4.3 Chevy v6 builds. - Page 3 - Chevelle Tech
 15Likes
post #31 of 39 (permalink) Old Aug 2nd, 18, 3:45 AM Thread Starter
won't let me edit the last post...? the twin turbo 4.3 nelson racing built was actually done on the old platform. I've reached out to them to see about getting their help on my lv3 build. especially the intake and tuning. I'll start a new thread on in the projects area once I'm back on land and start working on her....
BlakeSixty8 is offline
post #32 of 39 (permalink) Old Aug 2nd, 18, 6:11 AM
Re: 4.3 Chevy v6 builds.
If you really want light GM, they sell a e-rod version of their turbo 4. It has "lightweight" mentioned like 87 times, but nowhere do they tell you how much it weighs... I would love to put that in the Elky I have, but $7,000 is a bit steep. Probably runs better then 99% of the 1967s ever did though.
Pioneer4x4 is offline
post #33 of 39 (permalink) Old Aug 2nd, 18, 6:23 AM
I know the old Nascar Busch Grand National Series ran the V6 at one time years ago but I don't know what they were based on.
25C 70 is offline
post #34 of 39 (permalink) Old Aug 2nd, 18, 8:18 AM
Yes folks, the LV3 4.3 is a modern all aluminum direct injection engine. It's part of the gen V series. It makes 285 hp and 305 tq.
It has NOTHING to do with the old school iron block 4.3 that was created by chopping a pair of cylinders off an old school gen 1 small block 350.
GM EFI Magazine
Blake, this would be a very interesting build, I hope you post pics if you do it. I believe chassis interference will be your biggest problem.
Pat_McNeil likes this.
LS1tech.com supermoderator.
How may I help you?
1999 Trans Am-500hp
paul bell is offline
post #35 of 39 (permalink) Old Aug 12th, 18, 11:06 AM Thread Starter
GM EFI Magazine
I didn't even consider that....its something ill have to deal with eventually. No matter what I'm going to run a modern power plant, if that means I've got to run an entire new wiring and grounding system for lights, computer, ect. so be it. the dream I'm chasing is a classic feeling chevelle with all the comforts of modern safety, reliability and handling including but not limited to abs, independent rear disk suspension, coil overs upfront. the only part i want to keep original is the 4spd Muncie, it's gotta have a rock crusher to be a chevelle, even if i do plan on adding a gearvendors overdrive unit.
a true one of a kind custom machine
I pick her up next weekend, stay tuned folks.
post #36 of 39 (permalink) Old Aug 12th, 18, 11:19 AM
Justin
GM EFI Magazine
This build sounds bada** please start a build thread when you start.
JF74chevelle is offline
post #37 of 39 (permalink) Old Aug 12th, 18, 11:29 AM
Jonathan
My boat 4.3L actually came from a 2010+ Silverado/van. The thing is a torque monster and handle WOT well, that is all a boat does is run hard, in 1st gear, WOT. The boat has a Holley 4bbl marine carb and marine intake.
Later 4.3L engines have a balance shaft to keep vibration down. The shorter engine should bolt in but with the driveshaft may be too short after the install. Should be a cool build
Two 72 Chevelle Malibus, both 350 2bbls one Placer Gold, one Midnight Bronze
Other cars:
2005 Pontiac Vibe
2005 Ford Excursion
2000 Dodge Durango
2003 Mercedes E320
2-2018 Ford Fusions
2013 Ford Fusion
Chevelle_Nut is online now
post #38 of 39 (permalink) Old Aug 12th, 18, 12:48 PM
That's NOT the engine that this thread is about.
Steve R and Pat_McNeil like this.
How may I help you?
1999 Trans Am-500hp
post #39 of 39 (permalink) Old Aug 12th, 18, 2:41 PM
^ that's what I figured out after I read one of the links. Sounds like a very interesting engine.
Gary Adrian
Busted Knuckles is offline
This Thread is more than 652 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
