rite 270 oval ports 110cc chamber. scorpion endurance rockers
Cometic head gasket part#CGT-C5816-030
2904 Victor jr intake, Super sucker tapered spacer HVH-SS4150-1DPAL
Frankencarb 850 hp main body and base, demon metering bowls.
SUM-G3605 Pan, and MOR-22175 pump kit
Squishy cam, morel 4603 lifters
comp 929 spring, titanium retainers
Dave's small body HEI, 9 dollar coil from oreillys.
mr 4 speed likes this.
post #3 of 42 (permalink) Old Jan 11th, 19, 2:44 AM
Jon
That Straub youngster can mathematically figure out what you need for a camshaft to make power right where you tell him you want it. I hope you get the valvetrain issue straightened out quickly. Motor made just what one would expect for that combination or a bit more.
kermitsass and unclluke like this.
72BBMonte is offline
post #4 of 42 (permalink) Old Jan 11th, 19, 3:47 AM
Marcus
Congrats! Nice build and nrís!
kermitsass likes this.
Chevelle Malibu ss 64
Th 400 Edge 9.5" converter
57 3/4Ē wide 12 bolt: Eaton posi, Us gear 3.31, Toms KA 33 splines axles
Malibu ss 64 is offline
post #5 of 42 (permalink) Old Jan 11th, 19, 2:23 PM
Thanks for letting us be a part of the build. Goal reached, happy customer...that makes my week!!!
Chris Straub
Mfg Performance Parts
cstraub is offline
post #6 of 42 (permalink) Old Jan 11th, 19, 4:44 PM
kevin
good job - your rear tires will hate you....
the heckler is offline
post #7 of 42 (permalink) Old Jan 11th, 19, 5:03 PM
Alan
I saw it on FB this morning. Looks like a nice combo that delivered! You should be able to get into the 10s and drive like stock...
I must have misread earlier, but I thought it was a 227/241* cam or therebouts of? Not that it matters, I'm just wondering if I'm going crazy...
1971 Corvette
VortecPro 496"
T400, Tight 10" converter
3.36 gears, 3700lb raceweight
[email protected], 1.51 60'
STOCK APPEARING
ShouldntBeHere is offline
post #8 of 42 (permalink) Old Jan 11th, 19, 6:58 PM
I edited the cam specs on FB. My fault...lack of coffee.
ShouldntBeHere likes this.
Chris Straub
cstraub is offline
post #9 of 42 (permalink) Old Jan 11th, 19, 7:33 PM
jackie
Thatís a stout motor to be under 10 to 1compression.
And it made itís max power at under 6000.
That is going to be one great street engine.
jackie schmidt is online now
post #10 of 42 (permalink) Old Jan 11th, 19, 11:59 PM Thread Starter
Thor
Thanks Alan, been a big fan of your car for years! I really liked that it worked so well with 3:31s, and have to say a big influence in the direction this took. I'm hoping this will be a fun combination to drive with a tight 10" tree master.
I was confused about the fb thing until seeing Chris' response. Not the Clay Smith cam, but I have bought one of them from Chris as well so I could be confusing ... lol This one has a bit more rowdy idle to it, when it first fired my engine builder looked at me and said "well so much for your sleeper idea".
post #11 of 42 (permalink) Old Jan 12th, 19, 12:16 AM Thread Starter
Thor
Thanks! I sure hope so.
Pat_McNeil likes this.
post #12 of 42 (permalink) Old Jan 12th, 19, 6:41 AM
Originally Posted by kermitsass View Post
Combination is
242/254 on 107 LSA has to be lumpy as heck. You already had the heads? My guess is those are a choke point. 500" stroker could've used at least a 300cc intake runner and a smaller cam with wider LSA. I'm going to guess this motor only pulls about 7-8" vacuum at idle?
Status: Car-Less
GRN69CHV is offline
post #13 of 42 (permalink) Old Jan 12th, 19, 8:19 AM
Nice build and the results to back it up.
On a side note,noticed you have a Dave's small body HEI.
Recently picked on of those up myself,he sure does nice work.Looking forward to using it.
mr 4 speed is offline
post #14 of 42 (permalink) Old Jan 12th, 19, 9:14 AM
They are great pieces, ran as promised with NO problems.
Dan Orgill is offline
post #15 of 42 (permalink) Old Jan 12th, 19, 9:27 AM
jackie
I have DUI's small body version of a HEI. I had to go to it because the regular HEI would not fit between the injector rails on the Holly Multiport Fuel Injection. Works Great.
https://www.chevelles.com/forums/att...1&d=1547299603
The DUI coil mounts right on the firewall.
blue_69_malibu likes this.
This Thread is more than 376 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
