Cowl hood mods - Chevelle Tech
 19Likes
post #1 of 21 (permalink) Old Dec 19th, 17, 5:09 PM Thread Starter
Cowl hood mods
Iíve been toying with the idea of making my cowl hood functional for quite some time and I finally got around to getting most of the project done today. I ended up using an aluminum hot water heater water tray, with the center cut out and then riveted to my air cleaner base and a roll of Moroso flame retardant foam as the seal, glued down with 3M black weatherstripping adhesive.
Being that my air cleaner is positioned really high into my cowl, with the hood fully closed, I had to do a lot of trial and error fitting and trimming to arrive at the correct height of the air pan sides and foam height. I ended up with about a 1/4Ē lip or sides on the air pan and about 1.5Ē of foam required to seal-off the bottom of the hood. I still have to do a little final filing to smooth out the air pan lip but other than that, it doesnít look too bad.. Not sure if Iíll see any real performance difference but my primary goal or intent was to limit a possible pathway for hot engine-bay-air to escape up and out the cowl area when driving at low speeds, any performance increase would be a nice bonus.
ID:	504042   Click image for larger version
ID:	504050   Click image for larger version
Video:
fr8dog is offline
post #2 of 21 (permalink) Old Dec 19th, 17, 5:59 PM
Rame
Re: Cowl hood mods
Looks nice, congrats!
fr8dog likes this.
sampoerna415 is offline
post #3 of 21 (permalink) Old Dec 19th, 17, 6:03 PM
Re: Cowl hood mods
like it been debating doing something similar. The repop stick cowl induction air cleaners would look out of place on one as modded as yours
every little bit helps. considering a Holley heat shield also this gas evaoprates/boils way too easy, hot starts are a pain.
fr8dog likes this.
cuisinartvette is offline
post #4 of 21 (permalink) Old Dec 19th, 17, 6:25 PM
Re: Cowl hood mods
My air cleaner set up is similar. The main difference is I use closed cell foam so as to not let hot air in from the underhood area. I'm going to bet you'lk see a performance difference. My car slows down without it. That "could" be a jetting issue though.
fr8dog likes this.
'66 SS Chevelle
91 octane special
first day out
[email protected]
Stokerboats is offline
post #5 of 21 (permalink) Old Dec 19th, 17, 7:17 PM Thread Starter
Re: Cowl hood mods
I figure itís a cheap investment even if only marginal gains are noticed! Really hoping the Underhood heated air passes more out and underneath the firewall now. I should probably add some A-arm shields as well. I hear these can help keep the underhood heated air moving back against the firewall and out/under the chassis better?
Video:
fr8dog is offline
post #6 of 21 (permalink) Old Dec 19th, 17, 7:22 PM Thread Starter
Re: Cowl hood mods
I feel your pain with the boiling gas issues. Itís really bad at my altitude, weíre at roughly 6000í. Only quick remedy to this problem has been running at least 75-80% 100LL AvGas.
Video:
fr8dog is offline
post #7 of 21 (permalink) Old Dec 19th, 17, 7:34 PM
Al
Re: Cowl hood mods
Fun video showing air flow of a cowl hood.
Your setup looks good and should work well.
DUTCH MAX HEADWORK is offline
post #8 of 21 (permalink) Old Dec 20th, 17, 3:35 PM Thread Starter
Re: Cowl hood mods
Took the car out for a bit today, later weíre expecting snow, and after driving around town I opened the hood and noticed the air cleaner lid was ice cold to the touch. Before it would have been at least warm up to burning hot. I can also hear more carb noise through the windshield now. Interesting........ Maybe there will be a very small performance increase? Of course itís wintertime and the temp today has been around 40 degrees. It all helps with density altitude when youíre starting off at 6000í P.A. 😆
Video:
fr8dog is offline
post #9 of 21 (permalink) Old Dec 21st, 17, 12:15 PM
Re: Cowl hood mods
Its working then...it does build up pressure there, one drive in the rain youll see.
Every bit helps!!
if only there was a way to keep carbs cool with this lousy gas!
fr8dog likes this.
post #10 of 21 (permalink) Old Dec 21st, 17, 12:50 PM
Re: Cowl hood mods
Contact cement applied to both the foam and attaching base is an excellent adhesive which won't unstick vs weatherstrip adhesive.
fr8dog likes this.
'66 SS Chevelle
91 octane special
first day out
[email protected]
post #11 of 21 (permalink) Old Dec 21st, 17, 1:08 PM Thread Starter
Re: Cowl hood mods
Thatís good to know, thanks. Weíll see how long the weatherstripping adhesive lasts, hopefully for awhile? I figured the 3M black weatherstrip adhesive would last longer than the old permatex yellow ďgorilla snot?
Video:
fr8dog is offline
post #12 of 21 (permalink) Old Dec 23rd, 17, 8:14 PM
Deon
Re: Cowl hood mods
I have a cowl hood and was toying with the idea of building a box from carb to hood. To feed cold air intake that I cut in back of hood. I like your design.
fr8dog likes this.
72 Chevelle, 454, TH400, 3:73's
72SS454Chevelle is offline
post #13 of 21 (permalink) Old Dec 23rd, 17, 11:40 PM Thread Starter
Re: Cowl hood mods
Thanks, I probably could have saved myself a lot of trimming time if I would have ordered a pizza sheet instead of a hot water heater tray. I did keep a little bit of the 90 degree tray wall, just enough to hold the foam seal in place. The hot water tray was a lot cheaper than the pizza sheet so my inner cheapness made a command decision. LoL
Video:
fr8dog is offline
post #14 of 21 (permalink) Old Dec 27th, 17, 10:00 AM
Re: Cowl hood mods
I made this out of a piece of 1/8 aluminum to seal to the base of my non-cowl induction "Power Bulge" hood. I used Moroso hood scoop foam and Gorilla Glued it to the base. I cut 5 two inch holes in the underside of the hood where flap would be on a functioning cowl hood so the engine gets outside air all the time. Like mentioned above, the top of the air cleaner is cool to the touch. The drop based mount was made by Universal Spinners out of Canada.
ID:	506834   Click image for larger version
ID:	506842   Click image for larger version
fr8dog likes this.
70 Chevelle
414 BBC
TKO-600
12-Bolt/3.73
Michael Myhrvold is offline
post #15 of 21 (permalink) Old Dec 27th, 17, 11:45 AM
Re: Cowl hood mods
Is that a domed hood or the cowl hood with the flapper? This is the domed hood that was on my 72 El Camino, openings had to be cut in the back of the hood for air flow.
63 Nova wagon
Philip is offline
This Thread is more than 825 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
