Snow Flake Head 454 Dyno Results....... - Page 2 - Chevelle Tech
 40Likes
post #16 of 40 (permalink) Old Dec 21st, 18, 10:07 AM
Scott Foxwell
Re: Snow Flake Head 454 Dyno Results.......
Originally Posted by StevenS View Post
That sucker looks real fat. I guess it liked a lot of fuel.
02's weren't turned on for that pull.
FOXWELL MOTORSPORTS
Straub Technologies
steelcomp is offline
post #17 of 40 (permalink) Old Dec 21st, 18, 10:09 AM
Scott Foxwell
Originally Posted by steelcomp View Post
088 casting
Correction...077 casting.
FOXWELL MOTORSPORTS
Straub Technologies
post #18 of 40 (permalink) Old Dec 21st, 18, 10:11 AM
I gotta say, a 10:1 454 w/077 heads and that cam making 575 HP is impressive in my book. Nice combo that will be a blast to drive and have the ability to get into the high 10's/low 11's with a well sorted car.
JMHO
steelcomp and mrpaticular like this.
mr 4 speed is offline
post #19 of 40 (permalink) Old Dec 21st, 18, 10:19 AM Thread Starter
JMHO
The Ol school cam has proven itself to be very well suited for the the OEM headed BBC running around out there.
mr 4 speed, 427L88 and dell72 like this.
Chris Straub
Mfg Performance Parts
cstraub is offline
post #20 of 40 (permalink) Old Dec 21st, 18, 10:28 AM
Chris, what is the maximum recommendation for the 5374 lifters? Will they work with the .620/.600 Clay smith cam or is it time to step up?
bracketchev1221 is online now
post #21 of 40 (permalink) Old Dec 21st, 18, 10:45 AM
Scott Foxwell
It was kind unfortunate, and very fortunate at the same time, for the owner. He had sent us the long block with heads torqued on, cam installed, and all I was supposed to do was check the degree on the cam and do the valve train geometry, measure for pushrods, install the pan and finish up the motor for dyno. Well, the heads had green painters tape over the intake ports and were supposed to be fresh form the machine shop. When I pulled the tape off, this is what I found when I looked in the ports:
So I contacted the owner and he said lets pull the heads off and please check them out...
Notice how the head gasket doesn't even seal on one end of the head. They were pretty sad. Horrible, in fact.
We installed liners in all the guides (retained the factory 3/8 valves), installed new larger intake seats, gave them a fresh valve job and surface and re-assembled with new springs, retainers and locks. Valve job depths all get equalized to within .001" (after surfacing) and installed height on springs is within .005 high to low (+/-.0025"). We have springs in bulk so I sort through them and get springs all within 5# high to low (+/- 2.5#). We do this to every set of heads that leaves the shop. The ex seats on these heads were the hardest thing I've ever cut and actually needed to be hit with a stone for final finish. Probably Stellite. In the end, with our valve job and additional back cut on the intake valve, they turned out to be a real nice set of very clean, unmolested heads and seemed to work just fine.
(before I took them apart)
On the dyno
FOXWELL MOTORSPORTS
Straub Technologies
post #22 of 40 (permalink) Old Dec 21st, 18, 11:29 AM
Very nice Scott. Wish I had clearance for a Vic Jr
What did you use for oil pan , tray ??
Tremec by Liberty[/FONT]
Foxwell 475 BBC 688hp /610 tq
Crusin / Track video
CDN SS is offline
post #23 of 40 (permalink) Old Dec 21st, 18, 11:46 AM Thread Starter
.375 lobe lift
6500 rpm Max
150/400 spring rate
Chris Straub
cstraub is offline
post #24 of 40 (permalink) Old Dec 21st, 18, 11:56 AM
FYI, TC'er B433 Brian fit a modified Vic Jr under the stock hood of his 66 Chevelle. There is another thread in the performance section about 67 hood clearance where he discusses the modifications.
427L88 likes this.
dell72 is offline
post #25 of 40 (permalink) Old Dec 21st, 18, 12:02 PM
Scott Foxwell
Pan is a Summit/Moroso deal. It's claimed to be 8" deep but actually 8.5". The pickup they recommend (Moroso p/n) leaves 1"+ of pickup to pan clearance so we got one from Stefs. This is still about 5/8 clearance with a gasket on the pan. Std volume Melling pump.
I'm guessing the slight drop in pressure is before oil starts getting back in the pan and the level drops some. I think I had 6 qts total. Might want 7. We also found out the dyno is reading about 7-8# lower than it should.
FOXWELL MOTORSPORTS
Straub Technologies
post #26 of 40 (permalink) Old Dec 21st, 18, 12:22 PM
Originally Posted by cstraub View Post
.375 lobe lift
6500 rpm Max
150/400 spring rate
I think I could pull it off.
Ray
post #27 of 40 (permalink) Old Dec 21st, 18, 12:30 PM
HOLY COW! Scott's the pro so I'm sure the're not that great to him , yet... so far the best heads I've ever had on my car were well prepped 074s. 118.75 mph worth of head. They were drama prone, to be sure, which is why I offed them. But can make some good power, even in a short stroke 433. Those were fugly prepped. Like high school shop class crap, chatter, etc. Wow.
P.S> I hope to get some "good heads" next year and wake the beast back up.
NICE WORK FELLAS!
PS
Brian is as careful and fastidious as you Bill. I read some of that thread, it takes a bit of fiddling to be sure.
MERRY CHRISTMAS ALL!
steelcomp likes this.
post #28 of 40 (permalink) Old Dec 21st, 18, 12:34 PM
jackie
Just curious. Is the aluminum alloy in these newer "snowflake" heads better than the old heads we used back in the '70's?
Did the custome already have these heads?
427L88 likes this.
jackie schmidt is offline
post #29 of 40 (permalink) Old Dec 21st, 18, 12:43 PM
What newer snowflake heads are you referring to? Todays GM heads?
92Camaro
92Camaro is offline
post #30 of 40 (permalink) Old Dec 21st, 18, 12:52 PM
Wont work for me I have the factory Cowl Plenum air cleaner it’s 1 1/4” taller than the stock open element assembly I had to machine 1/8” off carb pad on the air gap to clear
427L88 likes this.
CDN SS is offline
This Thread is more than 402 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
