565 REDO five years later - Page 6 - Chevelle Tech
 105Likes
post #76 of 170 (permalink) Old May 25th, 18, 12:39 AM Thread Starter
Jon
Re: 565 REDO five years later
We seem to have almost gotten through the T and D rocker setup. Pattern was nice. Had to grind the mounting bar for the stands a little to have pushrod clearance. I think we have been very thorough fitting/assembling this one.
72BBMonte is offline
post #77 of 170 (permalink) Old May 25th, 18, 12:46 AM Thread Starter
Jon
Took Orange Monster for a ride around town today, then shuffled cars so she is at the back of the building again. Time to go racing and she isn't going. Weather didn't cooperate when I wanted to run her two weeks ago.
post #78 of 170 (permalink) Old May 30th, 18, 3:11 PM Thread Starter
Jon
Bad news and good news. The 582 in the chassis car was hurt last weekend racing. Not real bad from what I've looked at so far.
The 2013 565 is being bolted on the dyno right now. Should have results this time tomorrow. Gotta go to work or we would run it later today.
Stokerboats likes this.
post #79 of 170 (permalink) Old May 30th, 18, 5:38 PM
I bet you're gonna be happy. Sucks about the 582 though. I guess it helps if you have a spare 565 though.
'66 SS Chevelle
bored small big block
performance to be determined.
91 octane special.
Stokerboats is offline
post #80 of 170 (permalink) Old May 30th, 18, 6:47 PM
I agree you never want to have to pull an engine between freshen ups but it’s part of racing. You figure we built these things to intentionally try to break them. Otherwise we’d be running then easy.
Ray
bracketchev1221 is offline
post #81 of 170 (permalink) Old May 30th, 18, 9:00 PM
Jarad
Good luck on the dyno Jon. Looking forward to the results. Sorry to hear about the 582.
Sent from my SAMSUNG-SM-N920A using Tapatalk
72 Slovelle
555 Pump Gas BBC
Best so far:
5.87-118.52 MPH
JBoggs is offline
post #82 of 170 (permalink) Old May 31st, 18, 12:37 AM Thread Starter
Jon
Originally Posted by 70SS540 View Post
I think any power gains will be because of that intake!
I put plugs in those nitrous bungs. I think it will make significantly more torque than last time down low and a tad bit more horsepower at 7200 rpm. This was my back half burner motor.
Will play with nitrous down the road when the 582 is close to ready again as a replacement motor.
72 Monte Carlo (3865 lb Street/sStrip Orange Monster)
6.09/113.75 mph 1.32 60 ft.
9.634/141.50 mph-best pass
79 Trans Am Super Street, Top Eliminator, Super Pro , Quick 16, Hot Rod
5.25 eighth mile
8's quarter mile
post #83 of 170 (permalink) Old May 31st, 18, 12:41 AM Thread Starter
Jon
If it survives the dyno beatdown and makes as much power as last time I will be happy.
Throttle stop racing part of the time is easy on them. I just gotta run her all out out too often.
Thanks Jarad, should be a hp at rpm carrier again.
post #84 of 170 (permalink) Old May 31st, 18, 1:53 PM Thread Starter
Jon
Dart 4.6 bore block
Callies Magnum crankshaft 4.25 stroke
Callies Ultra I beam rods
JE custom FSR pistons 13.5 to 1 compression, maybe a little more.
5 year old AFR 357 magnums Tony Mamo worked over
Merlin X intake ported by Tony Mamo
Comp Cams 281/294 at .050 camshaft .823/.787 lift
.903 Morel Ultra Pro solid lifters
T and D 1.75 shaft rockers
Old Pro systems 1200 cfm carb
Peak torque 803.3 lb./ft at 5500 rpm
HP repeating several times 988.6 hp at 7200 rpm (990 once)
Same combination as 5 years ago but tried to get more compression and the cam was put in at 108icl instead of 109.5
It actually did what I expected with 16 more torque and 9-10 more horsepower then in 2013. (compression and cam ICL I believe)
Should push the firebird 8.40's in good air.
HP still 966 at 7700 rpm, still carries power like a mofo.
Should be a solid motor for the racing I do .
Wolfplace, dtrubey and Orr89rocz like this.
5.25 eighth mile
8's quarter mile
post #85 of 170 (permalink) Old May 31st, 18, 2:06 PM
Great results Jon. This thing will be a blast to drive.
'66 SS Chevelle
91 octane special.
post #86 of 170 (permalink) Old May 31st, 18, 2:06 PM
Well done Jon!
Jeff Evans
65 Chevelle, LS3/T56 transplant in progress
67 Chevelle, ZZ502, AFR 305, Straub Solid Roller, 400 Turbo, Moser Rear 3.42 gear
Jeff65SS is offline
post #87 of 170 (permalink) Old May 31st, 18, 3:16 PM
Jarad
Very very nice Jon!
72 Slovelle
555 Pump Gas BBC
Best so far:
5.87-118.52 MPH
JBoggs is offline
post #88 of 170 (permalink) Old Jun 1st, 18, 6:58 AM
Nick
Another baddass BBC to your collection Jon!!
BTW...did you just use that one carb at dyno and what did you end up for a spacer?
70SS540 is offline
post #89 of 170 (permalink) Old Jun 1st, 18, 2:53 PM Thread Starter
Jon
I think I will do very well with this combination. Thank you Dan!
Originally Posted by Jeff65SS View Post
Well done Jon!
Thanks Jeff! Looking forward to running into you soon somewhere!
Very very nice Jon!
Thanks Jarad, the scheming and plotting seems to have produced good results.
I used my oldest Pro-System's carb, probably 7 years old now? I had an out of the box 1" super sucker spacer I had bought when I thought my throttle stop was hurting performance three years ago. My experience is a spacer has helped in every application I have used them when running a Merlin X. 2" may have been even better...did not try.
Carb came in jetted 98 square from other motor, 100 jets in front 101 in back made more torque in the TQ curve but not as much hp. Played with timing, proved to the retired guys those heads like 37 degrees advance. They moved it around but ended the day back with 98 jets and the 37 timing like I know has worked in other combinations.
Set lash hot after about 10 pulls, just set .018 and .020 like the card said. I liked the power curves so did not deviate from what the card said.
Fun day on the dyno for all involved, that doesn't always go that way.
post #90 of 170 (permalink) Old Jun 1st, 18, 9:16 PM
Methodical approach and no need to venture too far off from a proven combo...NICE
68 BISCAYNE 4060lb
468-9.4:1
1.76 60FT Drag Radials
11.69 [email protected] 116.30 MPH
BigRed-L72 is offline
