396 Poor Off Idle Torque - Chevelle Tech
 49Likes
post #1 of 128 (permalink) Old Dec 15th, 18, 7:47 PM Thread Starter
From a stop, I’m used to dumping clutch giving gas and driving off. I have to feather clutch as if RPM drops below idle, engine can’t recover & dies.
396/365 engine dyno, tried 670 Street Avenger & 650 DP. M21, 3:73, 20 idle timing, Elgin 1310, 228/238, idle around 850, no headers, small heads, Qjet intake w/adapter
The only way I can drive this thing is to idle close to 950. Sounds like it’s stuck on fast idle.
I’m at wits end
Reelysalty is online now
post #2 of 128 (permalink) Old Dec 15th, 18, 8:10 PM
Re: 396 Poor Off Idle Torque
20 degrees with vac advance or not?
69 461" BBC 11.25:1 Compression
Orig Exhaust Manifolds
Straub (Clay Smith) Hyd Roller cam, 288/300 .600/.569 109.
TH400, 3500 stall, 4.11 12 bolt posi
rp930 is offline
post #3 of 128 (permalink) Old Dec 15th, 18, 8:12 PM Thread Starter
Oh, stock distributor Pertronix conversion, vacuum advance, 93 gas
post #4 of 128 (permalink) Old Dec 15th, 18, 8:14 PM Thread Starter
20 w/vacuum plugged, connected when running
post #5 of 128 (permalink) Old Dec 15th, 18, 8:23 PM
How does it run once you get going? Good power? You sure you dont have a clutch issue?
64 Chevelle 496
StevenS is offline
post #6 of 128 (permalink) Old Dec 15th, 18, 8:52 PM Thread Starter
OK power
Clutch is very smooth
post #7 of 128 (permalink) Old Dec 15th, 18, 8:56 PM
Justin
What is the issue? It takes a lot of RPM to get the car going? Or the when returning to idle the RPM undershoots and dies?
JF74chevelle is online now
post #8 of 128 (permalink) Old Dec 15th, 18, 9:00 PM
Mr Bill
Is this something that just started happening ? Has the car been ok in the past ?
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Team Chevelle #100
BillK is online now
post #9 of 128 (permalink) Old Dec 15th, 18, 9:21 PM Thread Starter
Been this way since I bought car last spring.
Issue is very low off idle power,
Have to carefully feather clutch .
post #10 of 128 (permalink) Old Dec 15th, 18, 9:24 PM Thread Starter
If engine falls below idle,
it can’t recover,dies
post #11 of 128 (permalink) Old Dec 15th, 18, 9:37 PM
check the float level.
427L88 likes this.
mr 4 speed is offline
post #12 of 128 (permalink) Old Dec 15th, 18, 9:46 PM Thread Starter
Moved float from low
to middle no change
post #13 of 128 (permalink) Old Dec 16th, 18, 12:13 AM
Kerry
Add more idle timing, and richen the mixture screws slightly.
What vacuum does it have at idle right now?
jonmarc likes this.
pockets is online now
post #14 of 128 (permalink) Old Dec 16th, 18, 2:16 AM
Gary
does it have small closed chamber heads off a 396 402? that cam is not super big plus its on 114 degrees so it should have no problem idling at 750 to 800 rpm. have you checked for vacuum leaks lean idle transfer circuit mixture? try choking the carb by hand with the air cleaner off gradually. note how much if any the engine speed increases
gnicholson is offline
post #15 of 128 (permalink) Old Dec 16th, 18, 3:24 AM
Geoff
Your carb adapter should be divided [ either 2 or 4 hole ] with a dual plane intake. If it is an open spacer, it weakens the carb signal leading to...flat spots/poor transition from idle to the main system.
StevenS and roadster601 like this.
Gtogeoff is offline
