5 speed trans for bbc car. - Page 5 - Chevelle Tech
 21Likes
post #61 of 69 (permalink) Old Feb 7th, 18, 7:26 PM Thread Starter
Re: 5 speed trans for bbc car.
I was told it is about the same length as a tko 3550 or with in an inch. I have not been able to confirm that but you will have to shorten the drive shaft 1-3" depending on application.
I have not checked on cryo yet the place I linked to has one or two short 26 spline shafts in stock at the 400 price but the reason they are limited is cause of no cores to build new one's. So if you want to upgrade you can send in your 10 spline so they can reuse the gear and make you the length you need it is the same price either way just the wait time is different.
78 Malibu, 402, th350, holley sniper EFI, 9" 3:70, Hoosier 26X8.50-15 slicks.
69 VW baja 1600cc.
96 chevy 1500, tow vehicle.
03 yz85 fun bike.
Jebchevelle is online now
post #62 of 69 (permalink) Old Feb 7th, 18, 7:28 PM Thread Starter
Originally Posted by 69-CHVL View Post
Another issue is the lack of speedo drive which will be an issue for most folks.
Mine is not hooked up so it did not matter to me but the 3650 uses a digital one so you could use a digital speedometer.
69 VW baja 1600cc.
03 yz85 fun bike.
post #63 of 69 (permalink) Old Feb 12th, 18, 2:53 PM
Andy
GPS Speedo
Ialone is offline
post #64 of 69 (permalink) Old Feb 12th, 18, 2:58 PM
Andy
Back about 10 years ago, I got a hell of a deal on a richmond 5 spd.... paid $500 for it, bought it from my wifes Boss, who had it in a rarely driven '62 Vette with a very mellow LS1 in it, more of a show car. He replaced it with a new one because it was jumping out of gear.... when his new one kept also jumping out of gear he then had someone adjust the shifter linkage correctly and then had a spare trans he didn't need.
I paid more for the shifter than the Trans... I know... I should be in jail.
I am pushing the torgue limits on the trans but so far so good.
Ialone is offline
post #65 of 69 (permalink) Old Feb 14th, 18, 2:32 AM Thread Starter
Well All BS aside I am rebuilding another th350 for now. I just am gonna gather parts for the swap. Money and time dictate everything in this world as with anything and everything.
69 VW baja 1600cc.
03 yz85 fun bike.
post #66 of 69 (permalink) Old Feb 17th, 18, 11:33 PM
Max
LGT700
1969 Chevelle SS (street car)
496BBC - 10.5:1 Pump Gas
LGT700
665HP/658TQ
| Jensen's Engine Tech | SilverSport Transmissions |
max69chevelle is offline
post #67 of 69 (permalink) Old Sep 5th, 18, 12:38 PM
Send a message via AIM to Ruby67 Send a message via MSN to Ruby67 Send a message via Yahoo to Ruby67
Originally Posted by T_R View Post
TKO600 in my 66 with 454. Works perfect, shifts great. I've used it on the dragstrip, on 700 mile road trips, no complaints.
Did you have to do any mods to the trans tunnel to get the trans to fit? What about the shifter location? I have a '67 4 speed car and I'd like to convert to a5 speed, but I don't want to cut it up to make that happen.
Thanks,
Ruby67 is offline
post #68 of 69 (permalink) Old Sep 5th, 18, 1:40 PM
blm
If your go to Silver Sports Transmission website they talk about a mod they do to the trans (think it's about $600.00) that may or may not keep one from having to cut their trans tunnel. I spoke with them once and they would give no guarantees that one would not have to mod their tunnel even with the trans mod. But I believe some have not had to cut tunnel.
One creative idea I read about in a thread here was someone that did have to mod their tunnel but just used a piece of donor tunnel from another car to add to their tunnel to give the needed clearance. That would at least make fab bing the tunnel mod easy.
blm is offline
post #69 of 69 (permalink) Old Sep 5th, 18, 11:43 PM
Bill R
Transmission choice depends on how the vehicle will be used. Overdrive transmission is best choice for a street-driven vehicle, but not beneficial for a drag race-only application. I have had excellent results with Jerico 5-speed, which has a broad range of ratios available for first through fourth gear (fifth gear is 1.00). Remember, when choosing gear rations for this type of transmission to specify the largest ratio spread between first and second gear, with smaller and smaller ratio spreads between second/third; third/fourth; fourth/fifth. This way, you utilize engine torque at lower speeds to accelerate the vehicle.
64 Chevelle Malibu Sport Coupe (original owner) car now has 427" BB, Jerico 5-spd. trans., Dana 60 rear end.
SAE Member (25+ years)
ASE Master Certified Engine Machinist
AERA Certified Professional Engine Machinist
engineguy is offline
