Eagle Field 2018 - Chevelle Tech
 4Likes
  • 2 Post By Steve69SS396
  • 1 Post By 496blaze
  • 1 Post By Steve69SS396
post #1 of 10 (permalink) Old Oct 9th, 18, 10:57 AM Thread Starter
Eagle Field 2018
Took my car to Eagle Field in Firebaugh, California on Sunday. Been there many times. Some good 1/8 mile drag racing, run what you brung type stuff. The track is an old air field and the races are 1/8 mile. I only made 2 passes because I blew a header gasket. On the first pass I left in 2nd gear at 50% throttle and went full throttle for just the last second. It ran 6.857 at 108MPH. On the second pass I also left in 2nd gear at 50% throttle and after about 2 seconds, went full throttle. It ran 6.63 at 113mph. After the first pass I noticed a small exhaust leak. After the 2nd pass the exhaust leak was huge! It blew out a chunk of the gasket. The track was hooking and I was ready to try launching in 1st gear, but I was not going to run my car with a huge exhaust leak. Here's the video.
66rat and DragRac69 like this.
'69 Camaro - 429 SBC Dart Iron Eagle 9.325" block, Crower crank, Crower 6" Billet rods, Ross pistons (10:1), Total Seal S/S rings, AFR 245 heads, T&D steel rockers, Cloyes Timing Set, 4-7 swap solid roller 274/286 @ .050", .704" lift, Dart single plane, Dominator EFI, Stef's #1705R pan, F2 Procharger on E85
Steve69SS396 is online now
post #2 of 10 (permalink) Old Oct 9th, 18, 11:22 PM
JIM
Re: Eagle Field 2018
Sounded sweet! How much boost? What gears are in it? Seems to do pretty good on the 2nd gear start!
JIM
'67 Vette-555"/Gforce 5 Spd/Dana 60 IRS-3.07's
Best ET
Best MPH
200 MPH at TX Mile
"...when it's not pointing at a wall...grab a gear!"
*This Life Stuff ain't no dress rehearsal"
540Hotrod is offline
post #3 of 10 (permalink) Old Oct 10th, 18, 12:09 AM Thread Starter
JIM
Thanks! It has 4.10 gears in the rear. It left pretty good for part throttle in 2nd. It would have accelerated harder in 1st but traction might have been a problem. Boost was at 18 pounds.
post #4 of 10 (permalink) Old Oct 10th, 18, 12:58 PM
I was there as a spectator. Saw some good runs. How about the guy in the silver Z. Holy cow....
any4xx is offline
post #5 of 10 (permalink) Old Oct 10th, 18, 11:20 PM
Ron
Never made it out there before. Would like to next year.
69 Camaro
491/AFR 315/Straub hyd roller/pump 91
TH400/GV OD/9" 3.50's/ 255/60/15 DR
10.86 at 124.8
3670 with driver
dirtlips408 is offline
post #6 of 10 (permalink) Old Oct 10th, 18, 11:56 PM
Todd
Hi Ron,
I've taken my Nova a few times and its a good time.. I probably wouldn't take a car of your caliber since its pretty much a dust bowl dirt lot without any asphalt or concrete to drive on. Just the concrete air runway.
dirtlips408 likes this.
1970 Chevelle SS 396 (491 now) 4spd
1969 Nova 496 Turbo 400 Dana 60
496blaze is offline
post #7 of 10 (permalink) Old Oct 11th, 18, 1:32 AM
Ron
Originally Posted by 496blaze View Post
Hi Ron,
Thanks Todd. Sounds similar to Kingdon drags here in Lodi.
69 Camaro
10.86 at 124.8
3670 with driver
post #8 of 10 (permalink) Old Oct 11th, 18, 9:49 AM
Looking good, I want to check out Eagle field one of these days.
1970 Chevelle, 400, UD Harold solid, 5.565 rod, standard bore, vortec heads, Jerico DR4, best ET 11.85, 113 MPH
1961 Buick Lesabre convertible, bone stock cruiser
ChevJerico is offline
post #9 of 10 (permalink) Old Oct 11th, 18, 3:24 PM Thread Starter
The owner of the Z is a good friend of mine and tuned my car. He went back to OKC with the car about 2 weeks ago. Here's a video of him doing a huge wheelie on the street.
any4xx likes this.
post #10 of 10 (permalink) Old Oct 11th, 18, 7:25 PM
p40
butch
i would like to visit there some day and just look at the old ww2 buildings ,it used to be a trining field for the aaf duuring ww2 ,lot of history there.
p40 is online now
This Thread is more than 493 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
