Richmond debate, - Chevelle Tech
 5Likes
post #1 of 16 (permalink) Old Apr 17th, 18, 1:59 AM Thread Starter
Richmond debate,
Hello guys thinking of spring for a Richmond I think the numbers are 71-58112 ? The guy Selling says itís new with zero miles. Heís says gear ratios is 1 st 3.33:1 2nd 1.85:1 3rd 1.31:1 4th 1.00:1 and 5th 0.77:1. Is this a good trans for a mild BBC . I think my rear gear is 355 . Heís asking 3000 is this high
Thanks KW
KDW66 is offline
post #2 of 16 (permalink) Old Apr 17th, 18, 2:22 AM
Re: Richmond debate,
Is that the gear ratio you would choose if you were buying one brand new? Have you visited the Richmond website to familiarize yourself with their product line and what the differences are from one part number to the next?
Three thousand dollars isnít much of a discount, I wouldn't make any compromises for that price. Most seem to be priced in the $3,500-$3,800 range.
Steve R
Steve R is offline
post #3 of 16 (permalink) Old Apr 17th, 18, 2:34 AM
Vince
that first gear is going to be good for about 5o' on take off;
then you are going to need second very quickly
SLR is 11.82
this trans ratios are similar to the T5 or Tremec 3550
so : second thru 5th/OD would be fine; but 1st could be a deal breaker
as this trans would be great with a 2.73 or 3.08 axle gears
Clint44 and Steve R like this.
VinceS427bb is offline
post #4 of 16 (permalink) Old Apr 17th, 18, 2:34 AM Thread Starter
Ok I thought that price was kinda high for a used/ new trans with no warranty. Iíll go to Richmond site. Iím not sure what gearing I need can u you make a suggestion? I have a 468 in a 66 chevelle
Thanks KW
KDW66 is offline
post #5 of 16 (permalink) Old Apr 17th, 18, 2:41 AM
Vince
first gear x rear axle gear = SLR start line ratio [about 9.0 to 9.9 is good]
Steve R likes this.
post #6 of 16 (permalink) Old Apr 17th, 18, 3:24 AM
That number, 71-58112, doesn't seem to fit any Richmond transmissions...
https://www.richmondgear.com/wp-cont...hmond/RG22.pdf
The Super Street 5-speeds with OD have part numbers that begin with "70", not "71"... "58112" doesn't show up... Early Chevy #7020510 (10 spline) or 7020526 926 spline)...
Lots of different variations: I see at least 8 different numbers for the "A" ratio (3.33 first gear)
as other's mentioned, I think its the wrong choice for the 3.55 gearing... First gear would be close to 5.37:1 with an M21 or 4.69:1 with an M20... and the RPM drop from 1st to 2nd is really high too... That's like a tow truck...
Strength-wise, they are supposed to handle 600 lb-ft...
Brand new, they are about $3600+ at places like Jegs and Summit...
TC #1366
Sold
Sold
1966_L78 is offline
post #7 of 16 (permalink) Old Apr 17th, 18, 3:59 AM
I ran an older Richmond with 3.27 first, and 3.55s 1.62 60'. Should have been better but I'm a dummy some/most of the time. I did not feel there was a rush shifting, and 0 issues driving. Just my experience.
Mike Lewis street 572
Cale Aronson
Black Magic clutches
Cam by UDHarold
Menscer Motorsports
TRZ
CEAutoelectric
aukai is offline
post #8 of 16 (permalink) Old Apr 17th, 18, 8:34 AM
My 2 bits is that a 3.55:1 final drive ratio is too low for a Richmond trans because their final gear ratio is 1:1. A 2.73 to 3.08 ratio would work much better.
Originally Posted by Jordan Peterson
The motivation that drives the commission of the worst human atrocities is an inevitable social consequence of the refusal of the self conscience individual to make the sacrifices appropriate to establishing a harmonious life and their consequent degeneration into a kind of murderous and resentment filled rage propagating endlessly through its variations in society until everything comes to an end.
Alan F is offline
post #9 of 16 (permalink) Old Apr 17th, 18, 9:46 AM
jerry
I run a 3.27 1st with a 2.73 rear and it could use a tad more gear to start but it's behind a 327 with a moderate cam. I think that combo would be ideal for a street bbc. This trans has a 1:1 5th
cheveslakr is online now
post #10 of 16 (permalink) Old Apr 17th, 18, 11:11 AM
I would drive a car with one first.. I never liked them.. Too many over lapping ratios for a big motor..
hydro462 is offline
post #11 of 16 (permalink) Old Apr 17th, 18, 6:38 PM
I'd run a 3.08 or similar with trans. overdrive ratio at .77 is soft.
3.33 x 3.08 = 10.25 overall first similar to a 2.20 Muncie with a 4.56
.77 x 3.08 = 2.37 which is high IMO but do-able.
That trans would be better with a little stiffer first gear, like a 3.00 or so. With a 2.73 rear the OD ratio is 2.1:1, pretty stiff unless you live at Bonneville.
yeah, for the money get what you want, not necessarily what he has on hand. I dunno, with 3.08 you could skip first altogether in normal driving, just use it for serious roasting of rubber.
post #12 of 16 (permalink) Old Apr 17th, 18, 7:11 PM
Andy
I run an earlier version with a BBC 3.27 first and 3.08 rear gears.... It has the best of both worlds for me... I can cruise all day long on the highway with 3.08 at 1:1 and still have a great SLR
GuysMonteSS likes this.
Ialone is offline
post #13 of 16 (permalink) Old Apr 17th, 18, 7:41 PM
Guy
Mine is very similar,only difference is the 3.0:1 rear gear in the Ford 9 inch.
Best of both worlds indeed
Guy
Ialone likes this.
'86 Monte SS,
513 Stroker,
AFR CNC'd 315 heads,
Isky .904 EZX Roll lifters,
9 inch rearend,
TC Member # 4921
GuysMonteSS is offline
post #14 of 16 (permalink) Old Apr 18th, 18, 11:51 PM
Tommy
That's just the Richmond Gear rehash of the old Doug Nash 4+1. They weren't all that great. They kind of drove like a tractor trans and didn't handle much more than about 450 foot pounds of torque. $3k is a pretty high number for one of them.
Tommy
LS6 Tommy is offline
post #15 of 16 (permalink) Old Apr 19th, 18, 7:04 PM
Tommy
This new Richmond is rated at 600 ft-lbs...
I had an older Richmond, non-OD version), and it was great. shifted well, and never had an issue behind my big block... AFAIK, its still going strong 11+ years after I sold the car... It had a 3.04 first gear, and I built a 2.73:1 posi 12-bolt... Very nice overall...
The trans he is looking at is an Overdrive version of the old Richmond...
TC #1366
Sold
Sold
1966_L78 is offline
This Thread is more than 673 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
