Engine masters single plane vs dual plane dyno test. - Page 3 - Chevelle Tech
 26Likes
post #31 of 53 (permalink) Old Apr 9th, 18, 4:07 PM
Bart
Re: Engine masters single plane vs dual plane dyno test.
Originally Posted by justkyle View Post
I guess until you guys watch the video of the dyno runs, it wonít make sense. All of them were surprised with the torque/hp curve and how the single plane out performed the dual plane with the same cam/heads and carb. From what they were saying, it had a lot to do with the AFR heads.
I guess, what Iím getting at is, you canít compare an engine that you drove 20 years ago with the engine combo they used for this test. This is a Ford 351, with current AFR 195ís, a Holley 750 xp, and a Comp cams XE282 cam and a jetting change and the Vic jr had a better curve everywhere over 3500. Below 3500, there wasnít a 100 hp/tq difference.
When it comes out for free in a couple weeks, watch the video.
I don't doubt what you are saying at all.. All I am saying is, (and just as you stated) "All of them were surprised". Unless you are building that exact engine with the same parts, same machine work done by the same person etc, you may not get the same results they got. At the end of the day, you just have to build it the way you want it, doesn't matter what any of us think. As long as it does what you want, I say go for it.
Bart_Swisher is offline
post #32 of 53 (permalink) Old Apr 9th, 18, 5:58 PM
The quote shared by Kyle seems a fundamental fluid dynamics system....math. mr 4 speed's logic is like using an integration under the curve and then weighing or constraining for real time stuff, like powertrains, converter, atmosphere, etc. I wouldnt doubt that a true hi-vel head can provide signal strength near a 180 divided with an open plenum. Combine that with a modern "intense" cam which shows better velocities....and the system may not miss the higher velocities of the 180 at all. Put lazy heads, or too big heads back on, and it'll show different.
Back in the day, I wish I ran the Z/28 and open plenum Holley at the track. The Holley always felt better at WOT, but in terms of azz dyno...? In that particular system....it was truly a draw... ( btw, you cant bolt on the same carb from a dual to single w/o recalibrating)
post #33 of 53 (permalink) Old Apr 9th, 18, 11:13 PM
You will love the AFR heads. They work very very well.
Ialone likes this.
WHT/73 is online now
post #34 of 53 (permalink) Old Apr 10th, 18, 5:19 PM
Andy
Originally Posted by pockets View Post
Remember that a dyno test is ran at full throttle. Run that engine in a car at varying throttle openings and rates of acceleration and see what happens.
While I agree with your statement, nor to be argumentative, who is worrying about what HP and Torgue numbers you have @ 1/4 throttle below 3,500 RPM? Yes we all drive there, but at that point if more power is needed, we dip into the throttle a bit more.
Just pointing out, no one measures or really cares that his car only has 190 HP at 1/2 throttle at 3,200 rpms.....
Now drive-ability can be a factor and we would agree that should make a difference. So my overall goal is usually the most power under the curve- most overall power, over most top numbers.
As to this test, I think it's a good trade off in my mind, this engine, I'll take the Vic Jr results
Ialone is offline
post #35 of 53 (permalink) Old Apr 10th, 18, 8:26 PM
Kerry
What I should have said was see what the differences are in throttle response, acceleration at light throttle, driveability, fuel useage, engine smoothness.
Ialone likes this.
pockets is offline
post #36 of 53 (permalink) Old Apr 10th, 18, 10:14 PM
89 5.7 tpi engine , hurricane, 1" open spacer, fitech.
Drives pretty good actually. Even in lock up!
Good converter and gears help.
Idles at 650 in gear, 19.6" of vacuum timing locked at 34*
post #37 of 53 (permalink) Old Apr 10th, 18, 11:02 PM
Andy
One thing that I have heard could be an issue that would affect the result of such tests...... Throttle body type EFI's can have issues with tuning on a dual plane intake, as opposed to a single plane..... I have heard many people who have come across this issue.
