Which new mufflers? - Chevelle Tech
 40Likes
post #1 of 54 (permalink) Old Dec 29th, 17, 10:14 AM Thread Starter
Ron
Which new mufflers?
I had 30 series Flowmasters with full tail pipes on my 70 Chevelle 496. They had the famous drone at steady speed on the highway so I took them off and had Dynomax Super Turbo mufflers installed. I just don't like the sound of these so I am going to change them. What do you guys recommend? I didn't have the drone when I had the 4 speed but with the 700r4 it drove me crazy. I don't want it extremely loud and I will be using the full tailpipes that are on the car now. I don't want the drone either, I drive on the highway a lot.
70 Chevelle SS396 (496) Straub roller, 700r4
69 Malibu convertible (sold)
TC #54 Gold
ToocoolZ28 is offline
post #2 of 54 (permalink) Old Dec 29th, 17, 10:40 AM
Kim
Re: Which new mufflers?
I happen to like Magna Flow because they have a reasonable amount of quiet and no drone at cruise and bark nicely when you get on the loud pedal. That's my .02 anyway.
shelteredv is offline
post #3 of 54 (permalink) Old Dec 29th, 17, 10:44 AM
Ron
Dynomax Ultraflows
WHT/73, fr8dog, fridgeguy and 1 others like this.
69 Camaro
491/AFR 315/Straub hyd roller/pump 91
TH400/GV OD/9" 3.50's/ 255/60/15 DR
10.86 at 124.8
3670 with driver
dirtlips408 is offline
post #4 of 54 (permalink) Old Dec 29th, 17, 10:50 AM
I have the 2 Chamber Summit mufflers on my car,very happy with the sound-but they are not quiet.
They flow well too as I used to have Race Pros on my car and the MPH did not change at the track.
This is a 2.5" system with stock exhaust manifolds.
mr 4 speed is offline
post #5 of 54 (permalink) Old Dec 29th, 17, 10:51 AM
I have used the Magna Flows before, sound nice.
mark_follweiler is offline
post #6 of 54 (permalink) Old Dec 29th, 17, 10:58 AM
Al
They are pretty quiet until you get on it. 3"x pipe full 3 inch exhaust. Hooker Super Comp. 100% stainless steel 3"mufflers straight through no baffles. Will probably out live me.
Dynomax ...Sunday driving. Too many cops out here to crack it open. OHHH but I wanted to so badly. CHP passes in opposite direction at 9:30. Flips it and follows me for 10 minutes. Finally passes and throws a thumbs up in another video.
flowmaster 40's ...Dronies. Full 3 inch exhaust no cross pipes.
I had to quiet it down. I was having too many red and blue lights behind me when running the Flowmaster 40's. Flow master didn't seem to lasr long on this set up. Once a year I was replacing one because the baffles inside were coming loose.???
The flowmaster 44's sound pretty cool. Not sure about drone on those though.
DUTCH MAX HEADWORK is offline
post #7 of 54 (permalink) Old Dec 29th, 17, 11:05 AM
Roman
I've got a built 454 in my 70. Headers and 3" full length pipes with Flowmaster Delta Flow 50's & I love the sound. Just loud enough and NO drone!
sz0k30 is offline
post #8 of 54 (permalink) Old Dec 29th, 17, 11:11 AM
Al
We need your video bro...That was one option I had considered.
post #9 of 54 (permalink) Old Dec 29th, 17, 11:31 AM
Kevin
I have a set of twin Flowmaster 50's behind my 383 and the drone is bad. They sound decent at Idle but are loud as my wife says she can hear me coming up the road from several blocks away. I had Borla's on a previous car and they were nice sounding and well made. I hear Magnaflows are good sounding as well.
"If you're not living on the edge, you're taking up too much space" - Jim Whittaker
AFR Eliminator 195's
Inglese 50mm 8 stack injection
FAST XFI Street
SC&C Stage II Plus suspension
Hotchkis/Hellwig sway bars
Tremec TKO 600
Chevy67 is offline
post #10 of 54 (permalink) Old Dec 29th, 17, 12:10 PM
Al
Magnaflow, Borla and Dynomax Ultras are all a form of glasspacks. They are a straight through design with some form, of matting to deaden the sound. I cringe at that statement, but they do sound good and are built well.
Flowmasters and most others are a chamber design that rely on baffles to deaden sound so they have more of a chamber exhaust tone. The chamber tone is more of what I expect from a muscle car. Usually the quieter they are the more they restrict the flow.
post #11 of 54 (permalink) Old Dec 29th, 17, 12:53 PM
DMH that clip prompted me to put the same on mine, long case. Love em but they can drone fairly good at 2500 the WOT sound is worth it
OP the quietest ones I know of are dynomax super turbos 22 in case but if you didnt like the others then
Whatever it is get the biggest case you possible can. Have seen guys stuff suitcase types behind the rearend, secondarys up behind the rear tires etc
Bet a termination box would really help, makes sense...lots of topics on it @ speedtalk
cuisinartvette is offline
post #12 of 54 (permalink) Old Dec 29th, 17, 1:14 PM
Mark
I run Jones Full Boar exhausts long case on my 66 with x-pipe and 2.5 inlet and outlets. Long cases keep drone to a minimum.
modern malibu is offline
post #13 of 54 (permalink) Old Dec 29th, 17, 4:18 PM
1970 SS454 LS6 idle - YouTube
That sounds good. Just curious... What cam are you running?
novadude is offline
post #14 of 54 (permalink) Old Dec 29th, 17, 6:05 PM
Thank you. [email protected] solid
fenns70 and Thor454 like this.
post #15 of 54 (permalink) Old Dec 29th, 17, 6:22 PM
I've been using Welded ultraflo's on my Nova.
My son has them also.
We run X pipes tho.
I don't like them without one but for max effort we wanted straight though.
Click on my youtube vid to hear the old exhaust.
It was a 3" from the hedders 1/2 way through the X where it reduced to 2.5" to the ultraflows and tailpipes.
I'm currently running a full 3" X mujfflers and tailpipes.
With 80E converter locked I don't "hear" a drone.
I am running 4.30''s so that helps.
Running lower numerically gears will compound the drone especially with the converter locked.
WHT/73 is offline
This Thread is more than 900 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
