Oliver's Tunnel Ram 467 Build - Page 3 - Chevelle Tech
 157Likes
post #31 of 68 (permalink) Old Mar 15th, 18, 9:47 PM Thread Starter
MARK
Re: Oliver's Tunnel Ram 467 Build
Intake port, picture not so good.
Machined GM production heads
Oil pan modifications
VORTECPRO is offline
post #32 of 68 (permalink) Old Apr 25th, 18, 10:24 PM Thread Starter
MARK
We started assembly on this engine, we ended up cutting the domes down to lower compression, we actually ended up with 11.5 after more chamber work. Our cam is .595 net lift with a 265/270 @ .050 duration on a 108, Rollmaster timing set, should work fine for driving to the track. We used the Scat 6.385 rods with a Mahle piston set at zero deck. Our oil pan is a Moroso 20401 with a Melling M77 oil pump.
ID:	548009   Click image for larger version
ID:	548017   Click image for larger version
ID:	548025   Click image for larger version
Wolfplace, mino65, aukai and 4 others like this.
post #33 of 68 (permalink) Old Apr 26th, 18, 6:08 AM
Interesting Mark, notice you didn't stud the mains. I've always thought on a performance build main studs are the way to go on a 2 bolt block.
Status: Car-Less
GRN69CHV is offline
post #34 of 68 (permalink) Old Apr 26th, 18, 10:09 AM
Sometimes there are pans which will not accommodate main studs thus the use of bolts.
'66 SS Chevelle
565 BBC Mamofied 300cc Ovals
4.11 12 bolt
Best e.t. to date [email protected] @115.31
1.315 60'
Stokerboats is online now
post #35 of 68 (permalink) Old May 13th, 18, 11:14 AM
OLIVER
I ll update Mark s thread since we have some preliminary dyno sheet and pics , and yes this 467 engine will go in my street-strip el camino
Oliver
Milano , ITALY
468 Vortecpro 585 HP back to street cruiser
M20 4 speed - 3.31
Prosystems 1000
BEST ET 11.62 (with 4.10)
BEST MPH 121
BEST 60 FT 1.64
4000 lbs street car
1969 El Camino Street Strip
467 Vortecpro Tunnel ram 730+ hp TH400
BEST ET 10.67 @ 127 1.56 60FT
oliver69 is offline
post #36 of 68 (permalink) Old May 13th, 18, 12:09 PM
I'm confused. You have two Elco's? I thought this was going in the strip build?
oliver69 likes this.
WHT/73 is online now
post #37 of 68 (permalink) Old May 13th, 18, 12:18 PM
OLIVER
haha, sorry i have only one elco , its a street-strip build
Oliver
Milano , ITALY
M20 4 speed - 3.31
Prosystems 1000
BEST MPH 121
BEST 60 FT 1.64
4000 lbs street car
oliver69 is offline
post #38 of 68 (permalink) Old May 13th, 18, 12:25 PM
Ok, I thought the strip bld was a strip only.
All good.
It's going to be one fun ride!
post #39 of 68 (permalink) Old May 13th, 18, 12:54 PM
Greg.
Sounds like it will Rule the Track, Oliver !
67 Chevelle Malibu SS Cdn
Born 283 / PG / A51
60' = 1.664
1/8 = 7.532 et / 91 mph
1/4 = 11.814 et / 115 mph
60' = 1.561
1/8 = 7.411 et / 90.18 mph
1/4 = ??.??? et / ??? mph
Kirk's67SS is offline
post #40 of 68 (permalink) Old May 13th, 18, 1:18 PM
OLIVER
And here is a first dyno sheet , it still needs some fine tuning but results are impressive : 729 Hp at 6700 !!!!!
Maybe Mark will chime in and say something about it
Oliver
Milano , ITALY
M20 4 speed - 3.31
Prosystems 1000
BEST MPH 121
BEST 60 FT 1.64
4000 lbs street car
oliver69 is offline
post #41 of 68 (permalink) Old May 13th, 18, 6:28 PM
Mark
Curious about that dyno water pump - is it a regular pump with an external electric motor mounted on it?
MadmanMark is offline
post #42 of 68 (permalink) Old May 14th, 18, 9:24 AM
Greg.
Damn that is one Hi Reving Monster of a BBC
I forget Oliver, what Trany are you going with
Hope it is going to be built strong enough to handle that kind of Power
Born 283 / PG / A51
60' = 1.664
60' = 1.561
post #43 of 68 (permalink) Old May 14th, 18, 9:27 AM
Kerry
Look at the afr numbers. If those are correct there is a lot more to come when the carbs are jetted to bring that into the 12.5-13 range!
pockets is offline
post #44 of 68 (permalink) Old May 14th, 18, 9:28 AM
OLIVER
its going to be a th400 built by one of Marks contacts !
Oliver
Milano , ITALY
M20 4 speed - 3.31
Prosystems 1000
BEST MPH 121
BEST 60 FT 1.64
4000 lbs street car
oliver69 is offline
post #45 of 68 (permalink) Old May 14th, 18, 9:30 AM
OLIVER
yes we spoke about it , this was the first dyno sheet , it should have more results any time soon
Kirk's67SS and pockets like this.
Oliver
Milano , ITALY
M20 4 speed - 3.31
Prosystems 1000
BEST MPH 121
BEST 60 FT 1.64
4000 lbs street car
oliver69 is offline
This Thread is more than 423 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
