BBC 6.135" rods that won't break the bank? - Page 5 - Chevelle Tech
 37Likes
post #61 of 61 (permalink) Old Sep 10th, 18, 7:50 PM
Re: BBC 6.135" rods that won't break the bank?
Originally Posted by Stokerboats View Post
Old School Pistons.... Still brand new
454+.060 1/16 1/16 3/16
old school high compression
TRW/Manley # 49056
Are the pistons New? I used that Manley piston in a 427+.030. The motor had all most 14:1 compression with an Old set of Diamond Engineering (Butch Elkins) ported 188 Iron heads. When you get ready to use them and check the piston to deck heights. You will see the flat surface quench part was machined on a slight angle. Do Not cut that out. That helps force the combustion gasses over to the exhaust valve. I should have bought another set and a 454 set as well at the time. That was back in the mid-80's.
92Camaro
92Camaro is offline
This Thread is more than 505 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
