Fuel Mileage Drop... - Page 4 - Chevelle Tech
 6Likes
post #46 of 48 (permalink) Old Nov 28th, 18, 7:29 PM Thread Starter
Re: Fuel Mileage Drop...
Originally Posted by 1967 chevelle malibu View Post
Is there play in the throttle shaft, is the return spring strong enough? Worn throttle bodies can cause the plates to hang up.
I don't know about the throttle shafts. The spring is the same one I was using with my Speed Demon.
My Chevelle w/ open headers:
WakkoWarner is online now
post #47 of 48 (permalink) Old Nov 28th, 18, 10:29 PM
gary
When it is idleing fast, move the throttle up & down vertically & see if the speed changes. Does it do this with both carbs?
post #48 of 48 (permalink) Old Nov 28th, 18, 10:45 PM Thread Starter
I had noticed it doing it with the Speed Demon before I took it off. I am going to double check the return spring tomorrow and possibly put a different one on. I created a new post in the engine section looking for recommendations on a return spring bracket/setup.
