Headers vs manifolds on a stock 454, observations - Chevelle Tech
 16Likes
post #1 of 20 (permalink) Old Dec 14th, 17, 4:36 PM Thread Starter
I always wondered how much torque was added by switching from cast exhaust manifolds to headers, never had a car without headers already on. I recently did the change on my 79 C-30, and it far exceeded my expectations. These engines had a ~184/194 at 0.410 cam and 7.9:1 compression ratio, super mild and embarrassingly slow in stock form. I got really tired of the lack of torque and power, but was too lazy to pull the engine. I started by recurving the distributor, setting the Qjet correctly for best power, and yanking the smog parts. This was barely noticeable on the butt dyno, but helped. Next was ditching the OEM style mufflers, went with 20" Walker 2 1/2" turbos on the stock crimped up dual head pipes (dumps in front of the axle). I could feel the effect mid range, definitely noticeable but not really anything major elsewhere.
A few months later I noticed an exhaust manifold leak, so I removed them and installed a set of Summit headers and custom mandrel bent pipes. BIG TIME difference. Major improvement across the RPM range, off idle all the way up. I can now cook the tires from a stop, none of that before. WOT is like night and day, and the 3000 RPM cliff is no longer there. And, I went from 9 to 11.5 MPG on the freeway on 3.73 rear gears at 75 MPH. This is still with the stock cam, and the iron pancake intake. Next up is an aluminum intake, then 1.8:1 stainless roller rockers.
I'm very pleased with the bolt ons, the truck went from a gutless pig to drivable. I had seen some dyno pulls with manifolds on the old LS5 and 6 engines, you could tell there was some restriction and I guess that was it.
Stu1 is offline
post #2 of 20 (permalink) Old Dec 14th, 17, 4:41 PM
Re: Headers vs manifolds on a stock 454, observations
Good info
Years ago,I picked up almost 5 MPH and almost 3 tenths in the 1/4 swapping from manifolds to headers with a well built 454
FWIW,there is a member on here (and good friend) "Big Block Dave" who took his stock,matching numbers 1974 454 4 speed Corvette down the track and ran a [email protected] MPH..bone stock,other than headers and sidepipes along with 3.55 gears.
Thor454 likes this.
mr 4 speed is offline
post #3 of 20 (permalink) Old Dec 15th, 17, 3:55 PM
bunch of years ago, 25+ , a buddy bought a mid 70s C10 with a 454. if you didn't look under the hood you would swear it was a 305! first thing we did was headers and exhaust, night and day!
mark_follweiler is offline
post #4 of 20 (permalink) Old Dec 15th, 17, 4:16 PM
Engines are only an air pump. If air goes in and cannot get it out it will not be efficient.
Take a deep breath, have someone grab your throat and squeeze some, there you have it and feel it.
Thor454 likes this.
mrpaticular is offline
post #5 of 20 (permalink) Old Dec 15th, 17, 4:41 PM Thread Starter
Yep. I wanted to post this since there a quite a few people running these engines, and they usually get told to swap heads, cam, etc. Much can be done with the stock package, I was very surprised how much I picked up just by that change. You would think that teeny tiny FT would limit the gains. I'm sure it does but less than you'd guess.
I am going to try to get the 2_0 manifold on soon, to see what that does. Anecdotally 15-10 HP, but once again I've never swapped from an OE iron to an aluminum. Then I'm installing the 1.8 roller rockers. Supposedly the ratio is closer to 1.9 and also higher throughout the lift range compared to stock stamped units, so it ought to be like adding duration. We will see...
At that point there's no more bolt on fun, other than nitrous.
Stu1 is offline
post #6 of 20 (permalink) Old Dec 15th, 17, 5:00 PM
rick
The 2.0 manifold is a peanut port manifold
shovelrick is offline
post #7 of 20 (permalink) Old Dec 15th, 17, 5:19 PM
I noticed a drop in performance when I got rid of my full length headers and went to exhaust manifolds on my 468 cruiser.
'67 Malibu,468 w/TH400
Project-
72LS3Z27 is online now
post #8 of 20 (permalink) Old Dec 15th, 17, 5:31 PM
The 2-0 manifold is an oval port.
oldcutlass is online now
post #9 of 20 (permalink) Old Dec 15th, 17, 6:22 PM
Durand
It is an oval intake but the ports neck down to fit peanuts.
This is a 2-0 intake scribed to oval port.
An old cast iron high rise flows better.
LaVelle is offline
post #10 of 20 (permalink) Old Dec 15th, 17, 6:51 PM
rick
Is the 2.0 the same manifold as a 2-0 ?, I don't mean to hijack or anything but I'm a little confused, sorry about that, I had a 2.0 on my 454 and was told it was for peanut heads and when I pulled it off to replace it with a RPM AG the ports were smaller, they did match the pp heads I had on at the time, again I don't mean to side track the OPs thread but would like to clear it up before the OP might buy the wrong intake, rick, ps maybe the OP has pp heads
post #11 of 20 (permalink) Old Dec 15th, 17, 8:21 PM
OP you may also want to check cam timing, sometime in the late 70s or 80s they backed it off for emission purposes. There's power to be had advancing it to where it belongs.
71350SS likes this.
BB68 is offline
post #12 of 20 (permalink) Old Dec 15th, 17, 9:34 PM
I ran my 75 C20 454 on a dyno back in July. The truck had around 53,500 original miles on it. The only thing not stock is an open element air cleaner, performance ignition module, coil and plug wires from Performance Distributors. Cast iron exhaust manifolds, 2" duals into generic turbo mufflers, turning out behind the rear tires. They did 3 pulls,
first pull.......228.6 [email protected] / 318.1 [email protected]
second pull...226.9 [email protected] / 320.8 ft.lbs @34 00
third pull......228.7 [email protected] / 323.0 ft.lbs @34 00
I was surprised at the HP numbers but I thought the torque would be a little higher than what it was. I did this to get a base line for some future bolt on mods and to see what kind of numbers I can get. First thing I did was the exhaust. It now has 1-3/4" full length tube headers, a 2-1/2" Pypes system, with an X-pipe into Dyno Max Ultra Flo mufflers, sounds killer.
I didn't get a chance to run it on the dyno after the exhaust change but it definitely made a difference. I plan on another dyno session in the spring when the weather warms back up to try and get an accurate comparison. I thought you would be interested in the numbers on basically the same motor.
1972 Nova
496/T56 Magnum/3.73
1964 Corvair Spyder coupe
1975 C20 Camper Special 454/TH400
72BB Nova is offline
post #13 of 20 (permalink) Old Dec 16th, 17, 3:17 PM
Correct and that 70's era cam can be replaced in place without losing your A/C charge with a couple of bungee cords holding the condensor up and out of the way.So while you've got the manifold off you can just drain the rest of the coolant when you remove the W/P.Probably needed a coolant flush anyway.
71 El Camino SS
406 SBC M21 3.31 12 bolt
71350SS is offline
post #14 of 20 (permalink) Old Dec 19th, 17, 12:38 PM Thread Starter
Absolutely, I'm curious to see what you see on the dyno vs my guesses. I'm thinking 50-75 ft lbs across the board and a 800-1000 RPM higher torque peak.
Stu1 is offline
post #15 of 20 (permalink) Old Dec 19th, 17, 12:41 PM Thread Starter
Good ideas, but it kinda violates the bolt on principal and is a big PITA to get the pan to reseal IMO. I would just pull the engine at that point. But, it's tempting...
Stu1 is offline
This Thread is more than 784 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
