L89 Stock Appearing Nova 10.63@131 - Page 4 - Chevelle Tech
 77Likes
post #46 of 75 (permalink) Old Nov 6th, 18, 8:08 PM
I will take that bet. I know him but no i am not him.
RickyHill is offline
post #47 of 75 (permalink) Old Nov 6th, 18, 8:27 PM
Re: L89 Stock Appearing Nova [email protected]
Originally Posted by Steve R View Post
No hop bars are not traction bars, they relocate the rear of upper control by approximately 1 1/2. I doubt the guys with leaf spring cars are running off the shelf OE replacement springs. They are probably having them made to their specs. Things donít need to be stock, just stock appearing, they give plenty of leway for items that arenít visible such as internal engine components. The faster cars in the class this thread is about are well sorted out race cars. Like any race car, they pick apart the rulebook looking for an advantage.
Steve R
That's what I was getting at. The really fast guys have to be doing something with suspensions, even if they look stock. Things like different spring rate (front and rear), loose bushings up front and maybe shocks with different characteristics than OEM assembly line stuff, etc, etc. I can't believe that everyone of these cars is running on exact assembly line spec stuff, even if it appears stock.
Plus, tq converter design must be completely different from a slick car, so as not to hit the tires too hard. I would wager the guys running 10s aren't using some out of the box TCI deal from Jegs.
Steve R likes this.
novadude is offline
post #48 of 75 (permalink) Old Nov 6th, 18, 10:25 PM
I dig the stock appearing cars getting it. Kind of what I have in mind for my ‘70 Monte Carlo.
Proving every day hindsight is 20/20.
Dragginwagon467 is offline
post #49 of 75 (permalink) Old Nov 6th, 18, 11:53 PM
Like the 'vert!
Originally Posted by mr 4 speed View Post
Fellow Supercar racer Ted D's 100% stock appearing L89 Nova ran an astounding [email protected] MPH this weekend at Atco.
On repro Polyglas tires.
That Nova just screams "bitchin"!!
mr 4 speed likes this.
Bruce
We should take care not to make the intellect our god; it has, of course, powerful muscles, but no personality.
Albert Einstein
SOLD!!!!
Xplantdad is offline
post #50 of 75 (permalink) Old Nov 7th, 18, 1:47 AM
The fact that he runs 131mph with 2.5" exhaust is very interesting considering how many think they need 3" with 4-500hp engines.
What great "sleepers" all those stock appearing cars are..
mr 4 speed and Dan Orgill like this.
540 Olds is offline
post #51 of 75 (permalink) Old Nov 7th, 18, 6:27 AM
Does make you question the need for 3" exhaust.
I would guess this car has been lightened significantly. I can think of a number of ways to pull weight out : sound deadener, seat frames, gutted electronics (not that these cars had a lot of electronics), door bracing.
Steve R likes this.
Status: Car-Less
GRN69CHV is offline
post #52 of 75 (permalink) Old Nov 7th, 18, 3:53 PM
von
Lifetime Founding Member
Von
Acid dipping, thinner repro parts, alum stock appearing radiator (painted black), small light battery inside gutted stock case, etc.
von is offline
post #53 of 75 (permalink) Old Nov 7th, 18, 4:48 PM
jackie
Don't get this car confused with something you see driving down the Katy Freeway.
It's a race car, built to meet the specifications of a distinct class and optimize the perameters of the competition it will be involved in, that being 1/4 mile drag racing.
jackie schmidt is offline
post #54 of 75 (permalink) Old Nov 8th, 18, 11:56 AM
is this car really turning a 1.50 short time on true bias ply tire , or are they a super soft radial made to look like a bias ply, the bias ply from the 60 and early 70s was hard as a rock. i bet if you took one of those tires the nova is running and analyzed it u would find it a cheater tire
potent rodent is offline
post #55 of 75 (permalink) Old Nov 8th, 18, 1:58 PM Thread Starter
In regards to the Nova, his short time was 1.66 on the 10.63 run and the tires are NOT CHEATERS,they are Goodyear Polyglas repro bia plys.
So you would lose that bet
..did you read our rules on the Supercar website? NO STICKY OR SOFT COMPOUND TIRES.PERIOD
Heck,I have raced on the IDENTICAL Goodyear repro bias ply tires (G70-14) and my best 60 ft. was 1.89
mr 4 speed is offline
post #56 of 75 (permalink) Old Nov 8th, 18, 3:00 PM
yes mr 4 speed i read the rules and your car runs damm good for your class, but are the tires a true bias tire. back in the 60s i had them on my 325 hp 396 4 speed chevelle with a 331 rear gear i could lite them up in 3rd gear . are the bias ply tire made the same as back then are the belts ran the same way just asking
post #57 of 75 (permalink) Old Nov 8th, 18, 3:06 PM Thread Starter
Thank you for the kind words (along with reading our rules) and yes-they are a true bias ply tire:
https://www.summitracing.com/parts/k...+5ba26a5537ffb
They drive like crap and I can light them up at highway speeds up to 55 MPH by just rolling the throttle. Lots of fun
Ted's Nova runs the same tires.
p40 likes this.
post #58 of 75 (permalink) Old Nov 8th, 18, 6:03 PM
Jon N.
All you have to do is stick your fingernails into a set of these new reproduction tires. 60's tires (even 60's era slicks) were as hard as rocks. These new tires are made of lots softer and stickier rubber. If you haven't tried them, don't knock them.
Jon N.
dyno jonn is online now
post #59 of 75 (permalink) Old Nov 8th, 18, 10:21 PM
p40
butch
thats what i thought the newer tires are softer and sticky just could not get anbody to say it, i remember the ol 60s slick yes they was hard as a brick. i cant knock them because i have not run them
p40 is offline
post #60 of 75 (permalink) Old Nov 9th, 18, 10:25 AM
Re: L89 Stock Appearing Nova 10.6[email protected]
Originally Posted by cstraub View Post
Rickyhill,
If I was a betting a man I bet that you use to post on this site as NPS Nova and have been at least 2X's before. I may be wrong, but I don't loose to many bets.
Supposed to meet up with him today and get some more stuff off him. I bought his heads intake and cam for my l88 motor i will be putting in my S10. Want me to say hi for you or ask any question.
p40 likes this.
This Thread is more than 397 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