Ialone is offline
post #38 of 53 (permalink) Old Apr 11th, 18, 12:47 PM
Not that it matters, but my experience using the two intake types on the same Gen 1 retrofit EFI powered engine was the reverse. The single plane took more thinking to tune. My motor doesn't make a lot of vacuum with either type intake. I had to add just a little fuel for the dual plane to make power, had to take fuel out in multiple places with the single plane with wet TBI. I had to do the same lean tune with the single plane and port injection to make good power for a driver. Every motor is different.
WHT/73 likes this.
'65 Chev El Camino
350/400+HP, 700R4
Edelbrock Pro-Flo 4 MPFI
'68 P-11 Norton
Schwany is offline
post #39 of 53 (permalink) Old Apr 18th, 18, 1:22 PM
Kim
I'm trying to decide on a Vic Jr. vs. Hurricane, vs.Dart dual plane for a 434 w/ 10.5, 220 AFR, 236/ [email protected] 520/540 lift hyd roller. I'm going to try Sniper and see how it goes. This is going to have a TKO600 in back of it and I am running 93 pump with an occasional tank of 112. I'm lacking hood clearance, so the Hurricane or Victor Sr. will be real tight. After reading for days, my eyes hurt. I really like the idea of getting the Sniper to cooperate, just a little leary. Any input is appreciated.
shelteredv is offline
post #40 of 53 (permalink) Old Apr 18th, 18, 11:42 PM
Tommy
It seems to me that it would be a comparable Test. Cubic inches is cubic inches, with a similar size cam,heads and intake on a 350 Chevy versus a 351 ford would basically make the same horsepower
No disrespect intended, but that is an invalid comparison. The head designs are not comparable and all else being as close to the same as possible, most likely the 351 will make less power the the 350.
Tommy
LS6 Tommy is offline
post #41 of 53 (permalink) Old Apr 20th, 18, 11:51 AM
Use whatever is on it now? I've used the DART SHP intake on a smaller SBC with a wet throttle body. It worked well and was fun on a street car. The single plane I used with a wet throttle body was mellower torque wise (lower low RPM torque) on a street car, but worked well foot on the floor from a dead stop where a low first gear would get the motor up in the useful power band before a second gear shift. Again street car performance.
'65 Chev El Camino
350/400+HP, 700R4
'68 P-11 Norton
Schwany is offline
post #42 of 53 (permalink) Old Apr 20th, 18, 12:07 PM Thread Starter
Kyle
Send a message via Yahoo to justkyle
Tommy
They did a comparison on that too. 351 vs 350. Same cylinder head runner size AFR's, same duration cam, same manifold, carb, etc. back to back dyno runs and both engines average hp/tq were within 1%. The ford actually made a little more torque because of the slightly longer stroke.
Kyle
1970 malibu race car (unfinished)
1968 Malibu, ZZ4, M-21 4 speed, 9" ford 3.73:1 Detroit truetrac posi
justkyle is offline
post #43 of 53 (permalink) Old Apr 21st, 18, 7:33 PM
Kim
Thanks Steve, I'm building it now and that's why the question, the options are wide open because I haven't bought anything yet.. I should prolly start my own thread on it because I have a few other questions I'd like to put to the knowledge base here, and I don't want to jack this thread any worse than I have
post #44 of 53 (permalink) Old Apr 21st, 18, 9:14 PM
Speaking of high jacking...
You building the 434 with a Dart block and putting it in the 67 El Camino?
I'll have to keep an eye on that if you are. Sounds like fun
'65 Chev El Camino
350/400+HP, 700R4
'68 P-11 Norton
Schwany is offline
post #45 of 53 (permalink) Old Apr 21st, 18, 10:13 PM
Has anyone else noticed that none of the professional engine builders have weighed in on this thread.
Steve R
Steve R is online now
This Thread is more than 592 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
