L78 intake plenum divider - Chevelle Tech
 45Likes
post #1 of 43 (permalink) Old Dec 19th, 18, 9:09 AM Thread Starter
I'm about ready to reinstall my bbc in my 65 after a rebuild. The motor is a .30 over 454 , 2.19 valve 781's with a summit 1303 cam, Holley 850dp. I have an L78 163 intake with rec port gaskets I want to install for the stock appearance. Is there any downside to modifying the divider? I've seen them cut down an inch or so and sometimes completely removed. Suggestions?
aimhard is offline
post #2 of 43 (permalink) Old Dec 19th, 18, 9:26 AM
Re: L78 intake plenum divider
Usually runs better at rpm with a .500"-1.00" gap. You can mimick this with a open spacer/heat shield. Ps UltraSeal 5828 is a good gasket to do this with.
aimhard likes this.
post #3 of 43 (permalink) Old Dec 19th, 18, 9:27 AM
Rich
Well, the Chevrolet Performance intake manifold which you could say is a modern day interpretation of the L78 manifold has a cut down plenum divider so I'd assume those in the know believe there is an advantage to be had in doing so.
427L88, NickeyChevelle and aimhard like this.
NCOA member #220
ACES member #1670
Team Chevelle #998
Rich Cummings
Rich-L79 is offline
post #4 of 43 (permalink) Old Dec 19th, 18, 9:36 AM Thread Starter
Thanks Gene, 5828 is what I intended to get but I ordered the Mr gasket 108 by mistake. Also, thanks for that pic Rich.
aimhard is offline
post #5 of 43 (permalink) Old Dec 19th, 18, 9:51 AM
Removing the divider and more or less leaving a .090-.100 lip on a 163 intake is worth 35 HP on 4.25" stroke 291 casting untouched square port heads.
tested by Eric @ Vintage Musclecar
You can find the info doing a search in this forum.
mr 4 speed is offline
post #6 of 43 (permalink) Old Dec 19th, 18, 11:47 AM
Rich
What do you mean by "leaving a .090-.100 lip" on the intake?
NCOA member #220
ACES member #1670
Team Chevelle #998
Rich Cummings
Rich-L79 is offline
post #7 of 43 (permalink) Old Dec 19th, 18, 11:56 AM
the .090-.100 lip refers to the height of the plenum divider.
This is my intake in this pic
badrad and aimhard like this.
post #8 of 43 (permalink) Old Dec 19th, 18, 12:45 PM Thread Starter
I just read that test. Those are some big gains for a simple change. Mr. 4 speed thanks for your photo.
mr 4 speed likes this.
aimhard is offline
post #9 of 43 (permalink) Old Dec 19th, 18, 1:07 PM
Bruce
What is your intended use? If low rpm carb response, low rpm torque and street driving efficiency is important to you, then you want the divided plenum in place.
WOT romp for 1/8th or 1/4 mile? Then sure.
Try the spacer idea first, experementation is fun, eh?
427L88, CRV CRW and aimhard like this.
Our You Tube Vids:
NickeyChevelle is offline
post #10 of 43 (permalink) Old Dec 19th, 18, 1:29 PM
I can assure you that removing the plenum divider will NOT cause any of issues that you mentioned. In fact,it increases throttle response,torque/HP
Eric's dyno tests indicate that plain as day. FWIW,my engine has ridiculous,instant throttle response and outrageous low end torque.
post #11 of 43 (permalink) Old Dec 19th, 18, 2:08 PM Thread Starter
It's a street car, but will go to the track some. I'd love to see some 12's.
aimhard is offline
post #12 of 43 (permalink) Old Dec 19th, 18, 2:08 PM
Mr Bill
I must be having a search brain cramp Could you post a link to it, I would like to see it.
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Team Chevelle #100
BillK is offline
post #13 of 43 (permalink) Old Dec 19th, 18, 2:14 PM
Hi Bill,read post #39:
https://www.chevelles.com/forums/13-...intakes-3.html
71350SS and DJsSS like this.
post #14 of 43 (permalink) Old Dec 19th, 18, 2:35 PM
A good friend of mine runs [email protected] 107-108 MPH with a flat top 454 with 215 heads w/2.19 intake/1.72 exhaust, the same cam,RPM Air Gap/850 DP,small tube headers. 3.42 gear/TH400/3200 rpm or so 10" convertor. 4000 lbs. 69 SS 396 full street trim. He drives it everywhere,family goes out for ice cream in it. And it burns 87 octane since it has about 8.9:1 compression.
Your 65 should have no problem getting into the 12's with your combo
(FYI-the engine in his pic is NOT his engine,someone uploaded the wrong pic )
aimhard likes this.
post #15 of 43 (permalink) Old Dec 19th, 18, 3:23 PM
Rich
Gotcha. Thanks for the clarification.
NCOA member #220
ACES member #1670
Team Chevelle #998
Rich Cummings
Rich-L79 is offline
