Now the Rocker studs too short! - Chevelle Tech
 6Likes
post #1 of 21 (permalink) Old Feb 6th, 18, 9:55 PM Thread Starter
Used the Straub/Foxwell video to set up my rocker geometry and ordered push rods. Now the Rocker studs are too short and the fulcrum is completely on the threads even with the preload set. Anyone know what rocker studs I need? Seems like there are 50 different ones. I have attached pictures. This engine has been a pain in the azz!
ID:	521313   Click image for larger version
540 BB
10 to 4 comp.
Brodix Race Rite BB-2 Plus heads
Edelbrock RPM Air Gap
Quick Fuel 950 CFM Carb
Lunati Voodoo HR 231/239 @ .050, 600/600, 110 LSA
Johnson 2116 BBR lifters
Hooker Super Comp 2" primary headers
Tremec TKO 600 .82 overdrive
3.73 Posi
William Hennke is offline
post #2 of 21 (permalink) Old Feb 6th, 18, 9:59 PM
Mr Bill
Re: Now the Rocker studs too short!
Nobody can tell you which ones you need without knowing which ones you have. You will have to pull one and measure it and then find the correct one to order.
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Team Chevelle #100
BillK is offline
post #3 of 21 (permalink) Old Feb 6th, 18, 10:05 PM
Mr Bill
For some reason I cannot enlarge your pics, but either way something does not look right ? Hard to tell without a view from a different angle.
Bill Koustenis
Waldorf Md
Team Chevelle #100
BillK is offline
post #4 of 21 (permalink) Old Feb 6th, 18, 10:16 PM
Right click and open in new tab Bill
Jake Wade likes this.
post #5 of 21 (permalink) Old Feb 6th, 18, 10:18 PM Thread Starter
Couple more pictures
ID:	521329   Click image for larger version
540 BB
10 to 4 comp.
3.73 Posi
post #6 of 21 (permalink) Old Feb 6th, 18, 10:21 PM Thread Starter
Studs are the ones that came on the Brodix heads.
540 BB
10 to 4 comp.
3.73 Posi
post #7 of 21 (permalink) Old Feb 6th, 18, 10:44 PM
Lang
Thanks for that tip. I can't count how many pics never open like that.
langss is offline
post #8 of 21 (permalink) Old Feb 6th, 18, 10:55 PM
Pete
ARP 135-7202 is 2.350 OAL with 1.500" of solid shank
William Hennke and fr8dog like this.
CP Motorworks,Inc
Custom Performance Engines &
Cylinder Head Fixtures for Vertical Mills and Surfacing Machines
1971 Chevelle 406- Mine
1970 Chevelle 496- 10.2:1, 781 ovals, 3.31, 275/60 DR 3800lbs, [email protected] on 91 octane - Hers
CPMotorworks is offline
post #9 of 21 (permalink) Old Feb 6th, 18, 11:14 PM
Mr Bill
Is it an optical delusion or is the roller hitting the tip of the valve way out to the "outside" ? What brand are the rockers ?
Bill Koustenis
Waldorf Md
Team Chevelle #100
BillK is offline
post #10 of 21 (permalink) Old Feb 6th, 18, 11:18 PM Thread Starter
Looks like that's what I need, 135-7202. Everything else looks like it's 2" or less. I can only get 6 turns on what I have now (2"). That doesn't seem like much thread and the lock screw on the Polly lock is way far in. Thanks!
540 BB
10 to 4 comp.
3.73 Posi
post #11 of 21 (permalink) Old Feb 6th, 18, 11:21 PM Thread Starter
It's to the outside but still on center 2/3 of valve. They are older Comp steel rockers.
ID:	521385   Click image for larger version
540 BB
10 to 4 comp.
3.73 Posi
post #12 of 21 (permalink) Old Feb 6th, 18, 11:32 PM
Mr Bill
Looks good Must have been the picture angle.
Bill Koustenis
Waldorf Md
Team Chevelle #100
BillK is offline
post #13 of 21 (permalink) Old Feb 7th, 18, 1:27 AM
I had to use those same Arp 135-7202 extra long studs on some Dart iron bbc heads when i ran into the same problem you did with regular length studs, not enough thread engagement.
William Hennke likes this.
Video:
fr8dog is offline
post #14 of 21 (permalink) Old Feb 7th, 18, 8:11 PM
Todd
Same here.
fr8dog likes this.
1970 Chevelle SS 396 (491 now) 4spd
1969 Nova 496 Turbo 400 Dana 60
496blaze is offline
post #15 of 21 (permalink) Old Feb 7th, 18, 9:19 PM
Kerry
135-7202 on the intakes only when I set up AFR 265 and Straub rockers. 6 turns thread engagement is acceptable. Here are a couple options.
135-7202
2.35" installed height, .85" adjuster thread, .85" screw in length, 3.2" OAL, 1.5" shank
235-7204
2" installed height, .7" adjuster thread, .82" screw in length, 2.82" OAL, 1.3" shank
235-7203
2" installed height, .7" adjuster thread, 1.64" screw in length, 3.65" OAL, 1.3" shank
334-7203
2.1" installed height, .8" adjuster thread, .75" screw in length, 2.85" OAL, 1.3" shank
235-7202
2" installed height, 1.0" adjuster thread, .82" screw in length, 2.82" OAL, 1.0" shank
pockets is offline
This Thread is more than 710 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
